  1. Jan 8, 2020 at 1:54 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Jiggle those wires around and make a few sparks. Zzztttt!
    bmf4069[QUOTED] likes this.
  2. Jan 8, 2020 at 3:44 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I had those on mine and actually removed them because they caused more of a whine at freeway speeds.
    Outbound[QUOTED] likes this.
  3. Jan 8, 2020 at 4:18 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I doubt it's the truck battery. You'd have bigger issues than just presets going away. Are you still stock radio or aftermarket. If aftermarket then you probably have a wire messed up in the harness that didn't get plugged in or go crimped to an ACC (red wire) and not a constant (yellow wire).
  4. Jan 8, 2020 at 4:19 PM
    Pulled up the carpet and added some Noico to the drivers side floor today. Did the back of the kick panel as well. Still have a mountain of this stuff left for the Rav4 this weekend.
  5. Jan 8, 2020 at 4:20 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    I picked up a norcold fridge. I've been trying to get it for a month or so and I couldn't pass it up. It kinda fits right here if I take the handle off. I need to see if I can remove some plastic trim from the seat to get an extra .5" so make it not compress my door panel.
  6. Jan 8, 2020 at 4:21 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    you guys buying this noico off Amazon or what?
    Bulldog_tundra likes this.
  7. Jan 8, 2020 at 4:33 PM
    You could fit a 6 pack of bee....or soda in there.
    SC T100, bmf4069, Darkness and 3 others like this.
  8. Jan 8, 2020 at 4:39 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    yes Toasty, anything you wanna keep cold :rofl:
  9. Jan 8, 2020 at 4:39 PM
    KarmaKannon
    Utah
    Some junk
  10. Jan 8, 2020 at 4:40 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
  11. Jan 8, 2020 at 4:41 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    Road sodas :burp:
    bmf4069 likes this.
  12. Jan 8, 2020 at 4:41 PM
    KarmaKannon
    Utah
    Some junk
    I think that's how much I used just on my 4 doors.
    CodyP[QUOTED] likes this.
  13. Jan 8, 2020 at 4:43 PM
    I bought 36 sq ft for $65 from eBay with free shipping. 10 sq ft might be enough. You could always start with that.
  14. Jan 8, 2020 at 4:46 PM
    imDementeD
    imDementeD New Member
    2003 Tundra Limited 4x4 Trd Supercharger
    I received my Coastal bumper today. Crazing seeing (3) fairly small packages knowing what it will become. Also, "received" my Baja design lights...or so I thought. UPS shows delivered in Catlett, VA..which is cool but I'm in Florida...so that's probably why I Amazon over eBay nowadays...
    speedtre and FrenchToasty like this.
  15. Jan 8, 2020 at 5:04 PM
    It’s impressive what flat steel can become with some know how and a good eye ball!
    NUDRAT and imDementeD[QUOTED] like this.
  16. Jan 8, 2020 at 5:15 PM
    bmf4069 Captain wtf
    Battery shows 12v when not running.
    Come on now! I ain't no rookie!
    Still rocking the factory radio!
    So I went out to check it. It showed 12 volts when off, and the radio was still on the last station i had it on. I started the truck and it gave a tiny struggle and started right up. Truck hasn't been driven since sunday, but it'll do it after sitting overnight. It doesn't do it while driving with multiple stops in one day. Weird.
    Truck off.
    Running
  17. Jan 8, 2020 at 5:54 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    You need to see what it's putting out while cranking though. A tester on the battery terminals will give to that, should be 12.6 with the truck off, 13.6-14.6 while running, and shouldn't drop below 10v while starting.
    Bulldog_tundra, speedtre and CodyP like this.
  18. Jan 8, 2020 at 6:23 PM
    bmf4069 Captain wtf
    Gotcha. I'll get a helper and try it again.
  19. Jan 8, 2020 at 6:28 PM
    jImmegart
    Jonah
    California
    2003 Tundra TRD Sport
    when you put them on the door, do you do the inside of door panel or on the door over the plastic protector?
  20. Jan 8, 2020 at 6:34 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    If you’ve got a DMM you can put it on the min max setting.
  21. Jan 8, 2020 at 6:55 PM
    KarmaKannon
    Utah
    Some junk
    The inside of the metal outer door skin. So the inside of the door part you see from the outside of the vehicle.
  22. Jan 8, 2020 at 7:18 PM
    jImmegart
    Jonah
    California
    Did you just pull back the plastic protector?
  23. Jan 8, 2020 at 7:20 PM
    KarmaKannon
    Utah
    Some junk
    Yeah it's just held on by butyl so you can peal it off and re-stick it back on. I think I pulled it and maybe used a razor to cut the butyl as I pulled. It resealed no problem.
  24. Jan 8, 2020 at 9:41 PM
    bmf4069 Captain wtf
    I've got a fluke t5-1000 and a Klein something clamp meter. I'll bust the Klein out since it's a bit "fancier".
  25. Jan 8, 2020 at 10:17 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    so you guys are putting the noico on the inside of the outer most metal of the door? Not inbetween the door panel and door sheet metal?
  26. Jan 8, 2020 at 10:30 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Both rear cam bolts are stuck. Looks like I’ll get to cut shit tomorrow. Even ye old hammer of pneumatics couldn’t budge it
    also that Napa axle looks rusty and bugs me.
    Need to find a inner joint for my original axle so I can put the good Toyota one back on.
    ESTundra937, Darkness, lsaami and 3 others like this.
  27. Jan 9, 2020 at 3:14 AM
    KarmaKannon
    Utah
    Some junk
    Inside of the outer most door skin is where I put it. I think that's what others have done too. It was my understanding that this was the normal place to put it. I could have been mistaken though.
  28. Jan 9, 2020 at 3:19 AM
    I did both. If you go on their website they have instructions that help. Here is what I gathered. You don't have to cover every sq inch. But the more you use the better it works.
    Here is behind the speaker on the rear door.
    And on the front doors you can put a lot in between the sheet metal and the actual exterior door metal. Had I know I would have this much left over I would have used more.
    Do a search here and you can find more pics.
    https://www.tundras.com/threads/my-2016-tundra-cm-stereo-system-install.47810/#post-1243156
    https://www.tundras.com/threads/sound-matting-worth-it.22604/
  29. Jan 9, 2020 at 4:08 AM
    Fred
    Hand Protectors
    I didn’t go to MIT, but can give you some advice that may help.
    Try doing all 4 door surfaces. In other words: The two inside metal walls cavity, the outside metal that the door panel attaches, and also the backside of the door panel. Doing this dampens all the surfaces instead of one surface. You don’t need to cover every square inch doing all 4 surfaces as the totality exceeds just doing one surface.
    Yes. You can cover over the plastic film as well.
    Throw some scraps of water proof foam in there. I used stuff from delivery boxes. Make sure it sheds water. You can use the other non-waterproof foam inside the cabin behind backseat or kick panels.
    FrenchToasty and bmf4069 like this.
  30. Jan 9, 2020 at 4:14 AM
    Fred
    Hand Protectors
    I did all four (4) surfaces using 25-50% coverage per surface.
    See my above statement about using foam.
