  1. Jan 12, 2020 at 12:00 AM
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    Haha, I can definitely relate. When it's really cold the laziness kicks in when it comes to cleaning. When it comes to adding a mod it can never be too cold. I hear ya brother. Truck looks great.
    BlueRibbon4x4[QUOTED] likes this.
  2. Jan 12, 2020 at 12:58 AM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    I wired them to an ignition fuse. 7.5A under the hood, so they’re on always.
    BamaMan44[QUOTED] likes this.
  3. Jan 12, 2020 at 6:46 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Got my NSV light bar finally working the way it's supposed to and here are some Show & Tell photos...
    Exterior with BD SS-WC:
    Low Beams Only:
    Low Beams with BD SS-WC Fogs:
    High Beams with NSV Light Bar & No Fogs:
    **I couldn't be happier! Thank you to @mtTundra and @Headlight Revolution for the help and patience with this procedure!
  4. Jan 12, 2020 at 7:34 AM
    Northbound Train
    Northbound Train Masshole
    Glenn
    Western MA
    Black 2016 SR5 Double Cab 4x4 5.7
    Gave it a quick wash to get the salt off.
    Removed the transmission pan bolts and reinstalled with never seize before they actually seize.
    Got a used black radio bezel.
    Drk_Jdi, Ostrich, BamaMan44 and 4 others like this.
  5. Jan 12, 2020 at 7:36 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Show us that bezel installed when you can!!
  6. Jan 12, 2020 at 8:38 AM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    175 is the claimed weight, mine was 171 with brackets
    equin, Jimes and Pinay[QUOTED] like this.
  7. Jan 12, 2020 at 8:40 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    I think Jones also had a winch on his...
  8. Jan 12, 2020 at 8:47 AM
    youngDUMP
    youngDUMP New Member
    Oxford, MS
    2014 Tundra Limited TRD CM
    maybe I didn’t explain correctly. I have a set that say tundra installed in my front door sills that are way too long. I tried them on the rear before sticking them down on the front to make sure I didn’t get the wrong ones, they were still too long for the rear. I do not have rear door sill protectors. Just these “front” ones that say the word tundra and are way too long with no lip. You can see in the front of the protector where I trimmed to make a lip to fold over the edge.
    Edit: Figured it out. I just checked part numbers and apparently I got a set of regular cab sill protectors. SMH. I guess the trucks are that different..
    mgm16trdpro[QUOTED] likes this.
  9. Jan 12, 2020 at 8:59 AM
    I was going to paint mine......maybe it's easier this way.
    Looks nice, can't wait to see the install.
    Squatting Pigeon likes this.
  10. Jan 12, 2020 at 9:01 AM
    mgm16trdpro
    Northern NJ
    Gotcha, now I see what you're saying. See even without us totally being on the same page I was still right being a part number thing. The streak continues and wifey will be happy to know I'm still never wrong lol. Glad u got it figured out and wish u luck on the application going forward.
  11. Jan 12, 2020 at 9:04 AM
    Northbound Train
    Glenn
    Western MA
    Out with the Silver, in with the black. I love it! It’s more dark charcoal than black and matches the trim above the glove box door. The whole procedure took about an hour. Very happy with it.
  12. Jan 12, 2020 at 9:07 AM
    CorsoTundra
    CorsoTundra This is the way
    North GA
    2021 Cement Trail Edition
    Toytec Aluma 3/1.5, Pro headlights, OEM LED fog lights, AJT chrome delete, interior/exterior LEDs, front TRD sway, 18x9 Method Roosts, 285/75/18 Toyo A/T 3, RCI engine skid,
    NICE..... my hybrid bumper is at the powder coaters waiting for it's black satin finish. I went without the hoop and similar light and winch setup. I got the Rigid SAE SR 30" and the Warn VR EVO 12s. Going to use the factory Rigid fogs and a set of Rigid D series amber floods. I'm worried that after the install my front end will be sagging like an old woman's front end :eek:
  13. Jan 12, 2020 at 9:14 AM
    Jimes
    Jimes New Member
    Bay Area, California
    2015 toyota tundra trd pro
    All depends on your suspension setup. After doing the math. The bumper weighs 170lbs, winch weighs 80, led bar is 10 lbs and the 4 D2s are probably like 2-4 lbs. so about 260-270lbs. I swapped my 600lbs springs for 700lbs and it supports the weight with ease.
    equin likes this.
  14. Jan 12, 2020 at 9:19 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Its 43 degrees outside and too damn cold to be doing this install but I've put it off too long already...
