Claybar usage?
Discussion in 'Detailing' started by Lainhairr, Nov 29, 2019.
  1. Nov 29, 2019 at 6:01 AM
    Lainhairr
    Lainhairr [OP] “Life’s a garden.. dig it” - JD
    Zach
    Northern Ohio
    SR5 TRD Off Road Tundra
    So I live in upstate Ohio, where it's cold right now. I have never messed with Clay bar and I have never owned a white vehicle. Reason being I never messed with Clay bar is because I lived in southern VA forever and never had a vehicle with white as paint. Well now that I own a white tundra I have finally seen and learned what IFO (Industrial Fallout) is haha. Can anyone give me advice and or brand names of Clay bar? When should you use Clay bar? where should you use it at (indoor? warm wether? certain temp?) Is there a certain time I should use Clay bar before the IFO on my truck becomes irreversible? Again Im sorry if this is a newb post but I figure people on here would know best. Thanks again guys!
    Rex Kramer likes this.
  2. Nov 29, 2019 at 6:04 AM
    teedubbya
    teedubbya I like fat booty
    Austin TX
    2019 trd pro voodoo 4runner
    When you’re washing your truck, move your fingertips across your paint and see if it’s smooth or not. If not, time to clay. Some people clay once a year regardless.
    any brand is fine. I use mothers but it’s all the same.
    Remember to follow with wax.
    B737 and Brownsfanhere like this.
  3. Nov 29, 2019 at 6:36 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I highly recommend looking into synthetic clay mitts or towels. Way faster and easier, and last a long time.
    You can get a nanoskin auto scrub clay mitt on sale right now at detailed image https://www.detailedimage.com/NanoSkin-M54/AutoScrub-Fine-Wash-Mitt-P701/
    Or check out autogeek, I have the blackfire one which isn't so great and just got the speed master combo that I need to try. Nanoskin is the standard aka best synthetic clay just FYI
  4. Nov 29, 2019 at 6:49 AM
    Brownsfanhere
    Brownsfanhere New Member
    2015 Crew Max
    I use IronX then clay. Use a fine clay. Tons of videos on YouTube. Good luck
    Rex Kramer, YotaMan and Pudge like this.
  5. Nov 29, 2019 at 6:52 AM
    Pudge
    CT
    IronX helps a ton, especially on a white truck. Its nice to dissolve that crap before claying
  6. Nov 29, 2019 at 9:57 AM
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    I use Meguires. I use Optimum No Rinse mixed as a QD, or I just use a Meguires quick detailer.
    If the paint feels rough, like others said, it’s time to claybar. You’ll be amazed at how much crud is on the paint and won’t come clean from washing alone.
  7. Nov 29, 2019 at 10:15 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I use mother’s clay bar kit. the clay bar is softer when the weather is warm.
  8. Nov 29, 2019 at 11:03 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I use Nanoskin Autoscrub Fine Foam Pad with my DA polisher.
    A lot faster than using a clay bar.
    https://www.amazon.com/gp/product/B0090IRKUG/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    Use it with Nanoskin Glide lubricant, it is a concentrate so you'll mix it with water according to what you need it for.
    https://www.amazon.com/gp/product/B00DOS0KC8/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    The surface test I use is put your hand in a plastic bag and lightly feel the paint surface.
    You can feel how smooth the surface is or isn't with your fingertips.
    https://www.youtube.com/watch?v=DEWl3R6TPLo
    Pudge[QUOTED] and Brownsfanhere like this.
  9. Nov 29, 2019 at 11:47 AM
    mt95
    mt95 New Member
    Ohio
    2017 Tundra Crewmax-White
    Ohio here also. As others in the tread above have said, yes use the IronX and then clay bar, but with it now being cold here in Ohio, you may want to wait for spring temps to avoid freezing your fingers off. Use a good detail spray as lube with the clay bar. Being white, it will be very obvious where to spend extra time with the clay bar. The spots will show easily, and you can also feel with a fingernail too. The clay bar results will be amazing once done!! Just be sure to use a good sealer or wax afterwards. It really isn't as bad of a job as it sounds. It does go quickly, once you are onto it
  10. Nov 29, 2019 at 12:10 PM
    DJFaninTN
    DJFaninTN New Member
    Panama City Beach, FL
    2018 Super White 1794
    I had no idea you could use the Nanoskin pad on a DA polisher. Pretty cool!
