2018+ LED HEADLIGHTS PLUG N PLAY HARNESS FOR 2014-2021 MODELS [V 2.0]
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by iHacker, Apr 21, 2018.
  1. Dec 15, 2019 at 8:22 AM
    #781
    thetwood
    thetwood New Member
    Louisville, CO
    2017 Blazing Blue Limited CrewMax TRD
    Kings, SPC, Icon Six Speed, Falken Wildpeak AT3w
    Finished install of 2019 TRD Pro headlights into my 2017 Limited yesterday. Used the harness with dimming. I did not purchase a terminal extractor and wish I had. After trying needles, pins and other assorted things, I ended up just cutting the grey wire and soldering into the harness... Live and learn.
    I of course forgot to set me old headlights to 0 before the install, so it seems to be off between the old and new. Still able to adjust, but any advice for getting them back in original sync?
    Firewurx likes this.
  2. Dec 15, 2019 at 11:37 AM
    #782
    iHacker
    iHacker [OP] SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    Check this from my original post
    thetwood[QUOTED] likes this.
  3. Dec 16, 2019 at 4:03 PM
    #783
    Firewurx
    Firewurx New Member
    Andy
    Greenville, PA
    2018 Midnight Black SR5 Double Cab Daily-Deer-Getter
    Remote starter added. 20” Platinum Wheels
    Doing my install right now. I set my height to 0 and marked a sheet of plywood. Hope they’re gonna be good. Threw on those 20” Platinum wheels yesterday too. It’s all coming together now.
  4. Dec 16, 2019 at 5:19 PM
    #784
    Firewurx
    Firewurx New Member
    Andy
    Greenville, PA
    Success! Now to put it back together.
    I noticed my lights were about 4 clicks higher. Lowered the dial to 2 below to align with the marks I made before removal.
    thank you @iHacker !!
  5. Dec 18, 2019 at 6:54 AM
    #785
    paradizecityz
    paradizecityz New Member
    Richmond, TX
    2022 Tundra TRD Off Road
    Do most people get the normal dimming or non dimming version? I'm still debating between the 2...
  6. Dec 18, 2019 at 10:00 AM
    #786
    TOYOTRD8
    TOYOTRD8 New Member
    Utah
    2017 TUNDRA SR5 TRD OFF-ROAD
    TRD Pro Grilled, Color match bumper end caps, OEM LED headlights, MX4 Bed cover, GoRhino RB20,TRS LED Fog Lights, Camburg leveling kits, SR8 wheels, STT Pro tires 295/70/18 and heritage decal.
    Depends on what you like but I did mine non dimming since I’m not handy with electrical wires stuffs.
    paradizecityz[QUOTED] likes this.
  7. Dec 18, 2019 at 10:16 AM
    #787
    iHacker
    Mario
    ^ Like he says, this depends on what you like to have the DRL to work, if you are ok with electrical wiring I recommend you the full harness (dimming option) but if you don’t like to be around wires non dimming is recommended I promise you don’t have to cut or cause permanent damage to a single wire everything can be reverted to factory state of you follow the instructions correctly.
    The most popular option is the dimming harness
  8. Dec 18, 2019 at 10:20 AM
    #788
    iHacker
    Mario
    Ohhh I just saw your message and noticed your truck is a 2019 that means you don’t have to worry about dimming or non dimming harness in your case you only need the plug and play harness and they’ll dim as it should, your truck already comes with LED DRL and the dimmer is already installed in your truck
    Ketchumj likes this.
  9. Dec 18, 2019 at 10:20 AM
    #789
    paradizecityz
    Richmond, TX
    Thanks!!
    iHacker[QUOTED][OP] likes this.
  10. Dec 18, 2019 at 10:21 AM
    #790
    iHacker
    Mario
    Anytime buddy,
    Have a nice day
  11. Dec 18, 2019 at 2:07 PM
    #791
    ARMYGREEN
    ARMYGREEN New Member
    2014 CrewMax MGM
    Thank you @iHacker for the wire harness. Awesome!!!! Step by step instructions on here were great! Went fairly smooth. That dang rubber nipple going through the firewall is a pain to get to and cut.
    Thanks again.
    iHacker[OP] likes this.
  12. Dec 18, 2019 at 3:05 PM
    #792
    mcroyo
    mcroyo New Member
    COS
    2017 MGM SR5 Crewmax
    Finally warmed up a bit today and was able to do this. Piece of cake
    Firewurx and iHacker[OP] like this.
  13. Dec 18, 2019 at 3:48 PM
    #793
    RLHULK
    RLHULK Too many gamma rays in all that BBQ smoke.
