Installed Toyota Bed Light Kit today.
Discussion in 'Lighting' started by tech1208, Dec 29, 2019.
  1. Dec 29, 2019 at 9:09 AM
    tech1208
    tech1208 [OP] Old Salt, New truck
    Orlando, FL
    2023 Tundra Platinum 4X4 Blueprint Blue
    I installed the Toyota Bed Light kit today. This is the South East Toyota Bed light Kit part #0016-34187. I can't tell the difference between this and the Toyota part#PT94835160 other than about $50.00 in my favor.
    The instructions are good, only needed a couple of clarifications for the 2020 model year:
    Instructions are attached.
    The kit comes with the following:
    Templates from the instructions were spot on for the holes:
    The bed lights prior to mounting and post mounting:
    A little different from the instructions is that a screw cap holds the carpet and the corner kick panel trim piece in place on both driver's and passenger sides. Once you remove that the trim cover may be removed and carpet pulled up:
    Here are the two tap connectors in place. These pictures are better than ones in the instructions for reference:
    Other than these few pics, all else is straight forward. Took me about two hours by myself taking my time and routing the harness to my liking on the passenger side.
  2. Dec 29, 2019 at 10:03 AM
    TheBeast
    TheBeast The Beach
    nice ! I went with mattgecko kit but it's nice to see Toyota coming up with factory option.
    Inquiringone likes this.
  3. Dec 29, 2019 at 4:39 PM
    Crizzlej5
    Crizzlej5 New Member
    You have any pictures of it lit up in the dark? Considering adding it
    SP3ll✔️ likes this.
  4. Dec 30, 2019 at 6:18 AM
    tech1208
    Orlando, FL
    Here you go!
    STR1, SP3ll✔️, TRD VO and 2 others like this.
  5. Dec 30, 2019 at 8:33 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Looks good. I need to add lights to mine as well. Seems like a decent kit.
  6. Dec 30, 2019 at 4:23 PM
    2chains
    2chains New Member
    Southern Ablerta
    Great quality pics! What size fuse do they include?
    Does it have a switch in the bed and cab?
  7. Dec 30, 2019 at 4:32 PM
    Mickeydog
    Mickeydog New Member
    Dave
    West Michigan
    2015 Tundra Pro CrewMax
    Diamond back lid, 2019 Pro LED Headlights, Recon Smoked LED Tail lights.
    The LED Bed Light should illuminate with
    any of the following actions:
    • Door is opened
    • Cargo light is illuminated
    • Key FOB is used to unlock doors
    AggiePhil and 619Tundra like this.
  8. Dec 30, 2019 at 4:43 PM
    2chains
    2chains New Member
    Southern Ablerta
    Thanks. How long do they stay on when the key FOB is used? And do they fade out?
  9. Dec 31, 2019 at 2:00 AM
    Mickeydog
    Dave
    West Michigan
  10. Jan 4, 2020 at 5:28 PM
    RayMcGee
    RayMcGee New Member
    2016 Tundra
    Awesome post, can you please provide the link to the South East Toyota bed lights?
  11. Jan 4, 2020 at 5:54 PM
  12. Jan 4, 2020 at 6:04 PM
    Berdine
    Berdine Voodoo Sport
    Frank
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Great job!
  13. Jan 20, 2020 at 8:34 PM
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    Fantastic post OP. Thanks for thinking of all of us, for $80, this is a solid mod. I’m absolutely terrible with electrical. Not sure if I can tackle this one but may try because of this post.
  14. Jan 20, 2020 at 8:44 PM
    junior
    junior Member
    Zach
    Santa Cruz, CA
    2016 Tundra TRD Off Road
    Black Rhino Rapid 17" 35x12.5 Mickey Thompson Baja Boss Fox Performance Elite 2.5 DSC at 3" with Coachbuilder 1/4" shim on driver side JBA UCAs Fox Performance Elite 2.5 DSC rear shocks Dobinsons HD Leaf Springs Firestone Airbags + Daystar Cradles Prinsu Cab Rack 2024 Four Wheel Camper Project M Camper Mods: Goal Zero Yeti 4000 house battery 200w solar IceCo fridge Truma Propane Heater
    AggiePhil and ForceV4 like this.
