SON OF A...
Discussion in 'Guns & Hunting' started by Outbound, Dec 29, 2019.
  1. Dec 29, 2019 at 2:11 PM
    Outbound
    Outbound [OP] SSEM #2.5, AmeriCanadian, OG 1st Gen Rabble Member
    Aaron
    Northern Alberta
    Well, I just had my first failure with my Mossberg Maverick 88. First, some perspective. I've been on a mission to see what kind of abuse a cheap shotgun can take.
    - This gun has over 12,000 rounds through it.
    - I have cleaned the gun 3.5 times. The first 3 times were when I cleaned it roughly every 1000 rounds before going on my torture test mission. It has not been properly cleaned since around the 4000 rounds poiunt. The half clean was simply a rinse and wipe down of the exterior to remove mud and grime after a swamp test.
    - I've fired it under a few feet of snow
    - I've fired it with the action and barrel jammed with mud and debris
    - I've fired it after dunking it in Alberta muskeg (hence the rinse treatment)
    - I've tossed it out of a moving truck a few times
    - I've fired it in temperatures from +35 down to -35
    - I've fired it in freezing rain
    - I've frozen the action shut and fired it
    - I've drop kicked it down a mountainside
    - In one test I loaded, fired, loaded and repeated so quickly and with so many rounds that the barrel began to change color from the heat. I believe the count was 200 ish shells with about 10 minutes give or take (didn't have a timer running) of constant firing and reloading
    - It's been rudely exposed to dust, dirt, grime, mud, ice, snow, water (salt and fresh), swamps, you name it.
    - I've probably abused it in ways I don't even remember.
    Now, on to the failure. I was reorganizing some stuff in my gear room and had the shotgun leaning against the table while I pulled some other guns out of the cabinet. I bumped it and it fell over, landing on the concrete floor.
    Now the action won't open more than half way. The trigger housing pin seems to be shifted out of position or loosened somehow and that's jamming up the action. Now I need to figure out how to disassemble this thing without opening the action...
    j-utah, Black@Blue19, vtl and 7 others like this.
  2. Dec 29, 2019 at 2:19 PM
    Outbound
    Aaron
    Northern Alberta
    Nevermind. IT LIVES!!!!! BWAHAHAHAHA!!!!!
    Beat it on the ground to break the action loose. Tap the receiver pin with a drift punch. Smack it a couple times. Problem solved.
    Mikhail Kalashnikov would have been proud to own this gun. :D
    kirkb, Wrongside, P-Factor and 16 others like this.
  3. Dec 29, 2019 at 2:25 PM
    Some times you have beat things to make them function.....dirty minds chime in now...3.. 2...1...
  4. Dec 29, 2019 at 2:31 PM
    WNY PAT
    WNY PAT New Member
    Western New York
    2025 GMC Sierra 2500HD AT4 2017 CM Limited (Sold) 2019 CM SR5 l
    Mossberg.... I own 3 of ‘em! But I treat them better.... lol
    Patch999 and Outbound[OP] like this.
  5. Dec 29, 2019 at 2:31 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
  6. Dec 29, 2019 at 2:32 PM
    TheBeast
    TheBeast The Beach
    pictures of said gun ? :D
  7. Dec 29, 2019 at 2:56 PM
    Outbound
    Aaron
    Northern Alberta
    Ask and ye shall receieve. Took a few close up ones to show the wear in spots. Magpul SGA buttstock hasn't held up well. A few hard impacts caused the loss of the washer that holds the LOP spacer pin in hence electrical tape and the pop in cover that goes over the mounting bolt on the grip, hence the hockey tape (true Canadian fix eh?).
    The gun is still in surprisingly good shape. No major dents. Just scratches, pockmarks, chips etc.
    20191229_155316.jpg 20191229_155218.jpg 20191229_155156.jpg 20191229_155145.jpg
  8. Dec 29, 2019 at 3:56 PM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    If beating it doesn't work, then try forcefully sticking it into some more dirty places. Get creative!
  9. Dec 30, 2019 at 8:48 AM
    marinakorp
    marinakorp New Member
    2010 DC 5.7 SR5 TRD Mica Green
    Tow Mirrors, Tekonsha p3, 12 v Solutions remote Start,Weather Tech Mats, Truxedo Roll up Tonneau
    I too have beaten the shot out of this mossberg...just keeps on going bang...every frigging time.
    Cmilla25 and Outbound[OP] like this.
  10. Dec 30, 2019 at 9:20 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    My little brother received an 835 Ultramag for Christmas in the early 90s. Running out of ammo was never a concern because you could bludgeon a polar bear to death with it.
    Sunnier, 1lowlife, Black Wolf and 3 others like this.
  11. Dec 30, 2019 at 9:53 AM
    Sounds like someone was a little bored up there in the cold north!!
    jewsNbrews and Outbound[OP] like this.
  12. Dec 30, 2019 at 10:12 AM
    Outbound
    Aaron
    Northern Alberta
    Between shooting polar bears, ice fishing for narwhal, managing sled dogs and preventing my igloo from melting due to global warming I'm far from bored. :rofl:
    vtl, JH5370, aperezsh and 4 others like this.
  13. Dec 30, 2019 at 10:15 AM
    jewsNbrews and OR18TRD[QUOTED] like this.
  14. Dec 30, 2019 at 10:17 AM
    @Pinay 's favorite giffy........just sharing for no particular reason.....and it's kuul.....
  15. Dec 30, 2019 at 10:22 AM
    ...and there's that one too........
  16. Dec 30, 2019 at 10:24 AM
  17. Jan 16, 2020 at 8:44 PM
    Glockmeister
    Glockmeister New Member
    North of the summer hell
    ‘17 Crewmax SR5 4X4 TRD
    You have big brass balls firing a shotgun with a barrel jammed with mud. I’ve cut shotgun barrels back and they’re NOT what I would consider “hard steel” by any measure.
    Impressive that it still worked after all that.
    Gives me high hopes that my 500 that sits by the bedside was a good choice!
    :bowdown::bowdown:
  18. Jan 16, 2020 at 8:50 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Haha awesome test! I love my 500. Not nearly as abusive as your sir so I should be good for the rest of my life haha:hattip:
    Outbound[OP] likes this.
  19. Jan 16, 2020 at 9:11 PM
    Windsor
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    I love my 88. Great shotgun for very little $. My 18.125" barrel use to be a 28". Kinda like the ribbed barrel on 18".
  20. Jan 16, 2020 at 9:35 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    I only have one shotgun in my arsenal, a Remington 870 Express Magnum. If the sound of it cycling another round into the chamber doesn't scare you, then nothing will.
  21. Jan 17, 2020 at 5:05 AM
    Outbound
    Aaron
    Northern Alberta
    I admit, I pulled the trigger with a string. My balls aint that big. Lol
  22. Jan 17, 2020 at 3:53 PM
    Glockmeister
    LOL - Glad you hear you don’t clank when you walk! :thumbsup:
  23. May 16, 2024 at 6:08 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I just got one based on review here ;) Thanks! It looks like a Home Depot hummer: crappy, but lasts forever.
  24. May 16, 2024 at 6:18 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    WOW!! Amazing,,, and one lil fall does it in?! :)
