2003 Firewall Access....
Discussion in '1st Gen Tundras (2000-2006)' started by smokey0810, Dec 29, 2019.
  1. Dec 29, 2019 at 6:42 PM
    smokey0810
    smokey0810 [OP] New Member
    '03 Tundra SR5 AC 4WD
    Looking for access thru the firewall. No real good pictures of the first gen, and the harness & grommet seem to go right behind the upper part of the dash. Any thoughts/pics?
    Gonna be running the wiring harness for my fog lights on Tuesday.
  2. Dec 29, 2019 at 7:25 PM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    Lift, Rims, Bigger Tires, Nerf Bars, Black Out Emblems
    Look straight forward between your E-brake pedal and side panel.IMG_20191229_191950555.jpg
  3. Dec 29, 2019 at 9:47 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    On the engine bay side you'll find that grommet between drivers fender and your master cylinder. You can see a red wire for my lights going in there.
  4. Dec 30, 2019 at 3:57 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Oooo! Look at that clean brake fluid!
    Darkness[QUOTED] and bmf4069 like this.
  5. Dec 30, 2019 at 12:27 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
  6. Dec 30, 2019 at 3:55 PM
    Fred
    Hand Protectors
    bmf4069 likes this.
  7. Dec 30, 2019 at 10:21 PM
    smokey0810
    Worked perfectly, with the exception of blowing my ECTS fuse...
