Tailgate handle
Discussion in '1st Gen Tundras (2000-2006)' started by DaveInTexas, Dec 25, 2019.
  1. Dec 25, 2019 at 9:41 AM
    DaveInTexas
    DaveInTexas [OP] New Member
    Dave
    West Texas
    2020 Tundra SR5 + 2003 Tundra SR5
    The 2020 has a Ranch Hand front brushguard/bumper
    I’ve broken two already; does anyone know of a metal handle?
    If metal not available, which one is most robust?
    Thanks
  2. Dec 25, 2019 at 9:45 AM
    Outbound
    Aaron
    Northern Alberta
    I don't think a metal one exist. I ordered my replacement one off Amazon. It's was something like $30. I haven't broken it yet, but I'm also not using it every single day.
    DaveInTexas[OP] and speedtre like this.
  3. Dec 25, 2019 at 9:55 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Personally feel the OEM is robust enough for most folks BUT one needs to keep everything on these old jalopies greased. In this case, clean the lock/latch mechanisms and spray some white lithium grease regardless of which one is chosen.
    Rex Kramer and speedtre like this.
  4. Dec 25, 2019 at 9:56 AM
    speedtre
    speedtre New Member
    Inland Northwest
    I bought this one off Amazon for $17 because it was 4.8/5 stars with 80+ reviews...I bought it to install a backup camera in, so I have not actually installed it yet, but it feels pretty sturdy.
    https://www.amazon.com/gp/product/B07Q1L53RD/ref=ppx_yo_dt_b_asin_title_o02_s01?ie=UTF8&psc=1
    BubbaW likes this.
  5. Dec 25, 2019 at 10:13 AM
    I have this one also. Seems to work fine but I agree with Bubba that occasional lubrication would likely help.
    BubbaW likes this.
  6. Dec 25, 2019 at 12:34 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    This is especially true if you spend any time on dusty roads.
    BubbaW[QUOTED] likes this.
  7. Dec 25, 2019 at 12:38 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Bought a Dorman about 5 years ago as a fix. Its been holding very well. I lubed all the gate slides and gate latches while in there.
  8. Dec 25, 2019 at 5:11 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    Having a Limited I ordered mine from Toyota as the handle is color matched. If not for that I would have went with a Dorman as well...
  9. Dec 28, 2019 at 6:49 PM
    3.4Tundra
    3.4Tundra New Member
    Greg
    So. California
    2006 V8 Tundra 2wd
    Bilstein 5100
    I bought the Amazon cheapy too and did the camera mod while I was at it. Seems to be just as good as the one I took off.
    speedtre likes this.
  10. Dec 28, 2019 at 7:01 PM
    Flying Fuzz
    Flying Fuzz New Member
    2019 GX460 Premium with Sport package.
    What is the failure point on these? Something internal or is the plastic handle flimsy and prone to snapping off? I have no issues with mine but curious what you guys are experiencing?
  11. Dec 28, 2019 at 7:16 PM
    3.4Tundra
    Greg
    So. California
    2006 V8 Tundra 2wd
    Bilstein 5100
    The frame is what cracked on mine. Handle/latch was still operational though.
  12. Dec 28, 2019 at 7:34 PM
    Handle breaks in half so there is nothing to grip when trying to open.
  13. Dec 29, 2019 at 3:46 AM
    Bubbles
    Bubbles Decent!
    Sunnyvale Trailer Park
    05 Tundra Limited, 96 Supra Turbo 6MT
    Is there a link to this mod and/or which camera you used?
  14. Dec 29, 2019 at 6:35 PM
    3.4Tundra
    Greg
    So. California
    2006 V8 Tundra 2wd
    Bilstein 5100
    I used this camera:
    [Downside Mounting] COOLINT... https://www.amazon.com/dp/B016I91IK2?ref=ppx_pop_mob_ap_share
    This particular one is downward facing and provides the correct image orientation on your screen when mounted in the handle.
    There was a post I saw here or over on TS forums(can't remember) where someone had done this mod.
    I drilled a hole just large enough to fit the connector through. You can then route the wire down and out the bottom of the tailgate.
    speedtre and Bubbles[QUOTED] like this.
  15. Dec 29, 2019 at 6:43 PM
    abcinv
    Tommy
    South of ATL
    I too bought this camera; reviews tomorrow I hope...
    speedtre and Bubbles like this.
  16. Dec 30, 2019 at 3:27 AM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Pretty sure I used the same camera on mine. It's been good so far. I think I'm probably going on 9-10 months on this mod. My only gripe is that sometimes rain or water collects on it, but that's with every backup camera I've used. Just wipe it off before you start driving and it should be fine.
    As to Willy... Dad?
  17. Dec 31, 2019 at 2:17 PM
    Flying Fuzz
    Copy. Thanks for the info :thumbsup:
  18. Dec 31, 2019 at 3:37 PM
    I forgot to reply when I saw this. Mine did what 3.4tundra's did. Frame cracked but the handle still worked.
