Switch panel harness through grommet?
Discussion in '2nd Gen Tundras (2007-2013)' started by Rica25, Jan 5, 2020.
  1. Jan 5, 2020 at 6:59 PM
    Rica25
    Rica25 [OP] Got Bam? IG ......@TNDRA08
    Ricardo
    Tulare
    How are you guys running the connection for the switch panels thru the grommet on the firewall there is a small hole on the bottom but will not fit connection thru that small hole
  2. Jan 5, 2020 at 7:14 PM
    14CRWMX
    14CRWMX New Member
    Tampa Bay
    2014 SR5
    On driver's side in the mid height there's a rubber nipple through which you can run your wires
    Rica25[OP] likes this.
  3. Jan 5, 2020 at 7:16 PM
    Rica25
    Ricardo
    Tulare
    yes but that nipple is to small to run the harness with the connection that it has on the end its nearly half inch thick
  4. Jan 5, 2020 at 7:21 PM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    With my light bar I had to run the connector and wire under the grommet, not through it, then lots of silicone seal around the wire. If I had it to do over again I would de-pin the connector and put the wire through the grommet, re-pin the connector on the cab side.
  5. Jan 5, 2020 at 7:23 PM
    Rica25
    Ricardo
    Tulare
    that was my next option but did not want to do that and mess up the pins.......my harness is ran thru the side and everything is hooked up but did not want the harness to cut with time
  6. Jan 5, 2020 at 7:23 PM
    Rica25
    Ricardo
    Tulare
  7. Jan 5, 2020 at 7:25 PM
    Rica25
    Ricardo
    Tulare
    the harness is that very bottom piece where the two connections are at where the switch panel connects to the harness
  8. Jan 5, 2020 at 7:31 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    Take a blade and try to make the hole a bit bigger. Use some grease on the wire so it slides better.
  9. Jan 5, 2020 at 7:43 PM
    belanger9
    Edmonton, AB
    A bunch
    You should be able to get that connector through, mine was at least twice the size and I almost had it through. If my hands were smaller I'm pretty sure I would have gotten it through. Just cut a slice about an inch or so long in the grommet above that nipple.
  10. Jan 5, 2020 at 7:44 PM
    jojo8
    jojo8 New Member
    Drilled a hole left of the steering column, added a rubber grommet.
  11. Jan 5, 2020 at 7:49 PM
    TheBeast
    TheBeast The Beach
    smslavin likes this.
  12. Jan 5, 2020 at 7:52 PM
    Rica25
    Ricardo
    Tulare
  13. Jan 5, 2020 at 7:59 PM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    Toyotoholic and Rica25[OP] like this.
  14. Jan 5, 2020 at 8:09 PM
    TheBeast
    TheBeast The Beach
    yeah it's cleaner that a cutter or knife blade. You don't want to cut some wires. tool is cheap too.
  15. Jan 5, 2020 at 8:10 PM
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    Unpin the connector or cut a slit
    I had switch pros send me my harness unpinned so I could run it through the nipple below the main harness. Another reason I run a switch pro, I only gotta do this once.
    Rica25[OP] and TheBeast like this.
  16. Jan 5, 2020 at 8:24 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    Yeah I had about 12 wires + switch pro + NSV plugs... A lot!. I just slit the nipple and pushed through a snake. I use a classic HVAC ziptie. Build up a taper with 33+ e- tape to the lead wires, staggering them to help spread it out. Lube it up with lots of silicone spray and pull swiftly and smoothly, you can get just about anything through with good prep.
    I always check the grommet too after just to make sure it still a tight fit to the firewall.
    belanger9 and Rica25[OP] like this.
