4x4 system
Discussion in '2.5 Gen Tundras (2014-2021)' started by Marcstryd, Dec 28, 2019.
  1. Dec 28, 2019 at 1:59 PM
    Marcstryd
    Marcstryd [OP] New Member
    Marc
    2016 White Platinum Tundra
    TRD pro suspension TRD pro exhaust
    20191228_141228_HDR.jpg Anyone seen this come up before? It came on while I was climbing a hill? I restarted the truck and it went away. It came back on when I engaged 4x4 again.
  2. Dec 28, 2019 at 4:23 PM
    Cornilsa
    Cornilsa New Member
    Andy
    Gaston OR
    2014 Tundra Crew Max Limited
    That’s strange I think if you do a search on here there’s been some issues with the factory trailer brake controller my 14 limited doesn’t have a factory controller and I have not had this issue
  3. Dec 28, 2019 at 4:31 PM
    Marcstryd
    Marc
    I'll try searching a bit more. My 4x4 won't engage and literally every every warning light is on.. abs, traction, 4 low, 4 high, proximity sensors, trailer brake... Seems pretty odd.
  4. Dec 28, 2019 at 5:10 PM
    Marcstryd
    Marc
    Looks like it's probably a wheel speed sensor.. at least from what I'm reading of others problems. I'll take it to the dealer as it's still on warranty and find out for sure.
  5. Dec 28, 2019 at 5:27 PM
    Cornilsa
    Cornilsa New Member
    Andy
    Gaston OR
    That’s what I would do, just make sure you can replicate the problem when your there
  6. Dec 28, 2019 at 6:33 PM
    zlaneb
    zlaneb New Member
    Austin, TX
    ...or the dreaded rodent issue (wires being chewed). I didn't have the same error for the brake controller but i was getting all kinds of odd crap show up. Started looking around and found rat crap in the engine compartment. Sure enough, a rat had chewed on my main wiring harness.
