Intake question
Discussion in 'Performance and Tuning' started by PyroTitus, Jan 9, 2020.
  1. Jan 9, 2020 at 5:49 AM
    PyroTitus
    PyroTitus [OP] New Member
    Thomas
    2015 Orange Tundra TRD PRO
    So I have the 4.6l, bought a k&n intake for it but when I received it it says it's for the 5.7l. I checked multiple times and it said it would fit, my question is has anyone put the 5.7l intake on the 4.6l? Dont want to have to go through the hassle of returnjng it and ordering another if I don't have to. Thanks
    Rica25 likes this.
  2. Jan 9, 2020 at 6:00 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Throw it on and see if it fits.
    Rica25 likes this.
  3. Jan 9, 2020 at 6:05 AM
    PyroTitus
    Thomas
    That's what I think I'll do, just didn't want to assemble it all if it doesn't work, you know?
  4. Jan 9, 2020 at 6:08 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Right. At least you'd have practice taking it on and off if you had to remove it!
    Maybe someone will chime in for sure though if it's interchangeable.
    PyroTitus[QUOTED][OP] likes this.
  5. Jan 9, 2020 at 6:09 AM
    timsp8
    NY
    Should be able to see if the tube lines up and is the same size without putting it all together and mounting it in the truck.
    PyroTitus[OP] likes this.
  6. Jan 9, 2020 at 6:18 AM
    PyroTitus
    Thomas
    The install guides are the same, gonna test fit the intake tube, if that fits I don't see why it would be an issue.
  7. Jan 9, 2020 at 7:48 AM
    15whtrd
    15whtrd Mr. Blonde
  8. Jan 9, 2020 at 7:59 AM
    PyroTitus
    Thomas
    It is the same part number, at least for the TRD intake. Thanks man!! Btw I used to work for Toyota of cool springs , good people there!
    15whtrd[QUOTED] likes this.
  9. Jan 9, 2020 at 8:13 AM
    15whtrd
    15whtrd Mr. Blonde
    One of our members here runs the parts site. Probably the best prices you can get on OEM parts.
    @Roman
    Roman likes this.
  10. Jan 9, 2020 at 12:13 PM
    PyroTitus
    Thomas
    Fit perfectly, sounds great. Thanks everyone
  11. Jan 9, 2020 at 12:15 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Looks good! Glad it all worked out.
  12. Jan 9, 2020 at 12:19 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Looks great!
    Question, is this still considered CAI? I am thinking with the shroud it would be for the most part, still pulling air for the fender opening. Does the shroud come in contact with the hood?
    15whtrd likes this.
  13. Jan 9, 2020 at 1:41 PM
    15whtrd
    15whtrd Mr. Blonde
    Well, I had one of those intakes on a couple of vehicles. The contact with the hood is not that great. They sell it as a CAI. But after many years of using them on my previous vehicles. I came to the conclusion that, ultimately, they end up sucking in hot air from the engine compartment instead of the fender. They definitely make more noise which is cool, but when watching the IAT On a DashBoss that I had, the IAT’s were hotter than stock thr intake when I compared them. This was on a Chevy, but same principle applies. I’ve grown to like a closed box that leads to the fender. The open air box sealed against the hood wasn’t as effective as I thought it would be. On some of my older vehicles the airbox was quite small so the K & N seemed like an upgrade. At the track the K&N seemed to do well as long as I let the car cool off between passes. Once the engine compartment is heat soaked, it wasn’t as good as stock. Make sense?
    Not to shit all over what the OP is doing. It may work out great for him. But I started to feel like it was more of a hot air intake LOL on my last car. If I ever do anything with this trucks intake system, it will be a closed box and only pull from the fender.
    Trooper2[QUOTED] likes this.
  14. Jan 9, 2020 at 2:31 PM
    Trooper2
    JR
    Makes perfect sense. Thanks!
  15. Jan 9, 2020 at 4:17 PM
    PyroTitus
    Thomas
    It's not a completely flush seal, but I can feel a difference in the acceleration
