Sold my Tacoma, buying a tundra, what do I need to know?
Discussion in '2nd Gen Tundras (2007-2013)' started by Christianwgiroux, Dec 30, 2019.
  1. Dec 30, 2019 at 1:50 PM
    Christianwgiroux
    Christianwgiroux [OP] New Member
    Christian
    Just sold a 2010 taco, loved her but it’s time for something bigger, I know the mpg will make me want to eviscerate myself with a very long and sharp knife, but what should I look for and expect from a 2007-2010 tundra RWD (those are the trucks I’m looking at)
    Maxi13 and Rex Kramer like this.
  2. Dec 30, 2019 at 2:02 PM
    TheBeast
    TheBeast The Beach
    crewmax is great for families and has rear window that rolls down :). check the usuals: VIN carfax, toyota maintenance, undercarriage for rust, AIP repairs or not and cam tower leak (easily visible from wheel well).
    the rock warrior are nice since already blacked out/de-badged if you are into that ;)
    edit: RW also comes with highly desirable TRD 17" wheels.
    GODZILLA and Pinay like this.
  3. Dec 30, 2019 at 2:04 PM
    Blueknights75
    Ron
    Clayton, NC
    Actually getting better mpg in my Tundra than I did in my taco....
  4. Dec 30, 2019 at 2:20 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I get 10.3 city, 17 highway.
    Torque is worth it.
    sf319 and TundraDude18 like this.
  5. Dec 30, 2019 at 2:31 PM
    Failure2comply
    Failure2comply Master HVAC Tech
    VA
    2008 Tundra Crewmax Limited w/factory 20" wheels
    Trailer brake. Limousine tint in rear windows. Ultra Gauge "Blue". Toyota bed mat and bug deflector.
    I got 15-16mpg ( V6) in my previout 2005 Tacoma AC Trd/Off Road, and get 13.8-14mpg in my 2008 Tundra Crewmax Limited 5.7ltr. The extra room and goodies in the Tundra more than makes up for the little mpg loss.
  6. Jan 1, 2020 at 6:38 AM
    DesertRoads
    DesertRoads Telecom Guy
    Utah's West Desert
    2005 DC SR5 V8 4WD LSD & TOW PKG
    LED Lights Galore. Mostly Stock
    What do you need to know? That you'll sit up higher, you'll be more comfortable, you'll have a TON more power, and depending on where you live, your fuel mileage will be 10-14 city, and 15-19 highway. I get 10-12 city and 15-16 highway here in the Rocky Mountains. It's a good truck. Look for one that's in good condition, check Car Fax, look under the truck for excessive rust, take it for a test drive during the day and at night. Normal buying stuff. I have a CrewMax. Works perfect for my needs. I use the 5.6' bed for carrying parts for work, and don't need a 6.5' bed. If you do, then get a double cab. The CrewMax has a huge backseat. Lots of leg room. I've never understood why people love the Tacoma so much and why it holds it's resale value better than a Tundra? The Tundra is way better in so many ways.
    Failure2comply and TundraDude18 like this.
  7. Jan 1, 2020 at 6:42 AM
    tye
    tye New Member
    tye
    2016 TRD Pro DC
    Diamondback cover, flowmaster exhaust, n-fab sliders
    Sell the wife and buy a new Tundra
    RollTide82 and Failure2comply like this.
  8. Jan 1, 2020 at 7:23 AM
    Elduder
    Elduder New Member
    My advice is to just do it, traded my 3rd gen Taco for a 19 Tundra Pro. Don't miss a thing.
  9. Jan 1, 2020 at 7:25 AM
    nuclearlemon
    nuclearlemon New Member
    wyoming
    2012 dc
    avoid flex fuel trucks, but do it. been one of the best things i've done
  10. Jan 1, 2020 at 7:45 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Considering that it's in a big heavy truck, the fuel economy isn't that bad with the 5.7 V8. I picked up a well used 2007 a little over 2 years ago, it's RWD and has the 5.7. On the first road trip and before any performance mods I was able to get about 19 mpg at speeds under 65, and about 16 mpg at speeds above 65. I had no interest in a big DC or CC, so I found myself a regular cab... it's a great truck that recently rolled past 290k.
  11. Jan 1, 2020 at 8:38 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Get the 5.7L if possible. The 4.7 has timing belt, only 07's I believe. Newer 4.6 has chain.
    Do not let 100K miles worry you. Purchased our 07 with 130K miles, drives like new.
  12. Jan 1, 2020 at 9:11 AM
    sf319
    sf319 New Member
    Utah
    2014 CM Barcelona Red SR5 5.7
    Dash Cam|PowerStop Z36|DIY bed rails|DIY Pop-n-Lock|LED interior
    Check the toyotaowners.com for TSB's and other maintenance performed on the truck at Toyota Dealerships. Teamed with Carfax, gives you a pretty good picture. Ultimately with any used get a third party opinion.
    Typical issues with 2nd Gens (XK50):
    Frame Rust - Some years still have a TSB that will replace the frame, mostly common in rust belt vehicles
    Cam Tower Leak - TSB covers the seal replacement, more common on newer models, my '07 and '14 don't have a problem
    Water Pump - simple replacement, common over 80-90K
    Rear Diff seepage - Simple re-torque of the bolts "can" prevent further seepage
    I am sure other's can fill in other items, but these are the one's I looked for when getting my '14.
    Like everyone has said, the 5.7 is just fun to drive, the 4.7/4.6 are the famed million mile Tundra's. I came from a Taco too, and only miss the manual transmission occasionally, though city driving is nice with an automatic. I am currently on my second Tundra, both used, my '07 had 150,000 miles when I bought it, drunk driver took it at 197,000. My new to me '14, had 90,000 miles. I never regretted either purchase.
    Maxi13 and nuclearlemon like this.
