Sprinter-AE86 Toyota Corolla Levin TRD N2+1 Supercharge
Discussion in 'Other Toyota Vehicles' started by SprinterAE86, Jan 12, 2020.
  1. Jan 12, 2020 at 4:59 PM
    SprinterAE86
    SprinterAE86 [OP] New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    Bilstein 5100 2.3/1.5, TRD sway bars ft/rr, Cooper Tires Discoverer AT3 XLT 295.70.18, Vision Manx 2 18x9 +12, APS side armor steps, TRD-Pro Grill and Bulge, de-chromed, blackout emblems, OEM mirror caps and flares, TRD shift knob, Leather wrapped steering wheel, All weather mats
    Toyota Corolla TRD N2 Levin S/C
    Lasre a TwinCam 16 and Pagasus
    Drivetrain:
    4A-GZE (ae92)
    Mobil1 10-40
    TRD oil cap
    Cusco/HKS combo oversize pulley 14 psi
    180hp@6400 140ft/lb@6400
    Front mount intercooler
    HKS Mega-Flo air filter
    Hks adjustable cam gear
    New oil seals and gaskets
    Fwd to rwd harness conversion
    TRD engine mount
    TRD clutch and cover
    Toda lightweight flywheel
    Cusco transmission mount
    Kazz 2-way LSD
    Torco racing gear oil
    Koyo LSD bearing
    Koyou wheel bearing
    Exhaust:
    TRD 4-1 headers
    Cat-delete test pipe
    HKS Hi-power with opt. silencer
    Interior:
    TRD Knob
    TRD shifter
    Integret dr seat
    Corbeau ps seat
    Schroth 5 point cam lock harness
    Nardi Classic steering wheels
    Nardi hub
    T3 hub extender
    Auto Meter gauges
    Auto Guage Tach
    Omori Guages
    Cusco 5-point roll bar
    Exterior:
    JDM Levin front end conversion
    Cusco Levin FRP fender
    Cusco Levin FRP Bonnet
    Sparco hood pin
    TRD 5 piece N2 body kit
    TRD rear spoiler
    Custom Max Steel front splitter
    Stainless steel fasteners
    JDM Levin head light
    Piaa ultrawhite bulbs
    JDM Zenki Levin grill
    JDM Zenki Levin front bumper
    JDM Kouki rear bumper
    JDM Red Line tail lights
    JDM tow hook
    Suspension:
    Tokico HTS SS Struts and Shocks
    Ground Control 450lb/in Adjustable Coil Over Front
    TRD 6kg/mm rear springs
    TRD bushings
    TRD Sway Bars
    Cusco strut bars front and rear
    Cusco panhard bar
    Cusco height adjustable camber plates
    Cusco RCA
    Wheels and Tires:
    SpinWerks 15x10 -25 (13lbs.) aluminum racing wheels
    Hoosier A7 275.35.15
    Watanabe 15x9.5 -19 ft/15x10 -25
    Maxxis 245.40.15
    Brakes:
    Cross drilled brake rotors
    Project mu brake pads
    Stainless steel brake and clutch lines
    Motul DOT 4 synthetic brake fluid
    Cooling:
    Koyo Aluminum radiator
    Dual electric fan
    148795_1577291107073_5899495_n.jpg 384975_186069501491628_1728947102_n.jpg 426831_365254976838825_1180029547_n.jpg 1093987_10201148422765598_145340395_o (1).jpg 10010016_10202810475896657_2092134316_o.jpg 45443441_10157398886663268_1828319697611784192_o.jpg DSC00933 (1).jpg IMG_4524.jpg
    TRDFerguson, chugs and 68vert like this.
  2. Jan 12, 2020 at 5:38 PM
    68vert
    68vert New Member
    AZ
    2011 Rock Warrior
    Sweet!
  3. Jan 12, 2020 at 5:57 PM
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    Cleeeeaaaannnnn
