Does the cement color match?
Discussion in 'General Tundra Discussion' started by Willskaf, Dec 30, 2019.
  1. Dec 30, 2019 at 2:14 PM
    Willskaf
    Willskaf [OP] New Member
    William
    Castro Valley, CA
    19, Limited, CrewMax, Off Road, Cement Gray
    None Yet
    I currently have a 2019 Tundra Limited with a chrome grille. I would like to buy the 2017 TRD Pro Cement Grille from Toyota already painted this way I don't have to paint it. I been getting conflicting information from the forum on the color matching. Some say it matches perfectly and some say it does not. Have anyone did that and can provide some input please? I would hate to buy it and not match the same color. Mine is a 2019 Limited. I appreciate any info before I waste the money. Thanks
  2. Dec 30, 2019 at 2:45 PM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    Bilstein 5100 2.3/1.5, TRD sway bars ft/rr, Cooper Tires Discoverer AT3 XLT 295.70.18, Vision Manx 2 18x9 +12, APS side armor steps, TRD-Pro Grill and Bulge, de-chromed, blackout emblems, OEM mirror caps and flares, TRD shift knob, Leather wrapped steering wheel, All weather mats
    Based on the photos I see online. It does not. I have not stopped and inspected it in person. I know, I see a lot of limited super white that does not match from the factory.
    619Tundra likes this.
  3. Dec 30, 2019 at 2:54 PM
    Willskaf
    William
    Castro Valley, CA
    None Yet
    I appreciate that @SprinterAE86. I would like to hear it from someone that personally did it already on their own cement truck if possible please. I do know that some bought it painted from Sparks that did not match . But I'm going to buy the TRD Pro OEM painted . Sparks uses a paint shop . Thanks
  4. Dec 30, 2019 at 3:01 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
  5. Dec 30, 2019 at 3:03 PM
    Travo60
    Travo60 New Member
    Travis
    Austin, TX
    2018 Limited CM Cement
    It’s not a 100% match. Installed mine over the weekend.
  6. Dec 30, 2019 at 3:07 PM
    Willskaf
    William
    Castro Valley, CA
    None Yet
    @Travo60 . What year TRD Pro Grille did you buy? 2017? and what year is your truck? Do you have a picture you can share ?
  7. Dec 30, 2019 at 3:25 PM
    gjcarving
    gjcarving New Member
    Even if it's the exact color code they will not match 100%. The paint will look different as one is on metal and the other plastic. In some lights it will look closer and others more different. Even color matched from the factory differs. I believe White and black match the best.
  8. Dec 30, 2019 at 3:27 PM
    Grendel
    Grendel New Member
    2016 Quicksand TRD PRO
    I would say it would not match 100%. Our trucks color fades with sun weathering etc. The only way you would get a 100% match is to find a shop to scan your truck and then mix the paint accordingly. Even from the factory there is some variation between panels painting metal vs plastic.
  9. Dec 30, 2019 at 3:29 PM
    Willskaf
    William
    Castro Valley, CA
    None Yet
    I hear that a lot that one is plastic and one is metal so it should not match . I respectfully disagree. If you look at the ones OEM painted such as the Sport, Platinum and the Pro. It matches perfect from the factory .
    Omohundro likes this.
  10. Dec 30, 2019 at 3:33 PM
    Willskaf
    William
    Castro Valley, CA
    None Yet
    My truck is 2 months old and garaged. Not faded yet. If Toyota is using the same exact paint for the cement gray on the 2017 TRD pro and my 2019 Limited, color should match regardless plastic or metal. Again, Slight difference in color is fine. Maybe 95% not 100%. but you can see some pictures on the forum with a huge color difference.
    That tells me its not a plastic or metal issue. Its a different shade completely . You see it either lighter or darker.
  11. Dec 30, 2019 at 3:56 PM
    Tundra9831
    Tundra9831 New Member
    Tundra805 likes this.
  12. Dec 30, 2019 at 4:08 PM
    Willskaf
    William
    Castro Valley, CA
    None Yet
    I see. But its hard to tell sometimes from the angle and the lighting
  13. Dec 30, 2019 at 4:10 PM
    gjcarving
    I think they are close, but not 100%. My friend works at a Dealership and I stop by often. The other day they had a cement and voodoo in the showroom and neither grill matched fully. I noticed it right away. But, might be more so for me as I deal with color quite a bit for work and my OCD is high about it. Some people may not care about a slight difference. That being said I much prefer the color over the overdone chrome. Just my opinion.
  14. Dec 30, 2019 at 4:34 PM
    Willskaf
    William
    Castro Valley, CA
    None Yet
    I would love for someone to post a picture of his own truck that he did . Lots of people did that
    KnuckleHD likes this.
  15. Dec 30, 2019 at 4:37 PM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    Just replied to your PM. Sounds like you’ve already seen the pictures of mine. I think it matches nicely. 100%? Maybe not. But close enough for someone like me who’s OCD about their truck.
  16. Dec 30, 2019 at 4:45 PM
    KnuckleHD
    Here’s a few in different lighting...
  17. Dec 30, 2019 at 4:51 PM
    Willskaf
    William
    Castro Valley, CA
    None Yet
    @KnuckleHD Looks awesome. It's perfect to me. I just PM you
    10TundraSR5 and KnuckleHD like this.