    SMTundra, Patch999, tundra_20 and 4 others like this.
  15. Jan 12, 2020 at 9:22 AM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    My son and I did the easy trails at Big Bend and had a lot of fun. Definitely want to go back.
    Not sure if they’re open now, but back in the 80’s and early 90’s we used to do some of the trails around Wakulla Springs south of Tallahassee about 3 hours from you.
    I have the Bilstein 6112s and may want to go with the Icons when it’s time to replace them. How much lift did they provide?
    Your setup and plans are close to mine. Definitely interested in the ARB twin compressor, sliders and front and rear bumpers for my own needs.
    Post pics when you get your stuff!
    Elfine[QUOTED] likes this.
  16. Jan 12, 2020 at 9:50 AM
    CorsoTundra
    North GA
    Which brand of springs did you go with?
  17. Jan 12, 2020 at 10:01 AM
    :eek2::eek2::eek2:
    And I need to do this.:facepalm:
    Love the look.:thumbsup:
    Kerch71 likes this.
  18. Jan 12, 2020 at 10:30 AM
    BamaMan44
    BamaMan44 Roll Tide Roll! Bama Fan till I die! & Go 'Hawks!
    Andre
    Tucson
    Trailbreaker - 2017 Black CrewMax SR5 4x4
    Thanks! I might have to redo mine now. Lol
  19. Jan 12, 2020 at 10:41 AM
    mgm16trdpro
    Northern NJ
    It looks great black OEM, but this is the reason mine stays silver lol. I'm more of a blunt force beat things or cut things that don't separate type of guy, I think it's pretty safe to assume I'd end up with broken tabs everywhere lol.
    Boerseun likes this.
  20. Jan 12, 2020 at 10:41 AM
    Jimes
    Jimes New Member
    I have kings shocks so I stayed with kings.
    Pinay likes this.
  21. Jan 12, 2020 at 10:46 AM
    BlueRibbon4x4
    Geno
    Grabbed a Pro skid for $200, then added a little bedliner. Can’t wait to install this thing. C7A6391A-8224-454B-BE50-06494DA08A59.jpg 5742BA5A-DDBD-4C61-A55F-B90E7EEA6BBB.jpg B479D2E6-A629-42F8-842D-010BF2BB5F7C.jpg
    khunk, Pat, BIGUGLY and 54 others like this.
  22. Jan 12, 2020 at 10:50 AM
    gjbsupCM
    gjbsupCM New Member
    Glen
    Hilton Head, SC.
    21’ SR5 XSP Crew Max
  23. Jan 12, 2020 at 10:50 AM
    BROGAN
    BROGAN FNG
    Logan
    East TX
    2015 TRD Pro CM Inferno Fast
    Just ceck out build thread in sig
    Got the Wilco vertical tiregate on.
  24. Jan 12, 2020 at 11:10 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    baller!
  25. Jan 12, 2020 at 11:43 AM
    Rabidllamas
    Rabidllamas New Member
    Phil
    WA
    2019 Cement Crewmax TRD OffRoad
    My build- https://www.tundras.com/threads/rabbidllamas-old-man-build.80802/
    After doing the DIY under back seat mod, I wanted some more storage behind the back seat to store Things like hats, gloves, etc. I like the Tactical look but did not like the price. Bought this cheap behind the seat storage and will try it out. I can add extra pounches and things if needed.
  26. Jan 12, 2020 at 11:44 AM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
    Did this a couple weeks ago but here are the pics as promised
    Cut up my organizer to fit
    Added a tray for more storage that doesn’t need to be locked up
    Joss1799, Keoki_m, equin and 7 others like this.
  27. Jan 12, 2020 at 11:53 AM
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    Like the grille with the raptor lights. How did you paint the bulge? Or did you buy an OEM bulge that color which matched the grille surround?
  28. Jan 12, 2020 at 11:59 AM
    Bob_Wiley
    Bob_Wiley I feel good, I feel great, I feel wonderful...
    Eric
    AZ
    2016 Black SR5 Crewmax 5.7 FFV
    That looks awesome!
  29. Jan 12, 2020 at 12:14 PM
    ARMYGREEN
    ARMYGREEN New Member
    2014 CrewMax MGM
    Out with the old Reese and in with the new Tekonsha P3 with the ESP Truck Accessories Mounting kit
  30. Jan 12, 2020 at 12:19 PM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    Used SEM Trim Black to paint my side view mirrors. Turned out nice, look brand new.:thumbsup:
