Driveshaft
Discussion in '1st Gen Tundras (2000-2006)' started by FedEx man, Jan 11, 2020.
Drive shaft problem
  1. Drive shaft
    8 vote(s)
    44.4%
  2. Drive shaft
    10 vote(s)
    55.6%
  1. Jan 11, 2020 at 3:36 PM
    FedEx man
    FedEx man [OP] New Member
    06 sr5
    Drive shaft problem
  2. Jan 11, 2020 at 4:29 PM
    Tiamat
    Tiamat New Member
    2015 tundra crewmax xp
    Not a problem, but I can feel the vibration from carrier bearing. Wish the Had a one piece.
  3. Jan 11, 2020 at 4:40 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    I too, have a driveshaft.
    bmf4069, hagrid, FirstGenVol and 2 others like this.
  4. Jan 11, 2020 at 5:02 PM
    Aerindel
    Aerindel New Member
    Montana
    I have two of them.
    bmf4069, lsaami[QUOTED] and VRC like this.
  5. Jan 11, 2020 at 5:03 PM
    Aerindel
    Aerindel New Member
    Montana
    Usually you can't, usually its something else, like a U joint.
  6. Jan 11, 2020 at 5:14 PM
    Outbound
    Aaron
    Northern Alberta
    It's not a driveshaft problem. It's a lug nut problem. Check the 4th lugnut clockwise from the top on your driver side.
  7. Jan 11, 2020 at 5:44 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Front or rear tire? :notsure:
  8. Jan 11, 2020 at 5:45 PM
    The poll is neck and neck. We need more data to pick a clear winner.
  9. Jan 11, 2020 at 5:46 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    :smack:drive shaft duh. The ones who picked driveshaft are wrong.
  10. Jan 11, 2020 at 6:19 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Tie broken
  11. Jan 11, 2020 at 6:20 PM
    empty_lord
    05 rollover special
    Only 2?
  12. Jan 11, 2020 at 6:33 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Driveshaft has pulled ahead to a commanding lead!
  13. Jan 11, 2020 at 6:33 PM
    War Machine
    War Machine SSEM # 5 3MW
    You pulled a head?
  14. Jan 11, 2020 at 6:39 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Once... on a 5hp Briggs 'n Stratton.
    It was meh.
  15. Jan 11, 2020 at 6:42 PM
    War Machine
    Don’t give up on it
  16. Jan 11, 2020 at 6:50 PM
    Aerindel
    Aerindel New Member
    Montana
    I think the others are technically axles.
  17. Jan 11, 2020 at 6:53 PM
    Dog
    Dog sit!
    Rocky Mountain high...
    2006 SR5 AC 4x4 TRD-OR
    Nope, no driveshaft problem here. Mine is still firm and straight, and doesn't make any noises.
  18. Jan 11, 2020 at 6:53 PM
    empty_lord
    05 rollover special
    They are a shaft that drives
    They’re technically called half shafts.
    speedtre likes this.
  19. Jan 11, 2020 at 7:30 PM
    Outbound
    Aaron
    Northern Alberta
    Front. Unless you have a truck with the opposite set up, in which case the front lug nut you need is actually the rear lug nut except it's 4 nuts counter clockwise from the nut at the 90 degree position.
  20. Jan 11, 2020 at 7:35 PM
    AZTundra
    Paul
    Phoenix, AZ
    Is it true you can place a tire iron on the lug nut in question and drive the truck forward to break it loose or should OP reverse to break it free?
    jewsNbrews likes this.
  21. Jan 11, 2020 at 7:36 PM
    Outbound
    Aaron
    Northern Alberta
    Definitely forward. It's a reverse threaded nut.
    jewsNbrews and AZTundra[QUOTED] like this.
  22. Jan 11, 2020 at 7:36 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Vote changed after some serious contemplation. It's back to a tie.
  23. Jan 11, 2020 at 7:38 PM
    Pudge
    CT
    Mine is kinda bent and makes some odd noises at times, mostly when it gets wet.
  24. Jan 11, 2020 at 7:54 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
  25. Jan 11, 2020 at 8:03 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    The gap is narrowing but driveschäft is still the Tundra.cum öberstürmführer!
