The weekend has arrived; bought my first Tundra!
Discussion in '1st Gen Tundras (2000-2006)' started by MrAristo, Jan 10, 2020.
  1. Jan 10, 2020 at 7:14 PM
    MrAristo
    MrAristo [OP] Hounty Bunter
    South FL
    ‘01 4X4 Limited TRD
    Did this instead hehe
  2. Jan 10, 2020 at 7:22 PM
    MrAristo
    South FL
    ‘01 4X4 Limited TRD
    Appreciate this for sure man. I’m honestly thinking of doing most of the maintenance and suspension stuff before I even decide to mess w the body. I’ll see about sanding or remove the rust spots throughout and hopefully paint it up within a year or so.
    mcharfauros and 02goes[QUOTED] like this.
  3. Jan 10, 2020 at 7:24 PM
    MrAristo
    South FL
    ‘01 4X4 Limited TRD
    So I called a local dealership and basically said I have 2 open recalls, both regarding rusted frame/chassis. Going in once I get my primary car back and they’re gonna do inspection. Here’s to hoping I can get this baby a new frame :amen:
  4. Jan 11, 2020 at 4:30 AM
    Trigger
    Trigger New Member
    Butch
    Savannah, Ga.
    2006 Tundra Double Cab
    Bilstein B8 5100 shocks and struts
    My two cents are echoing others here but with MORE emphasis: TIMING BELT FIRST! If you can't positively verify that belt has been replaced in the last 50,000 miles on the official Toyota owners website or other "Official" records it should be your first and main concern. Really!
    mcharfauros and speedtre like this.
  5. Jan 11, 2020 at 7:43 AM
    speedtre
    speedtre New Member
    Inland Northwest
    Inspect it yourself THOROUGHLY first....and research Toyota's position on what condition leads to what action on their part so you can manage your expectations/actions.
    Hopefully your inspection shows nothing, but if it does show frame rust issues, you will know what to do to get the best outcome for yourself when you take it in...
    :thumbsup:
  6. Jan 11, 2020 at 5:05 PM
    MrAristo
    South FL
    ‘01 4X4 Limited TRD
    Theres some very minor rusting, guess it’s up to the dealership/Toyota’s super specific standards eh? Lord knows I’d love an entire new frame :bowdown: inspection in less than 2 weeks!
    speedtre[QUOTED] likes this.
  7. Jan 11, 2020 at 8:06 PM
    02goes
    02goes New Member
    2002 Tundra Limited 4X4
    Do your homework. Toyota is not going to give it to you if the frames not beyond iffy to their standard! Toyota is not on your side rooting for you. What's minor rusting on the frame to you? Surface rust, rust that chips off the frame with a scraper in certain places, rust that chips off and gives way to rust holes in the frame. Do a car fax to know if the trk lived in the snow or if it didn't!
    Now that you own it, get under there with a scraper to make holes in the frame due to rust because they're not going to do it for you! Remove the spare tire from underneath and look for rust hidden there. Look where suspension support is welded to frame for rust through or weakening.
    I can't believe people buy these 1st gen trks w/o doing their homework and learn to first inspect the frames for rust, and everything else under there. Toyota replaces the frame only, and not the other rusted out components below the body. Check the body mount frame attachments for rust through. If the body itself to frame is rusted through, good luck! Just like they will not replace a rusted through differential.
    Please show pics of everything rusted underneath if you can.
    speedtre likes this.
  8. Jan 12, 2020 at 5:55 AM
    MrAristo
    South FL
    ‘01 4X4 Limited TRD
    Trust me I made sure none of THAT was found before purchasing, I def appreciate the concern! There is no holes or flaking anywhere on the frame/chassis/diffWhere there is rust is the hood, and portions of the lower body by the wheel wells. After some research the vehicle was sold & originally owned in Missouri btw.. I’ll get photos later today. I’m still having Toyota inspect, well bc shit you never know.
    02goes[QUOTED] likes this.
  9. Jan 12, 2020 at 6:26 AM
    speedtre
    speedtre New Member
    Inland Northwest
    No harm in that...but if it's as described the best you will get is an offer of coating....which you don't want, IMHO.
    Regardless seems like you got a great deal, enjoy...:thumbsup:
    MrAristo[QUOTED][OP] and 02goes like this.
  10. Jan 12, 2020 at 9:19 AM
    02goes
    02goes New Member
    When you said "I'd love an entire new frame" I thought it's rusted through in places, and there was a chance Toyota would replace it.
    Good to hear the frame has no rust at all.
    MrAristo[OP] likes this.
