Stubby antenna, freaking waste of money!
Discussion in '2.5 Gen Tundras (2014-2021)' started by Buster1, Jan 3, 2020.
  1. Jan 3, 2020 at 7:59 PM
    Buster1
    Buster1 [OP] New Member
    Oregon
    2019 Cavalry Blue Limited TRD Off Road Double Cab
    Ordered the 6-3/4" AntennaMastsRus "Premium" version off of Amazon and it showed up yesterday. Can't even get local stations to come in clear. Even Sirius XM is staticy. Going to test Amazon's return policy.
    Can't believe anyone actually recommended the POS!
  2. Jan 3, 2020 at 8:17 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
    I have that same one on my pro and seems to work good purchased January 28, 2019 6 3/4 Premium Choice drove to Indiana and Wisconsin from Chicago no problem maybe it’s your location or defected antenna
    Tchase likes this.
  3. Jan 3, 2020 at 8:20 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    That antenna has nothing to do with XM. But yeah, the stubby antennas are more for show than they are for go...
    EDDO, Sas, RebelRide93 and 7 others like this.
  4. Jan 3, 2020 at 8:23 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Tchase, Tiamat and panicman like this.
  5. Jan 3, 2020 at 8:25 PM
    Buster1
    Oregon
  6. Jan 3, 2020 at 8:26 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Honestly, mine works where my stock was static. Maybe it’s defective?
    Sorry your experience was not the same.
    GODZILLA likes this.
  7. Jan 3, 2020 at 8:33 PM
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    I have the stubby one from MastsRUs. Works very well. I do live close to Portland, so the stations come in strong, but I managed to hold onto good FM all the way down to Albany, OR with it on the same PDX station.
    I think you got a bad one.
    Joss1799 and NewImprovedRon like this.
  8. Jan 3, 2020 at 8:36 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    There's nothing to test with Amazon's return policy. Return it within the time limit, you'll get your money back.
    I have a cheap $30 one and it works perfectly.
    RitcheyRch and shellshock like this.
  9. Jan 3, 2020 at 8:45 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Mine works pretty well. Better than the last two stubbies I had by far.
  10. Jan 3, 2020 at 8:47 PM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    I have the same one and it works great. Can't compare to stock thought because I switched it out immediately. Try returning and buying another. I think you got a bad one too. If it sucks, return again.
  11. Jan 3, 2020 at 9:00 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    It could easily be a counterfeit as well. Amazon has plenty of counterfiet stuff on their site. Order one directly from the link I provided.
    Buzzeo and shellshock like this.
  12. Jan 3, 2020 at 9:05 PM
    deedubb
    deedubb New Member
    2018 Tundra SR5
    Mine works perfectly fine. Do you live out in BFE? That might make a difference
    FlipMonkey21 and Ely010606 like this.
  13. Jan 3, 2020 at 9:10 PM
    Buster1
    Oregon
    Roseburg, Oregon. Not a thriving metropolis, but not BFE either.
  14. Jan 3, 2020 at 9:21 PM
    ncomeau35
    ncomeau35 New Member
    2019 White Toyota Tundra TRD PRO
    Nitro Ridge Grappler 285/75/18
    I ordered the Ronin .50 cal antenna from Amazon, works perfectly! Only lost signal on rare occasions running thru the mountains in NH. Other than that, looks good, works better.
  15. Jan 3, 2020 at 9:25 PM
    Outbound
    Aaron
    Northern Alberta
    Mine works well. At least it did for the 2 minutes I listened to the radio to test it for the benefit of those asking here. Haven't turned the radio on since then, don't remember the last time I listened to the radio before then.
    Bassn429 likes this.
  16. Jan 3, 2020 at 10:37 PM
    vegas4x4
    vegas4x4 Blaaack
    Las Vegas
    2016 Black TRD CM 4x4
    BTBAKER[QUOTED] likes this.
  17. Jan 22, 2020 at 9:44 AM
    bmann7
    bmann7 Silver Sky Platinum Pro
    WA
    2019 SSM Tundra Crewmax Platinum
    See signature line
    Any update here? Looking at the same one. Thank you.
  18. Jan 22, 2020 at 10:05 AM
    Krautman73
    Krautman73 New Member
    Austin, Tx
    2018 SR5 Crewmax TSS
    6" Maxtrac suspension lift 20x10 KMC XD Buck 25s with -24 offset 35x12.5x20 BFG KO2s Cherry Bomb Extreme muffler 2/1 Stubby antenna
    Have the 6 3/4 from MastsRus and it's been working fine for the past year...
  19. Jan 22, 2020 at 10:05 AM
    Buster1
    Oregon
    I returned it for a refund and put the stock antenna back in place.
    MT Madman likes this.
  20. Jan 22, 2020 at 10:07 AM
    timsp8
    NY
    Might be your radio. That antenna doesn't have anything to do with satellite radio.
  21. Jan 22, 2020 at 11:28 AM
    TundraDude18
    TundraDude18 Deus vult
    'Merica
    '21 Limited CM
    Silver Bullet Express
    Agreed that your location might be part of the issue.
    They have different length antennas [of the kind you bought]: when I get around to it, I am replacing the original [which hits on the garage, going in and out] with one a few inches shorter [20 inches, I think].
    You might try that.
  22. Jan 22, 2020 at 11:42 AM
    RebelRide93
    RebelRide93 New Member
    Jake
    Athens, GA
    2019 White Tundra 5.7L 4x4
    The shorter antennas are typically for looks. i have the .50 cal Ronin Factory Antenna. Love the way it looks. But its connection is weaker.
    Doesn't bother me much because i think ive used the radio once or twice. Basically whenever my phone isn't connecting to the truck
  23. Jan 23, 2020 at 2:53 AM
    MikenMike
    MikenMike New Member
    RACEtruck
    I honestly tried every antenna...not even that nicer one everybody was ordering compares to original....dont waste ur time on stubby....im sure a few people had some luck but i went back to stock...there must be a reason they use that big mast.....it needs a signal booster imo
  24. Jan 23, 2020 at 3:45 AM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    2019 White Tundra Limited
    In work
    Never had a problem with Amazon or eBay returns.
    Stubby works better than the OEM, and as others stated it has nothing to do with the satellite radio. If you are have problems with XM it’s probably your location or maybe a defect in the head unit?
    BravoDeltaRomeo, Toytock and Ronin73 like this.
  25. Jan 23, 2020 at 4:05 AM
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    My stubby works just fine. No issues at all.
  26. Jan 23, 2020 at 4:11 AM
    nodak67
    nodak67 New Member
    JR
    I use the antenna source and this specific one. i tried the 3" one and the reception was horrible from them. switch to this one and its almost as good as the oem.
    41bigdawg and Tchase like this.
  27. Jan 23, 2020 at 4:15 AM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    That’s the exact one I got, the 3” just didn’t look right :)
  28. Jan 23, 2020 at 4:23 AM
    nodak67
    nodak67 New Member
    JR
    oh forgot to add here are pics of it installed
  29. Jan 23, 2020 at 4:30 AM
    muledawg
    muledawg New Member
    Indianapolis,IN
    2019 Silver Sky Metallic TRD CM
    I got the Metra .50 cal. for the looks. Not sure how it works with am/fm as I listen to XM mostly. But can give an update on it if anyone is interested. 66CAD3AA-59AB-4F4B-86FA-3FFA9FAF25FC.jpg
    Medic343 and mlucas555 like this.
  30. Jan 23, 2020 at 4:35 AM
    Haiti4x4
    Haiti4x4 New Member
    Seany
    2016 Black Tundra xspx 4x4
    Stock for now
    Got the Ronin stubby antenna. Works well. Sirius XM doesnt use that antenna and my music is on my phone anyway. I got it because “it looks cool and chicks dig it”.... lol.
    RebelRide93 and 41bigdawg like this.
