Tire pressure
Discussion in 'Wheels & Tires' started by Theghost37, Dec 26, 2019.
  1. Dec 26, 2019 at 6:10 PM
    Theghost37
    Theghost37 [OP] New Member
    Michael
    Downeast Maine
    2008 Tundra TRD 4x4 5.7
    So I just got new tires yesterday!
    Cooper Discovery AT3 ten ply
    The door jam says 30 psi
    The tires say 80 psi
    Tire installer said 70 psi
    So what do you think I should have for psi in these new tires?
  2. Dec 26, 2019 at 8:03 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    http://us.coopertire.com/safety/safety-tips/proper-tire-inflation
    The recommended inflation pressures for tires are specified in pounds per square inch (psi) or kilopascals (kPa) as indicated on the vehicle tire placard, certification label or in the owner's manual. Never set tire inflation pressures below the recommended inflation pressure found on the vehicle tire placard, certification label or owner's manual. Underinflation causes excessive heat build-up and internal structural damage that may lead to a tire failure, including tread/belt separation, even at a later date. Do not exceed the maximum inflation pressure shown on the tire sidewall. Overinflated tires (over the maximum molded on the tire sidewall) are more likely to be cut, punctured or damaged by sudden impact from hitting an obstacle, such as a pothole.
    Proper Inflation is Critical
    Inflation pressure enables a tire to support the load and to control the vehicle, therefore proper inflation is critical. With the right amount of inflation pressure, the vehicle and the tires will achieve their optimum performance. In addition to tire safety, this means your tires will wear longer and improve vehicle fuel consumption. Note that some vehicles may have different cold inflation pressures for tires on the front and rear axles.
    Operating a vehicle with just one tire underinflated by 8 psi (56 kPa) can reduce the life of the tire by 9,000 miles and can increase the vehicle's fuel consumption by 4%.
    Tires driven even a short distance while underinflated may be damaged beyond repair. Running a tire underinflated is like running the vehicle's engine without enough oil or coolant. It may seem to work fine for a time, but serious permanent damage has occurred. Adding oil or coolant won't repair engine damage, and adding inflation pressure won't fix tire damage. The tire will remain seriously damaged and can still fail, even after inflation pressure is corrected.
    It is impossible to determine whether radial tires are properly inflated just by looking at them. You must use a tire gauge to properly check the inflation pressure. Motorists should have their own gauge and keep it in the vehicle.
    Checking Tire Pressure
    Check your tire inflation pressures, including the spare, at least once a month and before going on a long trip. Tire pressure should be measured when tires are cold - that is, they have not been driven on. Otherwise, your tires may have heated up, increasing the inflation pressure inside them by several pounds. This is normal. Never "bleed" or reduce the inflation pressure in a hot tire.
    Remember that tires lose pressure when the air temperature gets colder (about 1 psi or 7 kPa for every 10°F drop in temperature). Tires may also lose a certain amount of pressure due to their permeability (about 2 psi or 14 kPa per month).
    Failure to maintain correct inflation pressure may result in rapid wear and uneven tread wear, improper vehicle handling and excessive heat buildup, which may result in tire failure. (Evidence of a continuous leak or repeated underinflation requires tire removal and expert inspection.)
    Tire Pressure Monitoring Systems (TPMS)
    It is still important to check inflation pressure at least once a month, even on vehicles that are equipped with a TPMS. Tire pressure monitoring systems are designed to be beneficial and accurate. However, a TPMS should not be solely relied on for inflation pressure maintenance since some systems may have limitations, such as:
    • Lack of warning of low inflation pressure until one or more tires are as much as 25% below the vehicle manufacturer recommendations.
    • May only detect inflation pressure differences between tires (in other words, if all tires are losing inflation pressure at the same rate, it is possible that the TPMS will not adequately warn of inflation pressure loss).
    • May not warn of rapid inflation pressure loss in a single tire.
    Underinflation (prior to a TPMS warning) is increasingly dangerous at high speeds, heavy vehicle loads, extended distances and at high ambient temperatures.
    Tire Inflation with Nitrogen
    One of the most important factors in tire care is maintaining proper inflation pressure, regardless of the inflation gas. Nitrogen is an inert (non-flammable) gas - basically, nothing more than dry air with the oxygen removed (air contains about 78% nitrogen). Nitrogen inflation does not harm tires nor does it affect the warranty.
    Proper tire inflation, whether nitrogen or normal air, helps tires wear longer, saves fuel, and helps prevent accidents. Under inflation, regardless of the inflation gas, can make it harder to steer and stop your vehicle, result in loss of vehicle control, cause sudden tire destruction, and lead to serious injury or death. Nitrogen and air can be mixed in any and all proportions. Nitrogen filled tires can and should have air added whenever nitrogen is not readily available, to maintain proper inflation as specified by the vehicle manufacturer.
    Blue Thunder likes this.
  3. Dec 26, 2019 at 8:07 PM
    What size are they? I run my 285/70/18 Ridge Grapplers at 44 psi.
  4. Dec 26, 2019 at 8:09 PM
    BROGAN
    BROGAN FNG
    Logan
    East TX
    2015 TRD Pro CM Inferno Fast
    Just ceck out build thread in sig
    42 front. 44 rear. Nitto Ridges 35x12.50s. Passed the chalk test.
  5. Dec 26, 2019 at 8:50 PM
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    Run 285/70r18 Ridge Grapplers. Called Nitto and they spec the tire to be ran at 34 psi front and 32 psi right for a 3rd Gen crew max.
  6. Dec 26, 2019 at 11:17 PM
    AZBoatHauler
    So.Arizona
    :eek: 70 would be beyond firm. I like 40-43 under normal conditions.
  7. Dec 27, 2019 at 2:32 AM
    Theghost37
    Michael
    Downeast Maine
    Yes way to firm
    There stock tire size but ten ply
    I’m gonna drop 15 psi today see how it feels until I get actual correct pressure
  8. Dec 27, 2019 at 2:44 AM
    Zero One Actual
    I have Cooper AT3 XLTs in 285/75R18 and run at 40 PSI.
    If you really want to nail down what you need do the chalk test. Go to YouTube and search vehicle tire chalk test.
    https://m.youtube.com/watch?v=MIvbFgrH0IQ
  9. Dec 27, 2019 at 3:11 AM
    Theghost37
    Michael
    Downeast Maine
    Wow alright so I’m really over inflated.... geesh the installer the other day was sure about 70 psi but it’s so stiff
  10. Dec 27, 2019 at 3:12 AM
    Theghost37
    Michael
    Downeast Maine
    Oh yea I ordered front skid plate can’t believe I waited so long without one
    RCI
  11. Dec 27, 2019 at 3:57 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    AND.....you're on a 10 ply tire!!!!!!!
    I'm on 275/60/20 Nitto Terra Grapplers, four ply. 44 psi front and 44 psi rear is the exact right spot for me.
  12. Dec 27, 2019 at 3:59 AM
    Sunfish
    Sunfish New Member
    17 4X4 CM Limited
    45 Cold is what I run in my old truck with 10 plys. Anymore than that be sure to wear the seatbelt other wise you might bounce out the window
    georgiey22 and Theghost37[OP] like this.
  13. Dec 27, 2019 at 4:40 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    Theghost37[OP] likes this.
  14. Dec 27, 2019 at 6:20 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Don't forget to air Down when off-roading, I like 15...
    Luck and enjoy those Toyotas. : ^ ))))
