Looking to get spacers
Discussion in 'Wheels & Tires' started by kukini808, Jan 2, 2020.
  1. Jan 2, 2020 at 1:53 PM
    kukini808
    kukini808 [OP] New Member
    Colorado Springs, Co
    2019 Tundra Limited CM
    None
    I have an opportunity to get used spidertrax 1.25" spacers for $150 for all 4, is there anything that I should watch out for on used spacers? what's the torque setting?
  2. Jan 2, 2020 at 2:12 PM
    JMB
    JMB I buy Nickelback albums at Target.
    Chesapeake, VA
    2013 Super White Tundra DC
    Not much to go wrong with a hunk of metal. I'd inspect the studs closely for defects, and probably bring a lug nut to install on each one. Make sure there's no corrosion form damage to the anodized surfaces. Surface rust from the hub is not a problem, just make sure you clean the spacer before installing. Also no defects like gouges with raised metal. Torque is 96 ft-lbs for both the spacer and rim.
    That's a pretty good price, they're 140 a pair from Spidertrax, but you can usually find them for about 100 a pair other places.
    kukini808[OP] likes this.
  3. Jan 2, 2020 at 2:17 PM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    2008 Tundra DC 4x4 5.7l V8 Blue Streak Metallic
    Goodyear UltraTerrain AT 275/70/r18, Stoptech Cryo Slotted Rotors/Hawk LTS Pads, DECKED, and lots more!
    I'd say make sure they are in good repair, no cracks, clean mounting surfaces. Torque spec should be same as the wheels, 94 ft/lbs I think. I did mine to 100 ft/lbs, drove 5 miles, and retorqued.
