Need help with my 2007 tundra
Discussion in '2nd Gen Tundras (2007-2013)' started by Juan.magana, Jan 17, 2020.
  1. Jan 17, 2020 at 6:40 AM
    Juan.magana
    Juan.magana [OP] New Member
    Juan
    2007 Toyota Tundra sr5
    Hey guy I’m new to this page and I was just wondering if any of y’all have ran into the same problem, I’m trying to replace the pinion seal and the main bolt for the differential is stripped, any recommendations on how to take it out. Thanks50FFBADA-17D8-4777-A2AC-37352170204F.jpg
  2. Jan 17, 2020 at 7:21 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Welcome, not too sure on the fix. Nice looking rig. Those rear bumpers are rare!
  3. Jan 17, 2020 at 1:02 PM
    Dr_Al
    Dr_Al New Member
    Al
    Which main bolt are you talking about? I haven't done a pinion seal on a 2nd gen but all the ones I've done require the 4 bolts holding the drive shaft onto the pinion flange. Once they are removed and the driveshaft out of the way the pinion nut needs to be removed. I think it will be like every other one I've seen and have a section that a punch is used to keep it from loosening up. Once the nut is removed the pinion flange slide off and has the sealing surface for the seal. From there the seal can be replaced. Is it not the same on the 2nd gen?
    Often all that's needed is to check the breather. If it's plugged it will push oil out one of the seals. To test it try to spin the cap on top of the breather. It should feel loose and spin freely. Often simply twisting it by hand will free it up. They are easy and cheap to replace and lots of people upgrade it.
    Mountun Goat likes this.
  4. Jan 17, 2020 at 3:06 PM
    08crewmax
    08crewmax New Member
    CA
    ‘08 Pyrite Mica Crewmax Limited
    What are is that rear bumper? I’ve only seen it a few times.
    Mountun Goat[QUOTED] likes this.
  5. Jan 17, 2020 at 3:10 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    I’m not too sure what model they came on. I remember reading something about a sport model or something a while back:confused:
