2019 5.7 trans cooler location
Discussion in '2.5 Gen Tundras (2014-2021)' started by jcop1, Oct 18, 2018.
  1. Jan 5, 2020 at 10:14 AM
    #481
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
  2. Jan 5, 2020 at 10:33 AM
    #482
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Any data on optimal operation temperature on WS fluid?
  3. Jan 5, 2020 at 12:02 PM
    #483
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
  4. Jan 5, 2020 at 12:34 PM
    #484
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
  5. Jan 5, 2020 at 1:17 PM
    #485
    timsp8
    NY
    202C = 395F and 214C = 417F.
    I think if anyone sees trans temps that high then their truck is on fire.
  6. Jan 5, 2020 at 1:51 PM
    #486
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    But it seems the WS would be able to handle the heat better than Valvoline full synthetic.
  7. Jan 5, 2020 at 2:55 PM
    #487
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    Flash point will have nothing to do with how well it handles heat - that comes down to the chemical breakdown of the fluids. There's too many additives in them and each company is coming at transferring heat in different ways. It would take real world use and data collection to determine which one is better - so which one breaks down less and which one protects metals the best.
    TTund16, Cpl_Punishment and sask3m like this.
  8. Jan 5, 2020 at 5:49 PM
    #488
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    What was the last year the Tundra had a standalone trans cooler 10 or 11?
  9. Jan 5, 2020 at 5:58 PM
    #489
    timsp8
    NY
    They changed it in mid 10 to be integrated with the ac condenser. I had a 2010 built in May 10 and it was integrated.
    sask3m likes this.
  10. Jan 9, 2020 at 5:14 PM
    #490
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    17' Tundra SR5, 12' Tacoma TRD offroad
    20% lower then a competitors truck without a cooler? Because both Chevy's I have owned ran way cooler then my Tundra ever did, my 17' Tundra was 176-186 on a normal day non towing. They took that cooler off on the 19's and 20's because they added other content people wanted like push button start and apple carplay, people were not asking for trans coolers or most there data shows a large % of Tundra owners don't tow so it got put in the cost cutting bin.
    WNY PAT and Cpl_Punishment like this.
  11. Jan 9, 2020 at 6:05 PM
    #491
    WNY PAT
    WNY PAT New Member
    Whats the least expensive way I can monitor trans temps on my 2019 and 2017? I’ll be pulling long hills several times this summer at or very near the tow rating of my trucks (2017 Limited CM / 2019 SR5 CM) taking my tractor, materials and some implants to my camp. I honestly really don’t care about the 2019 as it’s a 2 year 24K lease... so I’ll keep my foot in it until an idiot light comes on or I crest the hill. Then I’ll hook the same trailer up to my 2017 and run the same hill the next week and compare. I’m really wondering about this... how much difference there is temp-wise between the two identical transmissions that is.
    sask3m likes this.
  12. Jan 9, 2020 at 6:05 PM
    #492
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    I ran the Ultragauge on mine, worked well.
  13. Jan 9, 2020 at 6:20 PM
    #493
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    By a bluetooth obd2 and the obdfusion app for 5$.
  14. Jan 9, 2020 at 6:32 PM
    #494
    WNY PAT
    WNY PAT New Member
    Thx. That sounds perfect. Do you happen to have a link?
  15. Jan 9, 2020 at 6:37 PM
    #495
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    You should read the whole thread!
    OBD product link:
    https://www.amazon.com/KOBRA-Wirele...a-751691986698&psc=1&ref=&adgrpid=71715066929
    And get the app.... wherever you buy your app’s.
    I have an ‘18. My brother in law has a ‘19. We both have OBD fusion and the app mentioned above.
    My trans temps run up to 195 and then the thermostat opens and the temp drops into the 180’s immediately. Wash, rinse, repeat.
    My BIL’s temps raise and stay in the 225-230 zone without even towing. He is going to monitor while towing and probably report back.
    Now you don’t have to wonder! :thumbsup:
    WNY PAT[QUOTED] likes this.
  16. Jan 9, 2020 at 6:51 PM
    #496
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Its a phone app, download from your app store, go for the Pro version, much more features, it's only $5.
    Buy one of these and you are set: https://www.amazon.com/gp/product/B01HXGX8V6/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
    You will need to create the Trans TC and Trans Pan temperature templates, no big deal, just search on here for the formula/parameters. All other engine values can be read by the app/device straight out of the box.
    Luck and enjoy those Toyotas. : ^ )))
  17. Jan 9, 2020 at 7:08 PM
    #497
    WNY PAT
    WNY PAT New Member
    Thx gang. Ordered one just now. Will report my temps. If I am starting up a long hill with 8,500 pounds behind me at 225-230... I gotta imagine I’ll be seeing 250-260 at the top.
    panicman likes this.
  18. Jan 9, 2020 at 8:46 PM
    #498
    Jtundra81
    Jtundra81 Just a member
    Joe
    2019 cement tundra crewmax
    Let us know what you get, I towed last summer around 5000 lb travel trailer , I averaged 215 and that towing on S4 with tow haul on and around 55 to 60 mph , going through hills , climbed between 217 and 220 , saw up to 238 on torque when slowing down in traffic and on toll and goes down after a few . That was consistent for the 6 times I towed with it
  19. Jan 15, 2020 at 4:54 PM
    #499
    99SSCam
    99SSCam New Member
    Dave
    19 Tundra SR5 TRD
    none
    Hey new member here. Just thought I would add my thoughts on this subject. I read a lot of the posts regarding The 19/20 Tundras not having the traditional external transmission cooler that we all know and love. I got to say I feel like it should have one...However. If Toyota Says its ok. Then I will put a little faith in Toyota. The Toyota reputation is 100% built from the reliability of their vehicles and would not remove something to compromise that. The Tundra is a low volume truck so I don't believe that if they were trying to increase profit margins...I don't think they would start with the transmission cooler. Of course everything I am saying could be wrong and they could have done it to save a few pennies. The transmission cooler i'm sure doesn't cost Toyota much to manufacture. So why remove it at the risk of compromising reliability? I want to believe I'm right because I am sick of the other brands...that's why I got a Tundra. Don't let me down Toyota. Your my last Hope.
    Dallas007 likes this.
  20. Jan 15, 2020 at 5:26 PM
    #500
    WNY PAT
    WNY PAT New Member
    Will do - when I have time I’ll download the app - I received the OBD-2 the other day. I don’t see much point in measuring temps now but I am towing almost every day with my 2019. With outside temps in the teens, 20s and 30s I can’t imagine I’ll see higher temps... but I guess it’ll be a good baseline.
    Jtundra81[QUOTED] likes this.
  21. Jan 15, 2020 at 5:57 PM
    #501
    Jtundra81
    Joe
    Here is the formulas you need to configure to read the sensors with the torque app
  22. Jan 15, 2020 at 6:27 PM
    #502
    WNY PAT
    WNY PAT New Member
    Maybe I’ll need the weekend to sort this out. lol I thought I’d just download the app and *kapow* the trans temp would be one of the outputs. :)
  23. Jan 15, 2020 at 6:29 PM
    #503
    WNY PAT
    WNY PAT New Member
    Question - is it the torque obd2 app? Or just the torque app? Thx.
  24. Jan 15, 2020 at 6:33 PM
    #504
    Johnsonman
    Austin
    Sequoia
    There's Torque Lite and Torque Pro, free and $5 - go with the Pro, lots more features.
  25. Jan 15, 2020 at 6:34 PM
    #505
    Jtundra81
    Joe
    Lol , It is not that hard to add the pid, here is the app I use
  26. Jan 15, 2020 at 6:42 PM
    #506
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
    Obd Fusion is also an option. You can purchase the enhanced pid for your vehicle for $9.99 which will include the temp sensors for trans and tc.
    WNY PAT likes this.
  27. Jan 15, 2020 at 6:52 PM
    #507
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
  28. Jan 16, 2020 at 3:38 AM
    #508
    timsp8
    NY
    Higher psi caps supposedly only raise the boiling temp. They don’t reduce overall temp.
  29. Jan 16, 2020 at 7:18 AM
    #509
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Will this work on the 19-20 to read the TC temps? the 19-20 use a different ecu and it's been a challenge to get a pid to read the TC.
  30. Jan 16, 2020 at 7:33 AM
    #510
    jtwags
    League City, TX
    2018 Tundra CM
    Appears it supports 2019 based on what is available. Could always email them. I imagine the purchase is refundable within first 24hrs if it indicates it will work but doesn't. I also have Torque Pro with the custom pids added but i tend to use Obd fusion more when towing. Here is my obd fusion layout
    TTund16 likes this.