  15. Feb 2, 2020 at 6:48 PM
    pickupjason
    pickupjason New Member
    2019 Silver Crewmax TRD offroad 4x4
    Thanks OP. You saved my day!! I was installing mine earlier today and found out the installation guide shows the wire connection for 2018 which is totally different than what I have on my 2019
    By the way, How do you figure out which wires to tap to?
  16. Feb 5, 2020 at 10:50 PM
    KERNEL_DALE
    KERNEL_DALE New Member
    Norcal
    19’TRD-PRO
    A simple mod for my 2019 trd pro ,another first for this year and more to come :)
    tnx Op for a quick reference.
  17. Feb 5, 2020 at 11:18 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Great job.
    Installed mine a little different since I have a swing case.
    Happy with the results..
    Installed the left side in the front corner.
    BC864653-96C7-4E1C-B3C0-1DD6D8C48D3A_zps_2df44cd8b8e2ab6c120dee169b462a6d6cc4ffb8.jpg
    8012F3BF-4D59-4E09-A8B0-216A00B629E6_zps_56296efcf1444b277b9a60854920882f2bc90d35.jpg
    02E0EFFB-296C-4323-BEDC-88898E8043E2_zps_cdc45d35d521dd27229a36d3c87974beca20dd4c.jpg
  18. Feb 8, 2020 at 11:27 AM
    Crizzlej5
    What's the difference between the part number OP gave and this one?
    00016-34089 looks the same to me and is 67$ on eBay
  19. Feb 19, 2020 at 4:34 PM
    NCTundra1980
    NCTundra1980 New Member
    Stephen
    2019 SR5
    I wonder that too?
  20. Aug 31, 2020 at 8:59 PM
    trowski
    trowski New Member
    I installed the tailgate locking kit that used the passenger side grommet. It looks like there's a similar grommet on the driver side. Can I route this kit through that grommet instead? Seems odd they used the passenger side in the first place only to route it to the driver side.
    What color temp are the lights? Are they a cool white or a warm white?
  21. Aug 31, 2020 at 10:20 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    I don't see why you couldn't run them thru the driver's side.
    Just be careful poking the driver's side grommet from the top, the fuel lines are right under that grommet from what I remember..
    I had to run my Amp step lights thru it.
    Not the best pics but this is what I have.
    Pics taken under my bed cover.
    I installed one in front and one in the rear because of my swing case.
    I'd say more of a cool white than a warm white..
    Cooler and whiter than my cargo bulbs in the pic.
    But those might have been stock bulbs in the cargo light before I replaced them with LEDs ..
    A02F5218-A546-4E53-A261-CC7174004ACA_zps_bbeda49905fe6763870489a78afeb7bf3b298950.jpg 49EAB9F4-82B2-46FB-A121-1E2C6820843A_zps_0d7232afb1a21660bd269fae70db3be644a0c1cf.jpg 6F5F5483-5956-43F9-9303-47DFB6DD32C9_zps_96dedb45747d8706f5e642bf38c6579d688dce20.jpg 09DAF22E-1F05-42DE-9940-0846F07AD48F_zps_2394eda431c8bbf1f031b02b806a345a5459092b.jpg
  22. Sep 1, 2020 at 2:14 PM
    trowski
    trowski New Member
    Crawled under the truck quick and now I see why they run it on the passenger side. The driver side doesn't have a good place to zip-tie the wires to get to the driver seat grommet.
    Looks like theres another grommet under the rear seat on both driver and passenger sides. Does anyone have a picture of where those holes come out inside? I can probably run the wire the rest of the way under the plastic sills, but I'd like to see what I'm dealing with before I start tearing into things. Or is there a better way I'm not thinking of? Can I get directly into the sills?
    Thanks for the pictures! That helps a lot, especially on the color temp. If I install these I might be forced to spend more money on some color matched LEDs for the cargo light. :D
    1lowlife[QUOTED] likes this.
