Change of ownership check list
Discussion in '1st Gen Tundras (2000-2006)' started by sixteen2nd, Jan 7, 2020.
  1. Jan 7, 2020 at 6:01 AM
    sixteen2nd
    sixteen2nd [OP] Shadetree Mechanic
    2003 White Tundra Access Cab TRD
    New to the forum and new to Tundra ownership. I recently bought a 2003 Tundra Access Cab TRD with 212,000 miles that needs some work. Thankfully I don't need this to be my daily driver (yet) so I have some time to work on it. Here is my plan, I'd love your feedback/input/advice:
    1. Change engine oil and filter (5w-30 non-synthetic)
    2. Change differential oil (75w-90 full synthetic)
    3. Change transfer case oil (75w-90 full synthetic)
    4. Change timing belt and water pump (Aisin kit)
    5. Change radiator (Denso) - (I had a 2001 Sequoia that died due to pink milkshake so I may also add a transmission cooler)
    6. Change coolant
    7. Change valve seal
    8. Change spark plugs
    9. Replace gauge cluster lights with LED (some are burnt out anyway)
    10. Fix power steering (master cylinder?)
    11. Bleed break lines (they are currently very soft)
    The truck had the frame replaced with the recall so I've got that going for me ;-)
    The previous owner only owned it for a year or so and had no maintenance records.
    Anything else I'm forgetting for "change of ownership" maintenance? Should I do the transmission oil too?
    Thanks!
  2. Jan 7, 2020 at 6:25 AM
    Welcome from NY.
    Maybe change bulbs to LED's for better lighting.
    Pinay likes this.
  3. Jan 7, 2020 at 6:36 AM
    speedtre
    speedtre New Member
    Inland Northwest
    I would do a 3-4x transmission drain and fill on yours since the A340 is so easy to do. Also, adjust your parking brake and rear drums and rear proportioning valve in addition to the bleeding...those are more likely the culprit for soft brakes than air in your system. Grease the entire drive train as well. And welcome...:thumbsup:
  4. Jan 7, 2020 at 6:42 AM
    SC T100
    SC T100 New Member
    2005 Toyota Tundra Double Cab 4WD
    Rancho Quicklift/RS9000XLs, Rancho rear 1.5" blocks with RS9000XL shocks in rear, SuspensionMAXX extended sway bar links.
    It's also time for the lower ball joints (and uppers if you feel like it). OEM only.
    They are a failure point if they let go (tire no longer connected to lower control arm) so changing them at that mileage is definitely a priority and is good for peace-of-mind.
  5. Jan 7, 2020 at 7:48 AM
    Sunnier
    Sunny
    San Diego, CA
    Sounds like you’re an able guy. Welcome from SoCal!
  6. Jan 7, 2020 at 3:41 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Clean MAF Sensor and Swap in a new PCV valve.
    Do a few drain and fills on the transmission as already stated.
    I use Zerex Asian 50/50 Coolant ($16/gal.) and Valvoline Dex/Merc ($14/gal.) for the transmission.
    You can get the Toy YZZZD-3 engine oil filters online for about $4-5 each in multi-packs.
    Do a few suck and fills on your Power Steering Reservoir using the Dex/Merc.
    I use the Mobil1 5w-30 Synthetic High Mileage in the engine.
    Replace the V-Belt with a Continental Brand ($20) if needed. Real easy stuff using a 14mm flex head ratchet on the tensioner.
  7. Jan 7, 2020 at 3:59 PM
    Fred
    Hand Protectors
    bmf4069 likes this.
  8. Jan 7, 2020 at 4:46 PM
    bmf4069 Captain wtf
    Change valve seal? As in a valve stem seal? If so you gotta pull the heads for that...
  9. Jan 7, 2020 at 4:51 PM
    Fred
    Hand Protectors
    Maybe he meant Valve Cover Gaskets?
  10. Jan 7, 2020 at 5:21 PM
    Check the carrier bearing. The rubber tends to rot out.
    You mentioned the frame was replaced so I assume you live in the rust belt. If you're going to drive it this winter consider protecting the new frame so it doesn't rust too.
    Fuel filter should probably be replaced.
    Since you mentioned the pedal is soft, how's your parking brake feel? You can take the slack out and it will help adjust your rear drums. Should help firm up the pedal a bit. Might as well inspect and clean your rear drums too.
    When you drain the coolant, there are to drain plugs on the bottom of the engine, towards the back. 10mm required.
    theblurry1 likes this.
  11. Jan 7, 2020 at 8:29 PM
    Aerindel
    Aerindel New Member
    Montana
    I would ad PCV valve,
    And adjust the parking brake. The parking brake automatically adjusts the rear brake shoes, but only if it itself is properly adjusted and functional.
    Grease your U joints (if you have grease-able joints)
  12. Jan 7, 2020 at 10:58 PM
    johnvan
    johnvan OG
    john
    Rensselaer,New York
    2016 inferno SR5 DC
    If The frame was replaced for the rust issue, check the condition of the rear end housing. They also had rust issues also.
    good luck, john
  13. Jan 8, 2020 at 5:22 AM
    sixteen2nd
    You are correct, I meant valve cover gaskets. Still getting a hang of this ;-)
  14. Jan 8, 2020 at 5:25 AM
    sixteen2nd
    The rear end housing does look "wet" so once the weather gets nicer and I can do more work on the truck I'm going to inspect it for pin hole leaks. I'm hoping it was just an over eager tech refilling it at some point recently, or maybe just a few minor pin holes that might be sealed with JB Weld. If it is major I'll probably come back to the forums for advice on replacing the cover or getting a new rear end from somewhere south of Tennessee.
  15. Jan 8, 2020 at 10:08 AM
    bmf4069 Captain wtf
    You got a pic of it? If it's wet but not under the fill plug then it's probably got holes. There's a weld on cover that others have used. I'm not well versed in this "rust" thing everyone keeps going on about.
  16. Apr 23, 2020 at 6:56 PM
    sixteen2nd
    Now that the weather is getting nicer here in the northeast, and I found room in my garage, I placed a $550 order with RockAuto! Timing belt kit, radiator, serpentine belt, rack and pinion seal kit, etc!
    Also, a buddy at work agreed to help me weld on the replacement rear diff cover. He did the same thing to his wife's 2005 Tacoma.
    Pucks18 and speedtre like this.
