Bigger fuel tank for the 4.6liter even economic?
Discussion in '2nd Gen Tundras (2007-2013)' started by D4x4TRD, Jan 11, 2020.
  1. Jan 11, 2020 at 7:59 AM
    D4x4TRD
    D4x4TRD [OP] New Member
    Định
    Va beach, VA
    2012 Sr5 DC TRD 4x4 Blaaaaaack baby 4.6liter
    Blacked out front grill badge Bigger tires 305/60r18 Tonneau cover
    So I was thinking... if I add a 38 gallon tank or even expansion tank would the extra weight of gas when tank is full affect the mpg of the smaller v8 to a more noticeable difference when compared to the bigger v8? Trying to see if it’s even worth the “extra miles” before having to fill up so soon on the 26 gallon tank.thanks for all responses in advance.
  2. Jan 11, 2020 at 8:15 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    I can't imagine it's 'worth it' unless you genuinely need the extra range of 12 gallons, so that would be about what 12x17=204 extra miles compared to 26x17.
    So range may increase (at 17mpg) from 442 to 646. Few places in US that don't have fuel even 300 miles apart much less 442 or 646. Just saying.....
    Luck and enjoy those Toyota projects. : ^ ))))
    D4x4TRD[OP] likes this.
  3. Jan 11, 2020 at 8:17 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    The additional expense of the conversion makes it a bad idea imo, but everyone will have their own idea what convenience is worth. The additional gasoline will only weigh about 72 pounds.
    15whtrd, Mountun Goat and D4x4TRD[OP] like this.
  4. Jan 11, 2020 at 10:34 AM
    D4x4TRD
    Định
    Va beach, VA
    Thanks guys for the responses. I was thinking along the perspective you guys have. On to the next project idea.
  5. Jan 11, 2020 at 1:27 PM
    greghoro
    greghoro New Member
    Greg
    2012 Sequoia Limited
    I’m seeing some discrepancy in the math from the replies.
    The way I read the original post was that you wanted to add a 38 gallon tank to bring the total capacity to 64 gallons (26+38).
    Others have interpreted your question that you want to add a tank to bring your total capacity to 38 gallons.
    Which one is it?
    The first option (64 total gallons) would add 228 lbs when you fill up. As another poster said, going to 38 total gallons would only add 72 lbs
    Greg
  6. Jan 11, 2020 at 4:28 PM
    D4x4TRD
    Định
    Va beach, VA
    Good point. I was looking at total 38 gallons. Didn’t think about much more than that since I already run 33” LT tires and it’s 4x4 and of course a small lift and that setup already hurts the power feel a little. I guess I was really wondering if I might feel like the 4.6 is lugging around an extra load all the time with a 38 gallon tank or if the “extra weight” might hinder it more on say like highway passing and take off from red lights. Or I might not be able to form the right question for what I’m thinking. And thanks for your input good sir.
  7. Jan 12, 2020 at 10:02 PM
    TunaDr
    TunaDr New Member
    2007 Tundra
    I joined to see what is possible
    Theres a company that makes an aftermarket 50 Gal gas tank but its pretty pricey...maybe like $2000?
  8. Jan 12, 2020 at 10:39 PM
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    You won’t notice it. You’ll notice more from heavy tires. You can always run a Jerry can or two for the times you are worried about range, saves you a ton of money.
    most stuff I’ve seen is $1500-2000 plus shipping / install
    I considered going to a 34 gallon in my Tacoma but 3 Jerry cans is a whole lot cheaper..
    D4x4TRD[QUOTED][OP] likes this.
  9. Jan 13, 2020 at 6:02 AM
    D4x4TRD
    Định
    Va beach, VA
    Oh shoot didn’t even think about the jerry can route. Duh. That would be cheaper by a long shot and leave me extra money for bed rack or cover. Thanks a lot. Great idea.
  10. Jan 14, 2020 at 1:00 PM
    TunaDr
    TunaDr New Member
    2007 Tundra
    any mounting ideas for the jerry cans?
  11. Jan 14, 2020 at 1:16 PM
    D4x4TRD
    Định
    Va beach, VA
    Possible to mount on tailgate area, in the bed against the back of the cab, or even on a bed rack. Those are the first possibilities for me. Just have to consider what other purposes I have for the truck setup to optimize space and keep weight down.Im pretty sure there are pictures of other setups on the forum. Just have to search a little.
