The weekend has arrived; bought my first Tundra!
Discussion in '1st Gen Tundras (2000-2006)' started by MrAristo, Jan 10, 2020.
  1. Jan 10, 2020 at 7:28 AM
    MrAristo
    MrAristo [OP] Hounty Bunter
    South FL
    ‘01 4X4 Limited TRD
    As promised I have went and purchased not only my first Tundra, but my first truck!! Was looking for a secondary vehicle for utility, hauling, fishing and some DIY fun, and after seeing a few I think I picked a good one ;)
    This baby is an 01 with 228k miles, Limited 4x4 with the TRD Off-road Package! Best part is I was able to scoop her up for just under $3k (SoFL market)... I’ll let you guys take a look and let me know what you think, also give me some recommendations on the BIG important first things to check/inspect. Can’t wait to get this journey started!
    B5640C0B-0D61-48A1-ADA5-8D9C7FB28CDF.jpg 34299FF8-6E4E-46FE-ADE8-1A4C17B91F5B.jpg B053CBE9-111D-4F2F-9B66-5777E719C2A2.jpg 40200E99-DDA5-40D1-B950-A657E364D879.jpg 72DC1A9B-5C5E-46DD-9D35-01DB06835F73.jpg 5A8EF85F-1FA1-493F-AA88-D6BA6ADC32AB.jpg A180DB6F-798F-4A0D-9020-0CDF1059B164.jpg 7AF83212-C4E0-49CE-A369-B79C95542183.jpg
  2. Jan 10, 2020 at 7:30 AM
    CNE0207
    CNE0207 New Member
    Arvada, CO
    2020 Cement CM Limited
    Nice!
    mcharfauros and MrAristo[OP] like this.
  3. Jan 10, 2020 at 7:33 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Congratulations!!!
  4. Jan 10, 2020 at 7:35 AM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Nice!
    A good deep detail and she will be looking great!
  5. Jan 10, 2020 at 7:38 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Nice and welcome.
    MrAristo[OP] likes this.
  6. Jan 10, 2020 at 7:45 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Sweet!
    Focus on the nuts & bolts concerning maintenance / service / safety and reliability.
    Clean it up the best you can, and install some seat covers like Wet Okole.
    Replace the headlight housings with new Toyota OEM housings, and enjoy the ride.
  7. Jan 10, 2020 at 7:45 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Nice and Welcome to the party!!!
    Based strictly on what i see, headlights and tires would be the 1st thing i tackle. Seats a little torn a seat cover, since being used as a utility vehicle. Otherwise id say invest in some Katskinz seats.
  8. Jan 10, 2020 at 7:48 AM
    Good looking truck (looks just like mine, ha). I've never seen a used first gen tundra without a dented rear bumper! Mine came with both front and rear dented. I pulled them both, hammered them out best I could before i sanding, etching primer, and covered them with spray on bedliner. Things to inspect / replace:
    Timing Belt / water pump
    Ball joints
    CV axle boots
    rear drive shaft U joints, carrier bearing, lube
    rear drum brakes / adjustment (these came with an auto adjuster that they decided was ineffective. There is a newer version you can swap in if the back brakes are ready for replacement.
    Spark plugs
    I would flush the brake fluid, steering fluid, coolant (when you do your timing belt is a good time)
    Obviously oil change. I use a high capacity Mobil one filter M1-301. That allows you to run 7.2 qts of oil.
    Headlights are horrible on these. New bulbs make a good bit of difference, if the lenses are cloudy, new headlight lenses are cheap on Amazon / ebay.
  9. Jan 10, 2020 at 7:52 AM
    Definitely flush that brake fluid and inspect those brakes. Your fluid looks like ink in the reservoir. Brakes are not a strong point on these. If you have to replace any front brake hardware, do the 03 and up caliper conversion.
  10. Jan 10, 2020 at 8:02 AM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    Welcome and congrats on your new rig!
  11. Jan 10, 2020 at 8:07 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    My thoughts exactly!
    Congrats on your purchase.
  12. Jan 10, 2020 at 8:08 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    Welcome. That sounds like a good deal. Keep up the maintenance and it will serve you well.
  13. Jan 10, 2020 at 8:14 AM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    Nice score. 1st gens are unstoppable
  14. Jan 10, 2020 at 8:20 AM
    02goes
    02goes New Member
    2002 Tundra Limited 4X4
    Good to hear you found your low cost all around beater for second vehicle. Rust mild, wild or none at all?
  15. Jan 10, 2020 at 9:52 AM
    MrAristo
    South FL
    ‘01 4X4 Limited TRD
    Definitely needs tires and alignment STAT. What would you recommend for tire size on stock setup, for a more full look?
  16. Jan 10, 2020 at 9:54 AM
    MrAristo
    South FL
    ‘01 4X4 Limited TRD
    This is great thank you! I’ll be having a nice weekend just looking over everything, doing some minor touches. This list will be a great reference for me to fall back on bud.
  17. Jan 10, 2020 at 9:56 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    I was mainly referring to an A/T tire, something thats gonna be a little more rugged. Good both on and off road. I prefer the BFG K02, Nitto Ridge Grapplers also make good tire.
    MrAristo[QUOTED][OP] likes this.
  18. Jan 10, 2020 at 9:56 AM
    MrAristo
    South FL
    ‘01 4X4 Limited TRD
    The hood has some rusting spots at the very front, some on the top outer lining for the bed. Any quick fixes for spots of rust? I’m going to also throughly check the frame out this weekend, any idea if Toyota is still honoring recalls? Not that I expect to need it, more for knowledge.
  19. Jan 10, 2020 at 10:14 AM
    02goes
    02goes New Member
    Don't let it rust through the metal by waiting a year or more for repair.
    Sand down the rust till removed, or bare metal, and primer over it to stop the rust from reoccurring.
    Spray can metal primer works good. Wet sand it till smooth and it's ready for paint. Get your trks paint code and go to a parts store and get a can of your color.
    If like my trks color and it's not available use the following place.
    https://www.automotivetouchup.com/s...MIj6OanYuY5gIVgobACh3ffwUFEAAYASABEgIGx_D_BwE
    From what I've read on this Forum, enter your VIN# on Toyota's site for recall info.
    If the frame is rusted through and they haven't done anything to it you might qualify for frame replacement.
    Hopefully others here will help you with that.
    https://www.toyota.com/recall
  20. Jan 10, 2020 at 11:19 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    First, you're gonna need some black paint... :monocle:
    jpink, bmf4069 and MrAristo[OP] like this.
  21. Jan 10, 2020 at 11:21 AM
    Fishin RGV-Trd Pro
    Fishin RGV-Trd Pro White is faster
    Alex
    RGV Texas
    2011 White Toyota Tundra Limited
    Nice ride!!! Congrats.
    :thumbsup:
  22. Jan 10, 2020 at 11:36 AM
    SC T100
    SC T100 New Member
    2005 Toyota Tundra Double Cab 4WD
    Rancho Quicklift/RS9000XLs, Rancho rear 1.5" blocks with RS9000XL shocks in rear, SuspensionMAXX extended sway bar links.
    Congrats! Run the VIN at the dealer to see if the lower ball joints have been replaced under a recall. If not, you should get them for free. Otherwise, pick up the lower ball joint kit and replace them. Easy job with a tie rod separator and some other basic tools.
    I'll also echo the timing belt/water pump service. Pricey at a shop but good for 90K. Then baseline the fluids.
  23. Jan 10, 2020 at 1:03 PM
    NoRcptn
    NorCal
    2017 Platinum
    Great truck. I replaced my headlights and bulbs from Amazon for about $40.00 each. It’s was a lot brighter at night.
  24. Jan 10, 2020 at 1:10 PM
    Luckydog
    Luckydog New Member
    Dominic
    2015 DC TRD Offroad.
    Ranch Hand Summit front and rear bumpers. Diamondback SE tonneau cover. Rigid DOT fogs. LED headlight/fog replacement bulbs. Matt Gecko hood, and bed LED's. Foot well led's, and interior LED buld replacement. (warm) Broke the front shock of the 3" spacer lift, so replaced with 6112/5160 and 1' block rear. KO 2's. Speaker replacement, added amp and (2) 10's under seat. Weathertech floor mats. Salex organizers. Ziebart undercoating. RCI front, transmission/diff, and gas tank skids received, waiting for spring install. Compustar remote starter. front/rear dash cam.
    Nice score!
  25. Jan 10, 2020 at 1:11 PM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    That thing is mint! Just hop in and drive
  26. Jan 10, 2020 at 1:51 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Short answer Yes, but it depends on a few things. Suggest you take a moment and check out @lsaami Early 1st Gen (2000-2003) Tundra Frame Replacement FAQ
    I'd also drop by your local Toyota dealer and inquire. There has been more than one recall for that year dealing with frame and cross member.
    lsaami likes this.
  27. Jan 10, 2020 at 5:50 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    That’s a really nice truck for 3 large. I have more than that into mine, plus a butt-ton of labor, and it still looks like a piece of garbage.
  28. Jan 10, 2020 at 7:11 PM
    MrAristo
    South FL
    ‘01 4X4 Limited TRD
    Sweet thanks for this! It’ll probably only be a couple weeks to a month till I get a set of beefier tires hehe..
  29. Jan 10, 2020 at 7:12 PM
    MrAristo
    South FL
    ‘01 4X4 Limited TRD
    For all that chrome eh?
    KarmaKannon and Darkness[QUOTED] like this.
  30. Jan 10, 2020 at 7:13 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    For all that... non-black stuff :rofl:
    Solid looking truck, congratulations on the find.
    MrAristo[QUOTED][OP] and bmf4069 like this.
