Replacing differential
Discussion in '1st Gen Tundras (2000-2006)' started by MC2004, Jan 8, 2020.
  1. Jan 8, 2020 at 3:44 PM
    MC2004
    MC2004 [OP] New Member
    2004?Tundra ext cab
    The rear axle housing on my 2004 Tundra extended cab automatic SR5 has rusted through. I believe it is a limited slip differential, I can only find a locking differential as a replacement. Does anyone know if they are interchangeable?
  2. Jan 8, 2020 at 3:51 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    MC2004[OP] likes this.
  3. Jan 8, 2020 at 4:43 PM
    Grumpy Uncle
    Pat
    CO
    My Auburn is LSD. I'm not sure if they have an option for the 1st Gen. I THINK the 1st gen does have both E-Locker and LSD options from different companies though.
    TXMiamiFan[QUOTED] likes this.
  4. Jan 9, 2020 at 10:58 AM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    It’s sad when I hear stuff like this happening to vehicles. We are talking about some thick, sometimes case hardened steel and it rusted through? Shnikes:confused: Sorry about your costly predicament. Is it rusted through the back where the fill plug is? Or the front (gear pig)? Got some pictures?
  5. Jan 9, 2020 at 12:00 PM
    MC2004
    2004?Tundra ext cab
    Rusted through just below the fill plug. I live in Connecticut and the solution used on the roads before snow and ice storms is caustic. I had the frame replaced on recall a few years ago and although there is extensive rust on the ubut I didn’t expect
  6. Jan 9, 2020 at 12:00 PM
    MC2004
    2004?Tundra ext cab
  7. Jan 9, 2020 at 12:21 PM
    @NUDRAT were you the one that had the same problem? Didn't you find a fix?
    NUDRAT likes this.
  8. Jan 9, 2020 at 12:26 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    The rear cover isn't much more than sheet metal. Barnes 4wd has a weld on cover to replace it if you have the means or a shop that's willing.
    https://www.barnes4wd.com/Toyota-84-Rear-Axle-Heavy-Duty-Differential-Cover_p_1185.html
  9. Jan 9, 2020 at 1:01 PM
    sixteen2nd
    sixteen2nd Shadetree Mechanic
    2003 White Tundra Access Cab TRD
    MC2004[OP] and w666 like this.
  10. Jan 9, 2020 at 2:32 PM
    Festerw
    Festerw New Member
    04 Tundra DC
  11. Jan 9, 2020 at 4:54 PM
    Bubbadog
    Bubbadog New Member
    I put the Barnes 4WD Cover on my 2001. It is a thick piece of metal and should outlast the rest of the truck. It's a fairly big job but I had a more experienced buddy help me. I had tried a bunch of JB weld type fixes but they all failed within a few weeks/months.
    MC2004[OP], Festerw and KarmaKannon like this.
  12. Jan 9, 2020 at 8:22 PM
    delz05
    delz05 Old relic... Living and Loving Life!!!
    BOSTON
    2005 Tundra Limited
    Work in progress...
    Did the Barnes fix 3 weeks ago... looks and fits perfectly!
  13. Jan 10, 2020 at 6:18 AM
    SC T100
    SC T100 New Member
    2005 Toyota Tundra Double Cab 4WD
    Rancho Quicklift/RS9000XLs, Rancho rear 1.5" blocks with RS9000XL shocks in rear, SuspensionMAXX extended sway bar links.
    Our Tundras didn't come with a locking diff. Where are you looking for replacements?
  14. Jan 10, 2020 at 6:43 AM
    delz05
    BOSTON
    2005 Tundra Limited
    Work in progress...
    05 and 06 had the limited slips... not sure about the 04. You can always enter your VIN on the Toyota website to confirm specs... toyota.com, then "owners" section then sign up and add your VIN. You will get all the specs and any recorded service histories as well....
  15. Jan 10, 2020 at 7:11 AM
    MC2004
    2004?Tundra ext cab
    I already did the specs look up using the VIN, it didn’t include the differential type or gear ratio.
