  1. Jan 5, 2020 at 3:36 PM
    It’s not the same stiffness thru the entire bump. I’m not sure what direction it goes, but it handles small bumps and large bumps very well. Look up his videos for the Tacoma’s and 4runners.
  2. Jan 5, 2020 at 3:39 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    i believe its to help with trans temps because of how the transmission is designed to coast
  3. Jan 5, 2020 at 4:34 PM
    jImmegart
    Jonah
    California
    2003 Tundra TRD Sport
    I read this before I went to work and drove to work with OD off. I definitely feel like I coast less down hills with it off which helps with braking. I kinda like drive with it off, I always just left it on.
  4. Jan 5, 2020 at 4:34 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    My front bumps are custom cut down low squishymeter foam on the coilovers and whatever tight bypass valving fox did. Seems pretty good.
    We had our sled dogs crossing the sound moment today when the frozen mud started to thaw and we were miles away from solid ground. We pulled a nice pace of 40-50mph on very rutted and windy desert trails to get back to high ground.
    From this day to the ending of the world. But we in it shall be rememberèd. We few, we happy few, we band of brothers. Hahaha.
    Edit- If you've seen the new Disney movie Togo you might understand what I'm talking about. Very funny part of the movie.
  5. Jan 5, 2020 at 5:22 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
    Alright; finished the install this afternoon (decided to take a few days off from working on the truck). The problem was a bad choice in what I tapped into for ACC power for the mirror. I decided to use a fuse tap and used the CIG fuse.
    I still need to make some adjustments with the grid lines and such but otherwise its a wrap.
    New mirror on top
  6. Jan 5, 2020 at 5:33 PM
    abcinv
    Tommy
    NW Georgia
    Just to add a pic if anyone is looking for the inserts...
    Tohopko, oscardog86, bmf4069 and 3 others like this.
  7. Jan 5, 2020 at 6:05 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    that's them. They work like a charm and saved me from buying new sills.
  8. Jan 5, 2020 at 6:07 PM
    abcinv
    Tommy
    NW Georgia
    Me too, worked out great!
  9. Jan 5, 2020 at 6:17 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Considered that but I dont like the cluttered look. I'll sticker bomb spots that aren't visible 100% of the time, like the inner lid on tool boxes but not my fridge. I do have a big pile of stickers though.
  10. Jan 5, 2020 at 8:55 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    The inside of my tool box is nearly covered and my mini fridge is about 60% maybe
  11. Jan 5, 2020 at 10:45 PM
    empty_lord
    05 rollover special
    random question.... who thinks Gx470 seats will fit a tundra? hmm...
    nevermind. found my answer
  12. Jan 6, 2020 at 12:50 AM
    jImmegart
    Jonah
    California
    installed Dome, map, door, foot well, and glove box leds. I took the metal protectors out of the map lights and I think it over did it so I have them off when the doors opens. Now I have 15 t5 and t10 leds sitting around :(
  13. Jan 6, 2020 at 2:48 AM
    imDementeD
    imDementeD New Member
    2003 Tundra Limited 4x4 Trd Supercharger
    Assuming that was a no?
  14. Jan 6, 2020 at 6:32 AM
    empty_lord
    05 rollover special
    Yes
  15. Jan 6, 2020 at 6:33 AM
    empty_lord
    05 rollover special
    General rule of thumb the same as tacos when lifted, run a little more caster up front? Or just go factory spec. I’m going to align the truck tonight so I can hopefully get them close with the new arms at home.
  16. Jan 6, 2020 at 7:35 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    Yes as in they don't fit or yes as in they do.fit?
  17. Jan 6, 2020 at 8:27 AM
    empty_lord
    05 rollover special
    Don’t. Mounting points are different
  18. Jan 6, 2020 at 8:47 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Just roll that baby over again. Eventually they’ll fit.
    :itllbuffout:
  19. Jan 6, 2020 at 9:05 AM
    KarmaKannon
    Utah
    Some junk
    I think I'm running about 2.5* caster. Maybe stock was 1.5-2.5? Seems like 2-2.5 is a reasonable number, but I don't think as much as 3.5 would be bad handling. My prerunner is running about 5.5* and that's a little excessive.
  20. Jan 6, 2020 at 9:15 AM
    empty_lord
    05 rollover special
    I’m probably going to see how 2.5 is. My Tacoma I run 2.8. Seemed to work with no rubbing.
    KarmaKannon[QUOTED] likes this.
  21. Jan 6, 2020 at 9:15 AM
    I'm at 2.8 and it seems fine.
    speedtre and KarmaKannon[QUOTED] like this.
  22. Jan 6, 2020 at 9:22 AM
    KarmaKannon
    Utah
    Some junk
    I didn't care for the handling of my truck when I was running under 2*. Without a sway bar up front, around 1.5-1.75* caster, and stock rack bushings didn't produce the kind of feedback I want on the highway. It wasn't terrible but it did wandered more than I liked.
  23. Jan 6, 2020 at 9:40 AM
    This is probably a good time to ask. I've had 285's on my truck for around 6 months now. Initially I only rubbed the frame at full lock and the mudflaps. In the last month or 2 I've started rubbing the plastic. Safe to say my alignment numbers must have shifted somehow?
  24. Jan 6, 2020 at 9:43 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    That or your suspension has settled
    KarmaKannon likes this.
  25. Jan 6, 2020 at 9:45 AM
    empty_lord
    05 rollover special
    I’m more worried about clearance to the fender. Positive caster never bothered me as long as it wasn’t stupid excessive
    Big goal is make camber and toe in spec with even caster
  26. Jan 6, 2020 at 12:47 PM
    ESTundra937
    ESTundra937 All American Paratrooper
    Eddie
    San Diego
    2019 TRD Sport 4x4, 2003 SR5 Moto truck
    Finally buttoned her up. I have to remove some preload from the coilovers. It bounces way too much. Hopefully that helps, if not I'll be installing some Bilsteins. Fun project, learned alot from this one.
    Levy, hammeron, kodyquist21 and 8 others like this.
  27. Jan 6, 2020 at 1:04 PM
    ESTundra937
    Eddie
    San Diego
    New Akkon headlight assembly with Hikari LEDs really brightened up the front end too.
    Black steel bumper and grille swap is next, along with the side mirrors. Just gotta figure out if Im gonna paint or vinyl wrap the pieces. Swapping out the SCS F5s as well for some gunmetal versions. The dark bronze just ain't doing it for me. Those will be going on my father in laws LandCruiser.
  28. Jan 6, 2020 at 1:16 PM
    What's the connection here? Did ICON buy them out?
  29. Jan 6, 2020 at 1:26 PM
    ESTundra937
    Eddie
    San Diego
    That was my understanding. I didn't have any problems getn replacement shafts and seals when they were rebuilt by DSM.
  30. Jan 6, 2020 at 1:30 PM
    Whothefat
    Whothefat New Member
    Clark
    Las Vegas
    2006 Black Tundra DC 4x4
    I know this is talked about on several threads, but I’m ordering supplies to do diff/t-case fluid change... it sounds like most people use 75w90 in the rear but my owners manual calls for 75w140
    I’d rather buy all the same fluid in bulk.. any advice?
