Odd sound when turning right and braking from good speed
Discussion in 'Suspension' started by TundraJoe20, Dec 7, 2019.
  1. Dec 7, 2019 at 11:38 AM
    TundraJoe20
    TundraJoe20 [OP] New Member
    Joe
    2012 Tundra Luchesse edition
    K&N Intake
    Background story: I have a 2012 2WD CrewMax. I put on Bilstein 5100's in front and back. Front at highest setting and put Toytec shackles in back at 1" setting. Got some +12 offset wheels and Nitto Ridge Grappler G2 285/65/20 tires. They rubbed so while getting aligned, they removed the front inner fender shroud and the rear mudflaps. No more rubbing. Aligned it, turns great, looks great, no issues.
    Until today... I was getting off of a right turn exit ramp. So I've got the wheel turned to the right maybe 1/3 of the way and I start to apply the brakes and I hear a very odd almost combination of ABS sound and grinding sound. My first thought was maybe I braked too hard and the front of the truck dipped down causing the tire to rub the bumper somehow. I stopped and checked and saw nothing. I went back and took the exit again and barely ( and I mean barely) tapped the brakes and it made the same sound again. It only seems to do it when I'm taking a right turn from over 35 and braking. And if I barely tap the brakes, just to get the pad to engage is when it happens. Under that speed like when turning down a road or something it is just fine.
    When the noise occurs and I let off the brake, it keeps going for about 3 seconds then stops. Then it will start again if I tap the brake and again it will last about 3 or 4 seconds then stops. I can't see anything rubbing or grinding.
    Anyone have any clue? Will be taking to a shop next week if I can't figure it out over the weekend.
  2. Dec 21, 2019 at 6:07 PM
    DjGrhymes
    DjGrhymes New Member
    2011 Tundra 4x4
    Hey Joe, I actually have the same issue going on rn, it happened after I put new tires on. Exiting a freeway, or on a sharp bank... it will even make the noise without braking if I'm going fast enough.
    The one mechanic I went to was stumped... he said maybe the differential.
    Let me know if you found out anything on your end before I go into another shop and they start replacing things. I don't think its rubbing, very odd noises though. Thanks
  3. Dec 28, 2019 at 3:36 PM
    DjGrhymes
    2011 Tundra 4x4
    Hey Joe, not sure if this helps but for me it was my VSC activating on the turns. Try turning it off on, 3 second hold on the VSC once and then a second time for traction control to turn off. There are work around to recalibrate or reset it. Cheers
  4. Dec 29, 2019 at 12:14 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    Yep, it sounds like a your traction control is kicking on. I’m guessing it’s doing that because of the yaw sensor while turning and then tapping the brakes. It thinks you’re in trouble.
