Some tire porn
Discussion in '1st Gen Tundras (2000-2006)' started by 1stgenJim, Oct 10, 2019.
  1. Oct 11, 2019 at 12:46 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    For the highlander:
    That's fine as long as the rear tires aren't cupping or feathering.
    If they start to cup or feather then you'll want to cross the rears as they get rotated.
    For the Tundra, if the fronts are cupping, cross those as they get rotated back.
    JohnLakeman and BubbaW[QUOTED] like this.
  2. Oct 11, 2019 at 12:51 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Are they mounted yet? What's the hold up?
  3. Oct 11, 2019 at 1:34 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I kinda like cupping and feathering of the rears....
    turboser91, Rica25, MS22 and 7 others like this.
  4. Oct 11, 2019 at 2:03 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    If it's been working for you
    Rica25 and BubbaW[QUOTED] like this.
  5. Oct 11, 2019 at 3:24 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    I'm sorry, did you say something, somewhat distracted with what's above your head :eek2:
    Darkness[QUOTED] likes this.
  6. Oct 12, 2019 at 3:39 PM
    1stgenJim
    1stgenJim [OP] New Member
    2006 Tundra
    2" leveling kit with 285/70/17s
    Nope, not yet.
    I have to get my lift on first.
    TXMiamiFan[QUOTED] likes this.
  7. Oct 23, 2019 at 7:42 AM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Any update on these guys?
  8. Oct 23, 2019 at 5:00 PM
    1stgenJim
    2006 Tundra
  9. Oct 24, 2019 at 4:33 AM
    Professional Hand Model
    Fred
    Hand Protectors
    She is one of those rare body breeds that possess the ability to cross over into the Hand Model Field. Love those cuff accessories! And that manicure is to die for!
  10. Oct 24, 2019 at 4:42 AM
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
    O My
    Rica25 likes this.
  11. Oct 24, 2019 at 7:59 AM
    SouthPaw
    2000 Limited 4x4 AC
    Wonder if it's self cleaning tread technology.
  12. Nov 15, 2019 at 2:19 PM
    1stgenJim
    2006 Tundra
    Got the front part of the lift/leveling kit on last weekend, doing the rear tomorrow. Then taking it to Toyota Monday to get the tires put on and an alignment.
    Hope they fit!!!
  13. Nov 17, 2019 at 1:53 PM
    1stgenJim
    2006 Tundra
    So I've got the rear done and went back to check tire clearance on the front after driving it for a week hoping it settled down a bit.
    285/70/17 on stock rims and they rub the upper control arms. Guess I should have done more homework before I bought my tires.
    I've run spacers on landcruiser but everything I read here says dont.
    Any input on this?
    Supposed to have toyota mount and do an alignment tomorrow.
    Rica25 likes this.
  14. Nov 17, 2019 at 2:25 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Run spacers. Same as running a wheel with less offset with the exception that you have more opportunity to lose wheel concentricity and you have 6 more lug nuts to tighten and check. My opinion is get hub centric spacers, use thread locker, mark the lugs with torque check marker, and check them often. I run them on my prerunner without issue and I'll run them on the back of my tundra after I make clearance for the tires.
    revtune and Rica25 like this.
  15. Nov 17, 2019 at 2:56 PM
    1stgenJim
    2006 Tundra
    1.25 spacers would be what I'd want if any.
  16. Nov 17, 2019 at 3:01 PM
    KarmaKannon
    Utah
    Some junk
    That's what I ran on the front of my Tundra before I built the suspension. I think they were trail gear. Seemed nice to me.
  17. Nov 17, 2019 at 3:03 PM
    TUNDRA375
    TUNDRA375 New Member
    GA
    2021 TRD PRO LUNAR ROCK
    Its deep I see...:censored:
    Rica25 likes this.
  18. Nov 17, 2019 at 9:05 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    Check out a brand called KSP. I’m pretty sure they have 1.25 and 1.5. Either size is fine on a first gen tundra. They are hub centric with a 106 hub bore. I run 1.5 on all 4 wheels on my 06 with 285/70/17 and the tires are almost to the edge of the TRD flares.
  19. Nov 17, 2019 at 9:12 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    KarmaKannon likes this.
  20. Dec 25, 2019 at 1:48 PM
    #50
    1stgenJim
    2006 Tundra
    After the lift and tires
    Volt92, bmf4069, TX-TRD1stGEN and 4 others like this.
  21. Dec 25, 2019 at 7:09 PM
    #51
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    How do you like them?
    Rica25 likes this.
  22. Dec 28, 2019 at 3:42 PM
    #52
    1stgenJim
    2006 Tundra
    So far so good. Still a bit of rubbing even with 1.25" spacers.
    You can feel/hear them when you first start rolling from a stop but not very loud when up to speed.
