When to install Diff drop
Discussion in 'Suspension' started by Kojack, Jan 16, 2020.
  1. Jan 16, 2020 at 5:09 AM
    Kojack
    Kojack [OP] New Member
    MIke
    Black Mountain, NC
    2017 Tundra XSP CrewMax
    I have looked and searched and can not find an answer that has concences with the masses so here it is:
    How much lift is acceptable to NOT do the diff drop?
    2"?
    2.5"?
    3"?
  2. Jan 16, 2020 at 5:28 AM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    Bilstein 5100 2.3/1.5, TRD sway bars ft/rr, Cooper Tires Discoverer AT3 XLT 295.70.18, Vision Manx 2 18x9 +12, APS side armor steps, TRD-Pro Grill and Bulge, de-chromed, blackout emblems, OEM mirror caps and flares, TRD shift knob, Leather wrapped steering wheel, All weather mats
    2" kit I bought came with DD. I with would say 2" to save your axle.
  3. Jan 16, 2020 at 5:53 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    You need it for around three inches and up. I lifted 2.9
    Inches and installed it. I didn’t see much difference from before and after. I installed myself.
    vhstejskal and 15whtrd like this.
  4. Jan 16, 2020 at 6:28 AM
    vhstejskal
    vhstejskal New Member
    Vic
    2010 Silver SR5 Crewmax
    This is interesting and not the first time I’ve read or heard that. I know folks say the diff drop changes the angle of the axles but does anyone have (before/after) results? Don’t get me wrong I have one; maybe its more insurance measure than anything but how much of a difference does this make?
    :anonymous:
  5. Jan 16, 2020 at 6:31 AM
    Tundyfundy
    Bay Area, CA
    The bitch of it is it can affect the longevity of your needle bearing if you’re not careful. It doesn’t actually drop your diff, it pitches it forward at an angle to lower only the part your axles go
    Into so if you don’t keep your oil topped off it can leave that bearing in the air bubble unlubricated. I won’t go through the trouble of taking it out now that it’s I. But I slightly regret it. My cv boots still look angled. I’m sure I’ll have to replace them sooner than stock.
    Sas and 15whtrd like this.
  6. Jan 16, 2020 at 6:35 AM
    15whtrd
    15whtrd Mr. Blonde
    The Pro with 2” lift doesn’t have it, that’s what I have and didn’t install one either. If you do, top off the oil until its at the fill threads again.
    831Tun, Sas and vhstejskal like this.
  7. Jan 16, 2020 at 6:55 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    The articles I've read about it say 3+, but they also say that the CV angle only changes by a couple of degrees once it's in. I have a set laying around and have more than 3" in the front, but haven't installed them yet. Matthew at MCM said he didn't think they were necessary FWIW.
    15whtrd likes this.
  8. Jan 16, 2020 at 8:07 AM
    blizz86
    blizz86 New Member
    Installed them when I put my coilovers in and took them out a year later. No noticeable change in cv angles. They also make your front diff closer to your skid, so if you ever smash your skid hard enough your diff drop pucks will punch holes into your front diff.
  9. Jan 16, 2020 at 8:22 AM
    SprinterAE86
    Ian
    FYI, it's a pain to install. You'll need magnet, it will be your life saver.
  10. Jan 16, 2020 at 8:23 AM
    Kojack
    MIke
    Black Mountain, NC
    Let's ask this question then fellas...…
    Who here has 5100's on the 2.5" setting or 6112's on say 1.9 and up or any other lift and HAS NOT installed the diff drop and if not, how many miles since install and have you had any issues?
    vhstejskal likes this.
  11. Jan 16, 2020 at 8:23 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Lots of the LT tundras are pushing 4" and none have diff drops.
    Challenger1 and 15whtrd like this.
  12. Jan 17, 2020 at 12:18 AM
    wildbill2020
    wildbill2020 New Member
    2020 tundra sr5 crewmax
    5% tint all around, 35% tinted windshield with a 5% brow, removed stickers/decals
    following......
  13. Jan 17, 2020 at 2:03 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Anything over 2.5” I’d do a diff drop and anything over an inch in the rear I’d do the carrier bearing drop
  14. Jan 17, 2020 at 2:57 AM
    bradleykd
    bradleykd New Member
    Brad
    Kentucky
    2016 Limited-BLACK
    I've got 45,000 miles on 6112's on the top setting with no diff drop. I got my suspension from Keith at Dirty Deeds and he said not to worry about it.
    Bakelite likes this.
