Debadge help
Discussion in 'General Tundra Discussion' started by ToyoMafia, Jan 5, 2020.
  1. Jan 5, 2020 at 7:22 AM
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    So worked on de badge this am. Driver side went super smooth. Used power pro to take off emblem then scraped glue off with hairdryer and finger combo used carpro tarx then goof off then carpro eraser then finalized with elixer driver side turned out perfect. Then moved to the passenger side same exact process but I can still see where the emblem was. Any suggestions on how to go about the process to get the results I’m looking for. Will post pics in a min
  2. Jan 5, 2020 at 7:24 AM
    ToyoMafia
    Magic carpet.
    B3A6B613-16AD-4F7E-BED0-27DDD544A841.jpg ECD54574-1A3A-49B3-9CEA-A0D7DB66B2D8.jpg
    passenger side. You can see the difference of paint where emblem was. Hard to see but it’s there
  3. Jan 5, 2020 at 7:25 AM
    ToyoMafia
    Magic carpet.
    2ED7629F-7DA6-4F36-A511-9212D901154C.jpg Driver side looks great.
  4. Jan 5, 2020 at 7:29 AM
    Bassn429
    Bassn429 New Member
    I used 3m adhesive remover. Worked awesome and is safe for all surfaces. Got it from Napa. A little pricey but worth it
    ToyoMafia[OP] and JJcksn12 like this.
  5. Jan 5, 2020 at 7:40 AM
    ToyoMafia
    Magic carpet.
    Ok didn’t know if I should put a high speed buffer on it. Thanks for the input I will try that.
    Bassn429 likes this.
  6. Jan 5, 2020 at 7:41 AM
    ToyoMafia
    Magic carpet.
    It was a little odd the passenger side had water behind it didn’t know if that effected the paint at all.
  7. Jan 5, 2020 at 10:28 AM
    Sal_160
    Sal_160 New Member
    2019 Tundra Platinum
    On the similar subject, had anyone found the blackout for the Platinum?
  8. Jan 5, 2020 at 10:49 AM
    Beau De gustibus non est disputandum
    2008 Sequoia with a 2022 style
    As far as I know, it doesn't exist. I plastidipped mine. Came out pretty good.
    Sal_160[QUOTED] likes this.
  9. Jan 5, 2020 at 10:52 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    That's why I want all mine off. Only the door Tundra door emblems to go.
    Did you polish the area after?
  10. Jan 5, 2020 at 1:22 PM
    ToyoMafia
    Magic carpet.
    8F57B5A4-40DB-4637-86EA-B9A43ACFD430.jpg No I did not polish I used alcohol to clean then applied black tundras. Then I used car pro elixir to make it good again.
  11. Jan 5, 2020 at 1:24 PM
    JJcksn12
    JJcksn12 New Member
    Jay
    2025 MBM Limited TRD OR
    3” TRD Suspension Lift
    Same
    ToyoMafia[OP] likes this.
  12. Jan 5, 2020 at 1:26 PM
    JJcksn12
    JJcksn12 New Member
    Jay
    I’d try buffing it hoss, unless u were going to try the 3M adhesive remover first.
    jewsNbrews and ToyoMafia[OP] like this.
  13. Jan 5, 2020 at 1:26 PM
    ToyoMafia
    Magic carpet.
    FYI magic eraser is the sh*t for this project and make sure you use blue painters tape to mark your lines if you are putting on new emblems
  14. Jan 5, 2020 at 1:29 PM
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    Probably wouldn’t use a magic eraser on this.
    it’s essentially 5k grit sandpaper when wet
    JJcksn12 likes this.
  15. Jan 5, 2020 at 2:38 PM
    ToyoMafia
    Magic carpet.
    Well it worked well for me but I get it. I didn’t use much pressure it just got rid of the glue lines very easily.
  16. Jan 5, 2020 at 5:39 PM
    Mcoop
    Mcoop Throbbing Member
    Michael
    Berlin, NJ
    2015 Black SR5 5.7L DCLB 4x4
    I used bug & tar remover to remove the residual when my 4x4 emblem came loose. Washed afterwards and I could not tell where emblem was.
  17. Jan 5, 2020 at 7:14 PM
    FancyPants
    FancyPants Not my Husband’s truck
    Amber
    Oregon
    ‘19 SUPER WHITE Platinum Crewmax
    I had mine painted black at the Auto Body shop. But then I decided I like the look of it without my platinum badges better. So I never put them back on.
  18. Jan 7, 2020 at 4:21 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    I took mine off with a heat gun and some fishing line, then used the 3M stripe off wheel which works pretty well as long as the residue isnt too thick. As for that discoloration you have I also have a similar discoloring on mine, tried compounding and its still there but you can only see it under certain light, my guess is that it must have been caused by the adhesive since there us definitely no adhesive left there. Once it gets nicer out I'm going to polishing the whole truck with a new Dewault buffer I got, maybe that will take care of it.
    BravoDeltaRomeo likes this.
  19. Jan 7, 2020 at 4:24 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    It has a year of sunlight everywhere but where the badges where. To get rid of the ghost appearance it needs buffed out.
    On on old 4runner i had, i had to do the whole truck to get it all even and get rid of the ghost decals.