  16. Jan 10, 2020 at 7:15 AM
    delz05
    BOSTON
    2005 Tundra Limited
    Work in progress...
    Odd... I just checked the specs for mine again... under the "Port or Factory Installed" section it lists "LD 4.100mm Limited Slip Differential"
  17. Jan 10, 2020 at 7:16 AM
    delz05
    BOSTON
    2005 Tundra Limited
    Work in progress...
    Perhaps yours is a regular 3.90
  18. Jan 10, 2020 at 7:29 AM
    MC2004
    2004?Tundra ext cab
    Thank you everyone for the information and advice. FYI a locking differential can not be used as a replacement for non locking, it will not line up you will need to replace the drive shaft and transfer case to make this work.
    My mechanic found a cover to weld to the housing as some of you have recommended.
    NUDRAT and speedtre like this.
  19. Jan 10, 2020 at 7:30 AM
    speedtre
    speedtre New Member
    Inland Northwest
    If it didn't say anything about the differential, then it has no LSD.
    It's either a 3.91/4.10/4.30...this link will help you determine for sure what it was built with...
    http://www.lcengineering.com/LCTechPages/TECHGEARJANUARY.html
    MC2004[QUOTED][OP] likes this.
  20. Jan 10, 2020 at 7:32 AM
    MC2004
    2004?Tundra ext cab
    Delz05
    I got the information from the Toyota dealer where I bought the truck, it is a 4.3 ratio, I think that is standard for automatic transmissions.
  21. Jan 10, 2020 at 7:35 AM
    MC2004
    2004?Tundra ext cab
    Speedtre
    Thanks. As I said replied to delz05, I got the ratio from the dealer.
    Hopefully the weld repair works and I don’t need to find a replacement.
    speedtre likes this.
  22. Jan 10, 2020 at 11:02 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    yes I'm CT with the same issue.
    My solution was - finally was cleaning out the breather!
    LOL
    I drained, scraped, sanded, brake cleanered, JB Welded, & POR15 "Top Coat'd".
    The first two times fixed the leak until I drove the truck for an hour, where it started leaking again.
    Cleaning the breather valve out & re-doing the repair the 3rd time was my solution.
    The local welder actually told me to try JB Welding it before bringing it in to him to get a new cover welded on.
    My whole axle tube is pretty ugly & NLA, so avoiding welding on a cover made some sense.
    MC2004[OP] and speedtre like this.
  23. Jan 11, 2020 at 2:56 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    My 04 4WD with V8/auto has LSD. The paper sticker stating so was still present near the fill plug.
    I don't have this problem yet, but I can see it coming. I've scrubbed off the loose rust and treated with rust converter in an effort to postpone the problem, although I'm fairly certain that when I try to remove the rusted fill plug it will either snap off, or tear the sheet metal as above. It's nice to know there are aftermarket solutions that don't involve replacing the axle.
    For those of you that have done the repair, how do you keep the metal bits from grinding out of the gears? Do you have the pull the axles and carrier before cutting off the old cover?
  24. Jan 11, 2020 at 4:41 AM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    JB weld sucks for that purpose....some high quality bond works better, been there done that. That's if you can't weld a new cover on which is the way to go.
  25. Jan 15, 2020 at 6:39 AM
    MC2004
    2004?Tundra ext cab
    The weld cover fix worked and saved me a lot of money. Thanks again to everyone.
    The garage owner told his mechanic to leave the plug green, he left the whole piece green. It is clear coated so I will leave it green.
    NUDRAT, Mr0range, Sunnier and 6 others like this.
  26. Jan 16, 2020 at 3:36 PM
    Professional Hand Model
    Fred
    Hand Protectors
    bmf4069 likes this.
  27. Jan 16, 2020 at 3:58 PM
    Sunnier
    Sunny
    San Diego, CA
    Ha! :eek2: Not exactly. ;)
    Hulk > frog