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    After all the success @iHacker has had with his harness, I am surprised that dealerships are not beating at his door wanting to stock these as add on sales for Tundras.
    iHacker[OP] and easleycrawler like this.
  14. Dec 18, 2019 at 5:42 PM
    #794
    Firewurx
    Firewurx New Member
    Andy
    Greenville, PA
    seriously I was just thinking the same thing but I’m sure there’s liability mixed in there that they don’t want to have on their back.
  15. Dec 18, 2019 at 6:12 PM
    #795
    easleycrawler
    Travis
    Easley, South Carolina
    19 TRD SPORT CM MGM 4WD
    Or his. I wouldn't want that on me.
  16. Dec 18, 2019 at 10:49 PM
    #796
    RLHULK
    Rich
    2022 Silverado LT.
    Dealers install after market suspensions and tires and wheels among other items all the time, I doubt this would be any different.
  17. Dec 22, 2019 at 7:55 AM
    #797
    Alaska
    Alaska New Member
    2017 Tundra TRD 4x4 ~Quicksand~
    Baja Designs Squadron WC fogs
    Killer harness @iHacker and thanks for the rapid response to my questions along the way. The new lights are in and look fantastic! Huge difference from the stock 17's. Thanks again!
  18. Dec 22, 2019 at 6:56 PM
    #798
    9am53
    9am53 New Member
    adam
    2015 Black RCLB 4x4
    2020 PRO headlights and grill
    Hi, do you have any harnesses in stock and how much to ship to Canada?
    thanks
    iHacker[OP] and Y0TA PR0 like this.
  19. Dec 23, 2019 at 9:52 AM
    #799
    Alaska
    Alaska New Member
  20. Jan 1, 2020 at 11:53 AM
    #800
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    Since I have 17 Pro I need to buy LED dimming harness. I am not the best at wiring but I don't want to blind oncoming traffic. I assume that will happen if I don't get dimming harness. How hard is the install for dimming kit? Not good at wiring.
    I previously installed HR Supernova LED bulbs and the output was much better. Do the new LED headlights have better light output than my Super Novas. Here a photo of Supernova bulbs. As you can see there is some light scatter. I also noticed the light get absorbed on wet payment. Do the new LED have that problem. Really looking at switching over this time.
  21. Jan 6, 2020 at 5:45 PM
    #801
    socaltundra951
    socaltundra951 Gentlemen Prefer Black Tundras
    Southern California
    Black CrewMax 5.7
    I used the non-dimming harness and I've never been flashed. My neighbor has a 19 Sport and his DRL's are dimmer with headlights on but it's not too crazy.
    I see some cars out there (I'm looking at you, VW) that have DRL's that are practically spotlights they're so darn bright.
  22. Jan 6, 2020 at 6:31 PM
    #802
    cpc0812
    cpc0812 New Member
    Cory
    2018 Cement 4 X 4 CM
    I installed the pro headlights back in the middle of December with ihackers harness and absolutely love them. Everything was plug and play. Well worth it.0FA26E4E-9B3B-48D8-B318-D364D76D41C6.jpg366FB9CD-0C49-4342-8B06-47B7EE7BE046.jpg
  23. Jan 6, 2020 at 6:57 PM
    #803
    AZTundra
    Paul
    Phoenix, AZ
    Looks good! About to install mine very soon - ihacker harness is on it's way! Hope to complete my install over the weekend.
  24. Jan 9, 2020 at 4:24 PM
    #804
    AZTundra
    Paul
    Phoenix, AZ
    I'm about to install mine this weekend! Are most doing the Amber delete when installing?
  25. Jan 9, 2020 at 4:33 PM
    #805
    r8rs4lf
    r8rs4lf New Member
    Al
    Tree Juan Hoe
    2015 MGM SR5
    I'm doing mine this weekend as well and I'm leaving the amber.
  26. Jan 9, 2020 at 4:39 PM
    #806
    Azblue
    The Dirty T ( ^_^)_且
    Just my opinion, but it looks better with the amber delete and the dimming harness, more OEM.
  27. Jan 9, 2020 at 5:06 PM
    #807
    iHacker
    Mario
    Most people do the amber DRL delete, but this is totally up to you
    AZTundra[QUOTED] likes this.
  28. Jan 9, 2020 at 5:08 PM
    #808
    AZTundra
    Paul
    Phoenix, AZ
    I think this is the approach I'm going to take.
    iHacker[OP] and Azblue[QUOTED] like this.
  29. Jan 9, 2020 at 5:16 PM
    #809
    Azblue
    :thumbsup:
  30. Jan 9, 2020 at 5:18 PM
    #810
    alpinepro4
    Pat
    This the LED dimming harness or without? Looking at going without since I suck a wiring.
