Platinum Grill....is the center removable?
Discussion in '2.5 Gen Tundras (2014-2021)' started by joem1cha3l, Jan 4, 2017.
  1. Jan 4, 2017 at 4:32 PM
    joem1cha3l
    joem1cha3l [OP] New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    I know on my SR5 grill, the center would pop out for inserts.
    My truck was in the shop and the TRD grilles are actually on back order. I didn't believe it but confirmed with Roman. I need to get the thing done and I was on the fence about the TRD grill and the DB Customz grill anyway.
    Shop is throwing a platinum grill on me for now so I can have the color matched surround. Will the center section on this remove for this insert? Going to order it in color matched lettering (blazing blue pearl).
  2. Jan 4, 2017 at 4:34 PM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    I really like that custom grill. Everyone has the TRD PRO grill and you'll stand out more with that.
    Looks like these guys got their idea from @csuviper :D
    bigoltater and SouthBoundSteve like this.
  3. Jan 4, 2017 at 4:45 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    @boardude has that grille right? I think I remember reading it wasn't a simple swap out but was possible.
    boardude likes this.
  4. Jan 4, 2017 at 4:48 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    What color would you do the "Toyota"?
  5. Jan 4, 2017 at 4:49 PM
    joem1cha3l
    Albany, NY
    I am actually going back and forth right now with DB trying to figure that out haha.
    Either color matched blazing blue pearl or I was thinking maybe silver? The BOSS coilovers going in are going to be silver and visible....
  6. Jan 4, 2017 at 4:50 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Never mind just read it.
  7. Jan 4, 2017 at 4:52 PM
    scurdyness
    scurdyness One thing is sure, uncertainty is certain
    William
    Fort Smith, AR
    2017 MBM Platinum_BlackOps
    TRD CAI, TRD Dual Exhaust, TRD rear sway bar, TRD shift knob, T-Rex Sport grilles upper and lower, full window tint and brow, de-chromed, powder coat OEM wheels, blue LED interior, Winjet Tails, Retrofit headlights
    The shop that did mine had to 'break off' all the tabs to get it off...as per T-Rex destructions, oh well I did not like it anyways....
    Too many TRD Pro grilles around for my liking....I need to be different!
    and before.....
    BlueFalconActual likes this.
  8. Jan 4, 2017 at 4:53 PM
    joem1cha3l
    Albany, NY
    Ah, this is a bit scary.
  9. Jan 4, 2017 at 5:01 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I just read boardude's build and he only says it was a PITA. Is the DB costing you more? Just fricken do it! It'll look so good.
  10. Jan 4, 2017 at 5:02 PM
    joem1cha3l
    Albany, NY
    $609 shipped....but its a sick grill. what do you think on the color joon?
  11. Jan 4, 2017 at 5:05 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I personally think blue letters might be too much. Kinda like the silver idea. But we need @photoshopmaster to work some magic.
  12. Jan 4, 2017 at 5:07 PM
    joem1cha3l
    Albany, NY
    i feel like the blue is dark enough to where the lettering might get "lost"
  13. Jan 4, 2017 at 5:07 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Can't they give you a little discount since they won't need to buy the pro grille?
  14. Jan 4, 2017 at 5:09 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Damnit I want one now. :annoyed:
  15. Jan 4, 2017 at 5:25 PM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    This is not a simple swap. It requires you to cut out the middle section of the grill insert and then drill it into the sides similiar to a grillcraft install. You will also need to drill into the grill surround on the bottom as the grill extends a little lower. Was kind of a PITA but I wasn't willing to cut up a Pro grill so I drilled it into the side of the surround which made it a little tougher.
    edwin729, joonbug and GNTundra like this.
  16. Jan 4, 2017 at 5:33 PM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    ^^HAHA, its really not that bad.
    I would say just do it! The grill looks amazing and they can customize however you like with different colors, fonts and sayings. The one thing that I like is the middle section unbolts so I am going to see if I can get a second custom mid section made and then swap them out whenever. I posted some install pics on another thread too and trying to find those.
  17. Jan 4, 2017 at 5:38 PM
    joem1cha3l
    Albany, NY
    @boardude is it something thats relatively easy to figure out? I can have someone much more patient give me a hand. I just dont want to look at it and no idea if I'm cutting the right parts or not lol
  18. Jan 4, 2017 at 5:43 PM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Yeah its really not that bad.. I think it would be easier with the grill insert cutout which would give you more room to work with on the sides. I removed the insert completely and drilled into the surround. Once you have the sides drilled in then you just drill the bottom into the surround.
    Sunnier likes this.
  19. Jan 4, 2017 at 5:47 PM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Found them. Here are a couple pics of the install.
    Side:
    Bottom:
    Sunnier likes this.
  20. Jan 4, 2017 at 6:04 PM
    joem1cha3l
    Albany, NY
    Ok so Im literally just cutting that entire center section out. Just leaving the surround. The drilling should be relatively easy because you're just drilling where the mount points/tabs are on the DB grill, right? Like your not measuring and shit
    Sunnier likes this.
  21. Jan 4, 2017 at 6:05 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    That doesn't look too bad. Looks doable Joe. DO EEEET!!
  22. Jan 4, 2017 at 6:25 PM
    joem1cha3l
    Albany, NY
    I'm close.....I just wish I knew what a plastidipped platinum grill looks like before I order this thing lol
    I basically hate the look of the platinum grill though other than the color matched surround
    hmm....one more thought.
    black wheels, blacked out badges, black spider headlights and I'm doing a black vinyl roof wrap
    Should I go black "tundra" lettering?
  23. Jan 4, 2017 at 6:27 PM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Well if you want to drill directly into the surround like I did the grill insert is just held in with a dozen tabs or so which you can pop it right out. Although I think it was intended to drill into the sides of the existing grill insert once you cut away enough of the mid section. The guy at dbcustomz (I think his name is David) is super nice and willing to walk you through it. I would call him up and tell him the model and grill that you have and he can probably explain the best method of installing it on your grill.
    Edit: No measuring and shit required
  24. Jan 4, 2017 at 6:28 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    No! You won't see it.
  25. Jan 4, 2017 at 7:41 PM
    Lars
    Lars Trail Communicatons Expert
    Lars
    Cedar Creek Texas
    2010 Tundra TRD RockWarrior
    It would be fun if you could get some amber "EL Tape" and light the Tundra.
    I suggest amber because I believe all 50 states allow amber light to be projected anywhere on/around the vehicle without restriction. :)
  26. Jan 4, 2017 at 8:07 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    They actually sell a backlit one. Joe... get the lit one!
    Sunnier likes this.
  27. Jan 5, 2017 at 1:52 PM
    joem1cha3l
    Albany, NY
    i actually dont care for the backlit one.....just seems too "ricey" to me....
  28. Jan 5, 2017 at 1:53 PM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    And very pricey
  29. Jan 5, 2017 at 5:09 PM
    joem1cha3l
    Albany, NY
    Jesus I need to stay off of this site. Its literally costing me thousands lol....but I finally pulled the trigger
    FireAC, boardude and joonbug like this.
  30. Jan 5, 2017 at 5:14 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Gonna look BA. Damn I just figured out m1cha3l.
    joem1cha3l[OP] likes this.
