Discussion in 'Detailing' started by War Machine, Dec 30, 2019.
  1. Dec 30, 2019 at 5:11 AM
    War Machine
    War Machine [OP] SSEM # 5 3MW
  2. Dec 30, 2019 at 5:38 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    i may have to get some of this - since im all out of my favorite smelling Iron-X lemon scent...lol
    War Machine[OP] likes this.
  3. Dec 30, 2019 at 8:08 AM
    War Machine
    I did my truck last week. I did half and half and saw no difference in performance between the two. It had been right at a year since I’d done mine last, and there wasn’t a ton that needed to be removed, but the Shine Supply product did just as well. It doesn’t have the stink that Iron X does.
    One of you guys may want to get a small bottle to verify, but it did fine for me.
    NewImprovedRon likes this.
  4. Dec 30, 2019 at 8:43 AM
    I'm going to try this out Jason. Looks quite promising :thumbsup:
  5. Dec 30, 2019 at 8:45 AM
    owb2gp
    owb2gp New Member
    ID
    I bought a gallon of this stuff in the spring and it worked great. Was my first time using an iron remover so I couldn't really compare it to another product. Definitely cheaper than Iron-X.
  6. Dec 30, 2019 at 10:02 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Does anyone agitate the iron product with a mitt or MF towel like many instructions say to. I have always sprayed and rinsed and never even thought to wipe the surface at all.
  7. Dec 30, 2019 at 10:21 AM
    Squeaky
    Squeaky New Member
    Wisconsin
    ‘19 White TRD Pro
    I did my wife’s Highlander last week. After a good hand wash, I used IronX and wiped off with microfiber towels after 5 mins. Not sure I would try this on a black vehicle, but with her blizzard pearl, it worked great.
  8. Dec 30, 2019 at 10:38 AM
    Black paint needs love too.
  9. Dec 30, 2019 at 10:42 AM
    War Machine
    I’ve done it both ways. I don’t think it makes a ton of difference, especially if you’re claying afterwards. I’d say it’s best to spray on and rinse off within five minutes. If you aren’t claying it is probably better to agitate it.
    Pudge[QUOTED] likes this.
  10. Dec 30, 2019 at 10:43 AM
    Squeaky
    Squeaky New Member
    Wisconsin
    ‘19 White TRD Pro
    I hear you but ya might have to follow up with the G9, LOL!
  11. Dec 30, 2019 at 10:44 AM
    Squeaky
    Squeaky New Member
    Wisconsin
    ‘19 White TRD Pro
    I’d agree with this. I followed up with the clay bar and it was almost unnecessary as most came off with the IronX towel combo.
  12. Dec 30, 2019 at 11:01 AM
    War Machine
    I hear all the time that polishing is needed frequently after claying, but I’ve never seen any marring on my black truck or any other. I think using chemical decon first makes the clay step a lot less harsh. It may also be because I exclusively use a fine grade Nanoskin mitt. I have a medium grade Nanoskin sponge that I use for glass with bad water spots, or in the event my dumbass lets IronX sit in the windows too long and it stains......
    Squeaky[QUOTED] likes this.
  13. Dec 30, 2019 at 11:02 AM
    War Machine
    Generally the only spots where I pick anything up with clay after IronX are around the hood and front end. Usually next to nothing left on the rest of the vehicle.
  14. Dec 30, 2019 at 11:12 AM
    Squeaky
    Squeaky New Member
    Wisconsin
    ‘19 White TRD Pro
    Yep exactly. Mostly in the little nooks and crannys around the plastic trim areas.
