Opened up my Headlights
Discussion in 'Lighting' started by Rebel Tundra Man, Nov 11, 2019.
  1. Nov 11, 2019 at 8:31 AM
    Rebel Tundra Man
    Rebel Tundra Man [OP] New Member
    Tyler
    Western Kentucky
    2016 Black Limited CM
    4" RCX Lift, 20x10 Fuel Coupler's, 35x12.50x20 Nitto Ridge Grappler's, Color Match Front End, LED Bulbs, RCX Tube Steps, Green LED Underglow
    Hello everyone,
    I have a 2016 limited truck, and I wanted the factory LED DRL under the headlight. I came here to share my experience of opening up my housings as most post's I have read, everyone experiences something different or learns something different while doing so to hopefully share with the rest of our people here.
    I have an electric oven, these are the settings that worked for me:
    -210 degrees (wait for preheat to go off)
    -Air/speed bake to circulate the air in the oven (if your oven has this option, some do not)
    -15 mins bake time
    -cardboard on the rack
    -housing was put in lens down
    Something I realized after getting them apart was using an exacto knife or something there of to cut the permaseal that lapped to the outside between the lense and the housing. I watched a guy on youtube use a flat head screwdriver and that's what I used and also a paint can opener to work the glue loose, but a knife blade would give a cleaner seal break I believe.
    I have more updates to come, I will keep this updated as this project progresses.
    Rica25, Ostrich, jewsNbrews and 3 others like this.
  2. Nov 11, 2019 at 9:53 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Awesome! You going to throw some projectors in there while your at it?
    Rebel Tundra Man[OP] and Pudge like this.
  3. Nov 11, 2019 at 9:59 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    This^ the hard part is done
  4. Nov 11, 2019 at 10:26 AM
    Danimal86
    Daniel
    Sacramento, CA
    Truth!
    Also, TRS has some good black friday sales, if you can keep them open for a couple weeks
    Rica25 likes this.
  5. Nov 11, 2019 at 12:09 PM
    Rebel Tundra Man
    Tyler
    Western Kentucky
    Yes, I can stand for them to be open for a while, these are the spare set I purchased off a guy with a platinum that replaced his with the '18 LED ones. Only gave $175 for them. I haven't decided forsure if I want to put projectors or not. I talked about it for a while but I'm still not sure. I know I'm going to do the BHLM like @graves037 did on one of the sets he had, I dropped the link below to his light build. I also purchased the clear corner reflectors from klearz.com as I cant stand the orange reflectors. I will get more pics this afternoon. I'm kinda new to the projector stuff but I'm still not opposed to doing them if anyone has any info they would like to share with me about them.
    https://www.tundras.com/threads/2016-bhlm-complete.16889/
    BlueRibbon4x4 likes this.
  6. Nov 11, 2019 at 12:30 PM
    Pudge
    CT
  7. Nov 11, 2019 at 7:57 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Yo bro! Nice job! If ya have any questions regarding projectors, I can probably answer them. I strongly recommend them. I did exactly as you did, opened my lights up, painted, then resealed. Only to open them back up and add projectors. The light output is incredible, and have awesome cutoff.
  8. Nov 12, 2019 at 9:43 AM
    Rebel Tundra Man
    Tyler
    Western Kentucky
    So I guess I should start by asking Which projectors are the best to use. I'm usually an ebay and Amazon guy and I don't mind using cheap product and doing extra work myself. But the projector game is all new to me. I really want Green Halo's but I have not found much info on anyone that tells what they bought or used for me to even search for parts.
    BlueRibbon4x4[QUOTED] likes this.
  9. Nov 12, 2019 at 10:02 AM
    Danimal86
    Daniel
    Sacramento, CA
    Theretrofitsource.com
    They have everything you need. Some projectors will be easier to install than others.
  10. Nov 12, 2019 at 10:44 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I would definitely do projectors. I have Profiles in my retrofits. No comparison to the OEMs
  11. Nov 12, 2019 at 11:08 AM
    Rebel Tundra Man
    Tyler
    Western Kentucky
    I know they have everything needed but trying to read through that stuff is like Spanish to me. Id rather buy something that comes with everything needed together because I don't know what fits what, or what all is truly needed to complete the set. Nor does the info tell you, its like you have to already know everything you're looking for before you go to their website.
  12. Nov 12, 2019 at 7:50 PM
    BlueRibbon4x4
    Geno
    Yo man. Go to theretrofitsource.com. Look up projector retrofit kits, grab the Acme kit. On that page, you can choose your halos, the main harness (which will make everything pretty much plug and play), and the shrouds, which are the covers around the projector. It’s inexpensive, and good products. That’s seriously all you need. I can help with hooking up halos or anything else you go with, or there’s actually a write up on here for both building retrofits and hooking them up. Do a little homework, they’re worth it.
    Pudge likes this.
  13. Nov 12, 2019 at 8:07 PM
    BlueRibbon4x4
    Geno
    This is what your page will look like. You’ll need to order the halos separately if you want green ones. You can change the shrouds, use google to see what they look like.
  14. Nov 13, 2019 at 5:55 AM
    Rebel Tundra Man
    Tyler
    Western Kentucky
    Thanks guy, I will look into it some more, I have did quite a bit of homework on it too. What about LED bulbs, can those be used instead of HID's? not a big fan of HID's anymore now that I've had both.
  15. Nov 13, 2019 at 12:35 PM
    BlueRibbon4x4
    Geno
    There are led projectors you can get. Not really a great idea to put leds in hid projectors.
  16. Dec 2, 2019 at 9:20 PM
    Rebel Tundra Man
    Tyler
    Western Kentucky
    Finally got everything back from being painted and started putting my truck back together tonight. Here is the finished product of the headlights.
    georgiey22 and BlueRibbon4x4 like this.
  17. Dec 27, 2019 at 8:42 AM
    Shephard_Of_The_Tundra
    Shephard_Of_The_Tundra DIY try guy
    Corpus Christi, TX
    2016 Black Tundra SR5 4.6 DC 2WD
    Morimoto 2 stroke H4 LED Headlight Bulb VLEDs 3157ck Amber Triton V6 TurnSignal Auxito LED reverse bulbs OEM Toyota LED smoked fog lights Auxito LED T10 license plate bulbs Auxito LED T10 Side marker headlights LASFIT LED T10 3rd brake light Xenon Depot T10 LED Bed/Brake Lights TRD Off-Road Black/Chrome Wheels Bridgestone Duellers 255/70/R18 Front & Rear TRD Sway bars MBRP Dual side exhaust exits Drop-in K&N air filter TRD air flow accelerator Toyota Rubber floor liners OEM Rear under seat storage box Kenwood DMX7706S head unit TRD Shifter knob Center console organizer tray Dual USB fast chargers center stack
    What did you use to re seal them?
  18. Dec 27, 2019 at 11:47 AM
    Rebel Tundra Man
    Tyler
    Western Kentucky
    I bought a roll of butyl but I ended up jus treheating the permatex and then packing it tight with black silicone