  18. Dec 30, 2019 at 5:08 PM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    Metallic or pearl paint applied to metal and plastic parts with the same equipment, at the same time (which these parts are not) will absolutely look different. The parts and trucks in question will be painted months or years apart. Toyota could even change paint suppliers in the mean time and they’re certainly spraying from a different batch with different equipment. We’re not rolling on latex here. The idea of a perfect color match on anything other than identical panels sprayed simultaneously on the same plane is wishful. With a few minutes in the right light I could take a cell phone pic that would make you think I replaced any panel on your truck with a darker one. Cement is not a hard color to match but if you’re going into it looking for a variance you’ll find it. Google camaro quarter panel mismatch. Cars painted at the factory had people lining up complaining that the doors and quarters didn’t match. Slight angle difference at the panel gap. Slight.
    Omohundro and Toyotoholic like this.
  19. Dec 30, 2019 at 5:43 PM
    Tundra$
    Tundra$ White Trucks Matter
    Las Vegas
    2018 SR5 4x4 off-road CM 5.7 Super Fast White
    3/1 readylift, 35x11.5r20 ridge grapplers, 20’ fuel wheels, bakflip revolver bed cover, console safe, N-fab side rails, mini antenna, 2019 TRD Pro grill, color match hood bulge, front bumpershellz, baby car seat, to be continued...
    Doesn’t Toyota use a single stage paint or whatever that has the clear built in on the metal parts? Do they use that on the plastics too ?
    Could the slight veriance in paints on grills/plastics be due to paint + clear maybe ?
    I’ve never seen a color match done after original purchase that was 100%.
    I know Toyota of cool springs stopped shipping most colors on the parts due to complaints. Have also seen a bunch of complaints on sparks parts color matching too.
    You’re either gonna need to settle on it most likely not matching 100% or have it painted locally where you can see it with your own eyes in person and make them repeat until satisfaction.
  20. Dec 30, 2019 at 5:50 PM
    cpc0812
    cpc0812 New Member
    Cory
    2018 Cement 4 X 4 CM
    This is my 18 with a 17 surround. There is a slight difference. I think most will be off a little. As someone already said, lighting plays a role as well.2BDA1962-CA6C-4BAC-8AAA-B8853DF61AD4.jpg
    10TundraSR5 likes this.
  21. Dec 30, 2019 at 6:11 PM
    Travo60
    Travo60 New Member
    Travis
    Austin, TX
    Here is a overcast picture. Hard to tell from the glare but the grill is a shade darker than the truck painted metal. Pretty close. 2018 truck, 2017 grill from Toyota cool springs.
  22. Dec 30, 2019 at 6:19 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Mines a little off as well. Its close enough for me to be happy with it.20181111_175953.jpg SmartSelect_20181121-075010_Gallery.jpg
  23. Dec 31, 2019 at 10:54 AM
    Willskaf
    William
    Castro Valley, CA
    None Yet
    All these pics are fine to me. @KnuckleHD and @cpc0812 looks the closest. They all look good.
  24. Dec 31, 2019 at 10:54 AM
    Willskaf
    William
    Castro Valley, CA
    None Yet
    Thanks Fellas . I appreciate you all
    Toyotoholic likes this.
  25. Dec 31, 2019 at 11:03 AM
    Willskaf
    William
    Castro Valley, CA
    None Yet
    @Larmand , who makes your front bumper ? Looks awesome. Does it come with the all the lights or are they extra ?
  26. Dec 31, 2019 at 11:04 AM
    10TundraSR5
    10TundraSR5 Happy Tundra owner
    Tennessee
    2010 Black Tundra SR5
    Curse you Perry the Platypus!
    I'd be happy with that to!!!!
    Larmand[QUOTED] likes this.
  27. Dec 31, 2019 at 11:05 AM
    Willskaf
    William
    Castro Valley, CA
    None Yet
    Agree... I'm OCD and fine with that .
  28. Dec 31, 2019 at 11:06 AM
    Willskaf
    William
    Castro Valley, CA
    None Yet
    Toyotoholic and Larmand like this.
  29. Dec 31, 2019 at 11:44 AM
    Ericbike6
    Ericbike6 So we're doing this shit today?
    Eric
    Austin, TX
    2019 Tundra TRD 4X4 sport
    Air bags, ARK liners, misc bullshit added also
    I see at least 3 different colors there. Which is pretty normal for Toyota. Mine in super white, and has 4 different colors on the front end.
    Trucks painted in one plant, plastic grill made in another, bumper ends made in yet another, then all married up on the line, some variances are to be expected. Even if all of them were painted at the same time, the colors would be off. At least 3 different substrates there, that will each reflect the light a different way.
  30. Dec 31, 2019 at 11:51 AM
    7.62Tundra
    7.62Tundra Chromeaphilliac
    SA Texis
    2015 5.7 Crewcab
    No they do not. Clear is a separate booth before the ovens. That goes for the plastic parts on the grille. The grilles are fabricated in another satellite location that is adjacent to the plant. I seriously doubt they are going to match 100% as they are not sprayed with the exact same lot of paint like the body. Base coat is water based and clear coat is solvent based.