    Still waiting on a deal on the Griots G9 but so far no sales to be found.
    Pudge and Brownsfanhere like this.
  11. Nov 29, 2019 at 12:34 PM
    GREENwithENVY
    GREENwithENVY New Member
    Knoxville, TN
    2020 Tundra TRD Pro
    Working on it!
    I like the Pinnacle Clay and Lubricant from Autogeek...usually try to clay 2X a year.
    Brownsfanhere likes this.
  12. Nov 29, 2019 at 1:22 PM
    PKFan
    2018 Inferno! DC SR5 4x4
    I just got a Nanoskin mitt (fine - AS-016) for $28.50 from Amazon. Way cheaper than Autogeek and other places. While I haven't used it yet, it will be with a spray made with Wolfgang Uber Rinseless Wash.
  13. Nov 29, 2019 at 5:51 PM
    Bust
    Bust New Member
    Shean
    2013 Black Toyota Tundra Rock Warrior
    I use the mother's speed clay 2.0. like some people said above, take a plastic bag and run it across the paint with your fingers, if it feels gritty, then it's time. The mitt is probably the way to go as far as time, but I do like going over it slowly so I can see areas that need more work or less when it's time to paint correct
  14. Nov 29, 2019 at 7:03 PM
    Pudge
    CT
    I have a nanoskin pad for my DA. It is fast and works well but kinda scares me cuz I don't have any feel and I worry about marring. That said, it hasn'tcaused any damage so its probably just all in my head
    Brownsfanhere and War Machine like this.
  15. Nov 29, 2019 at 7:13 PM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
  16. Nov 30, 2019 at 5:02 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    I just did used a clay bar for the first time not too long ago. I believe they make them in different grades: Fine, medium and heavy. Since my Toyota Corolla XRS was a 2005 I purchased a medium. I think that choosing the right grade may be more important than the brand name.
    The second I learning is to use PLENTY of lubricant. More lubricant can be purchased. I have used detailing sprays as lubricant.
    Last bit of advice, if you drop it, throw it out. You don't want the grit now on the bar to ruin your paint.
    After I clay bar, I wipe the area I just did with a towel so it doesn't dry on the car. I rewash the car and then wax.
    panicman and Brownsfanhere like this.
  17. Nov 30, 2019 at 4:13 PM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    I also have a nanoskin mitt ( fine grade) easy to use and does a great job . Just make sure you use plenty of lube.
  18. Nov 30, 2019 at 9:47 PM
    OV-1794
    OV-1794 New Member
    I have used the nanoskin pad with my DA a couple times on my wife's black Sequoia and 2 or 3 on my old MGM tundra and never introduced any marring. I just make sure I use plenty of clay lube.
    Pudge[QUOTED] likes this.
  19. Jan 12, 2020 at 10:12 AM
    mahmer09
    mahmer09 SR5 4x4
    Do you guys wash your truck and then clay bar? My truck is fairly clean, could use a California Duster then clay bar. Or should I wash first?
  20. Jan 12, 2020 at 11:56 AM
    Squeaky
    Squeaky New Member
    Wisconsin
    ‘19 White TRD Pro
    You definitely want to wash before using a clay bar.
    FirstGenVol likes this.
  21. Jan 12, 2020 at 12:18 PM
    Pudge
    CT
    Definitely need to wash first and not a bad idea to use a spray on iron remover before you clay.
  22. Jan 14, 2020 at 6:21 AM
    War Machine
    War Machine SSEM # 5 3MW
    Wash first, Iron X before clay helps also.
    And....please don’t use a California Duster on your paint.
  23. Jan 14, 2020 at 8:58 AM
    mahmer09
    mahmer09 SR5 4x4
    Never use the Duster? Does it scratch the paint?
  24. Jan 14, 2020 at 10:32 AM
    War Machine
    To be honest I can’t say for sure. The guy who taught me and several of us here about detailing recommended against it. I always took his word for it. You have a light color, so it may be ok. Mine is black, so pretty much anything will.