  23. Sep 21, 2020 at 4:45 PM
    Charliebrn
    Charliebrn New Member
    NW Ohio
    2017 DC Limited 4x4 Tundra
    Tyger Folding Tonneau cover Polished stainless running boards LED interior lighting VLED Footwell Kit LED Bed lighting
    How do you like the Matt gecko kit? I’m seriously considering it since I’ll probably be adding the swinging storage bin for my 2017. Pics??
    Thanks,
  24. Sep 21, 2020 at 7:12 PM
    TheBeast
    TheBeast The Beach
    I posted some in his sale thread
  25. Nov 18, 2021 at 7:30 AM
    tundraiggy73
    tundraiggy73 New Member
    2021 Cement Crewmax Trail Edition
    I'm late to the party on this one but I just installed these lights on my 2021 Crewmax. I will be adding a switch in the hole above the light on the left side (doesn't matter what side) so that I can turn these lights on without opening the door or using the remote. This will also ground the relay for the cargo light and turn the cargo light on as well.
    These lights are very well made and the install was easy, although there is just too much excess wiring you have to bundle up and zip tie under the truck. I may shorten the harnesses at some point, but for now they're fine.
    georgiey22 and Mater like this.
  26. Nov 18, 2021 at 7:32 AM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Great first post. Welcome!
  27. Nov 18, 2021 at 8:33 AM
    georgiey22
    Would you mind sharing where you purchased your lights and cost?
  28. Nov 18, 2021 at 11:23 AM
    tundraiggy73
    i bought them from Sparks Toyota in South Carolina. I believe they were around $80 and shipping was quick, they are good people to do business with from what I gather.
  29. Dec 21, 2021 at 7:00 PM
    TundraBrew
    TundraBrew New Member
    After drilling into the bed, did you guys dab some paint into the holes to prevent rust? The instructions mentioned body sealant, but I would probably add some rustolium for added protection.
  30. Jan 2, 2022 at 1:40 PM
    BlueTSS
    BlueTSS New Member
    2014 Blue Tundra TSS
    Exterior - ReadyLift 4” SST Lift - BFG KO2 285/65/R20 - GST black wheels (2021 TSS) - MGP red caliper covers - TRD exhaust with black tips - TRD rear sway bar - Toyota blackout emblem overlays - Toyota bed rail system - Toyota bed light kit - AlphaRex headlights - AlphaRex style taillights - OEM LED fogs - OEM honeycomb grill - VLEDS Interior - Katzkin black leather seats - TRD black shift knob - Toyota all weather floor liners - SET wireless charger - Taco Tunes starter system - JL Audio 10TW3 - 3M 35% front tint - VLEDS
    For those curious about the Toyota version (PT948-34170) I installed this kit on my 2014 Tundra two weeks ago. A couple of differences I noted (vs the SET kit):
    1. You need to drill a larger hole (1 1/8 inch) as there is a rubber grommet protecting the wires behind each light pod.
    2. There is a visible brownish water proof sealant behind each light pod.
    3. The entire wire loom is protected with black tape.
    4. Part of the wire loom has a heat shield.
    5. Wire length is an exact fit, no excess wiring left over.
    6. 2 red wire taps of a different style are provided.
    7. You tap into the ground wire behind the cargo light switch instead of next to the ground bolt.
    8. Foam tape for protecting/routing the wire inside the cab is provided.
    9. Removing the front seats and the center console are part of the instructions.
    10. Kit was designed only for 2017 & up Tundras, but it still fits the 2014- 2016 (only the wiring is different).
    11. Lastly, it costs about twice as much lol
    I followed the Toyota instructions with 3 exceptions.
    1. I used a black touch up paint kit instead of the 3M ultra pro body sealant for the holes I drilled.
    2. I routed the wiring around the passenger foam floor insulation pad instead of under it.
    3. I tapped into a brown wire in the DC connector for power (no 3H connector in 2014-2016).
    This kit works perfectly, the bed lights always come on when the cargo light is on. Do I recommend this over the SET version... it depends. For most people, probably not. It's more expensive and more work to install. But for others, the Toyota version is a very well built kit.
    scruffy727 likes this.
