Strange water leak...
Discussion in '1st Gen Tundras (2000-2006)' started by LovesLabs, Jan 4, 2020.
  1. Jan 4, 2020 at 12:36 AM
    LovesLabs
    LovesLabs [OP] New Member
    Frank
    2002 White Tundra
    none
    I seem to be leaking water from this "weep nipple" behind the engine on the cab wall on my 2002 Tundra, V8. Any ideas of where it is coming from? I have attached a picture.
    Thanks for looking!
  2. Jan 4, 2020 at 2:01 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Freeze plug?
  3. Jan 4, 2020 at 3:55 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Hard to tell what we're looking at. Is that the firewall? Zoom out and focus.
  4. Jan 4, 2020 at 5:42 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    OH...WOW!!! Is that a transmission dipstick??!! :D
    AC condensate drain? If it's the condensate drain, you want it to keep dripping. If it stops dripping, the HVAC box eventually overflows to the cabin soaking your carpet and stinking.
    15whtrd and speedtre like this.
  5. Jan 4, 2020 at 5:43 AM
    It's AC condensation. That's where it's designed to drip. Mine leaves a small lake under the truck in the summer.
  6. Jan 4, 2020 at 6:21 AM
    Professional Hand Model
    Fred
    Hand Protectors
    A/C drip spout there. Its suppose to drip out there.
    Your A/C interior coil is directly behind that firewall. It catches moisture from the air and it drips into a collection tub which runs out the spout you pictured.
    NORMAL.
    Aerindel likes this.
  7. Jan 4, 2020 at 9:27 PM
    LovesLabs
    Frank
    2002 White Tundra
    none
    Thanks, guys, I did suspect it was condensation but the fact it is winter now made me doubt my first thought. I knew it was not any kind of fluid associated with the truck. Yes, that is a transmission fluid dipstick....
  8. Jan 4, 2020 at 9:39 PM
    Aerindel
    Aerindel New Member
    Montana
    The AC is on any time the climate control is turned to defrost or defrost floor mix. It removes moisture from the air (hence, the drip spout) There is a thread here about disabling this feature if you want as some of us have done.
  9. Jan 4, 2020 at 9:49 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    yea, a/c drain, defrost on, a/c is on. normal. good little mod to do is extend that hose to avoid it dripping on the frame.. goes a long way to stop rust there
  10. Jan 5, 2020 at 7:10 AM
    Dog
    Dog sit!
    Rocky Mountain high...
    2006 SR5 AC 4x4 TRD-OR
    Is there a write up and / or do you happen to know the hose size?
  11. Jan 5, 2020 at 7:41 AM
    Fred
    Hand Protectors
    Hows this? Personally, its a waste on time mod IMO. Just grease the frame below the drip line and save your time/money.
  12. Jan 5, 2020 at 9:22 AM
    Dog
    Dog sit!
    And your point is? :D Hell, without waste-of-time mods, how would we spend our time and money? :spending: There would never be red-painted door handles, if everyone followed that philosophy. Guess I'll have to get off my computer chair and walk 20 steps to the garage and measure it myself. Might need a nap after that.
    Tundra2, BubbaW and empty_lord like this.
  13. Jan 5, 2020 at 9:24 AM
    empty_lord
    05 rollover special
    eh the grease works for a while. but i work on rusty trucks all the time. any time i can fight it happening that requires no maintenance, im happy (it also makes it easier to clear out if it gets clogged, which it does. now you just remove the hose and blow it out instead of getting an air gun up there to blow air into the truck
    BubbaW likes this.
  14. Jan 5, 2020 at 10:17 AM
    Fred
    Hand Protectors
    I usually just massage the nipple on occasion.
    FrenchToasty, Tundra2 and bmf4069 like this.
  15. Jan 5, 2020 at 10:24 AM
    Fred
    Hand Protectors
    Soon to be black door handles! Maybe blue once I get to be an old dog like some others?:D
    My point is: Mines been dripping in that spot since 2002 with no rust. Don’t let me get in your way with my opinion. Its your truck. :thumbsup:
    bmf4069 likes this.
  16. Jan 5, 2020 at 10:40 AM
    empty_lord
    05 rollover special
    Kinky
    bmf4069 and BubbaW like this.
  17. Jan 5, 2020 at 10:54 AM
    Fred
    Hand Protectors
    I even held back a little bit about it keeping the juices flowing.
    Seriously, whats your mod advice on this one? Not sure it effects our trucks, but I’ve read this mod helps with stopping the wind from creating a damming effect blowing the water back at high speeds.
  18. Jan 5, 2020 at 11:08 AM
    empty_lord
    05 rollover special
    I'm going to do it to mine when i remember to get a nipple to extend it. i did it on my tacoma. As for noise it should technically help a little? but in all reality it likely wont make a huge difference in that regard. but i can say for sure almost all the trucks with rotted frames coming in are rotted REALLY bad on the top frame rail right below the drain. you've got water dripping onto the frame and a weld there. to top it off you've got the hot exhaust nearby. its not a good combo for anti rust measures
  19. Jan 5, 2020 at 11:12 AM
    Fred
    Hand Protectors
    Must be a northern thing. Where you get these nipple extenders?
  20. Jan 5, 2020 at 11:13 AM
    empty_lord
    05 rollover special
    napa sells them.. you just needa barbed fitting that fits the hose. i forget what size. i think 3/8 or 5/16
  21. Jan 5, 2020 at 11:27 AM
    empty_lord
    05 rollover special
    The other option is replace the short hose with a longer one from the inside out. I don’t think the things hard to get to in the truck. But I don’t remember
  22. May 13, 2020 at 6:00 AM
    I’ve also noticed it ends up dripping right onto the sway bar mount, and looks like that bracket holds water pretty well. I might look into the ol nip slip extendo mod
