left turn signal blinking faster than normal
Discussion in '2nd Gen Tundras (2007-2013)' started by chop123, Dec 25, 2019.
  1. Dec 25, 2019 at 3:35 PM
    chop123
    chop123 [OP] New Member
    clifton
    2007 dark green tundra sr5
    The last couple of days my left turn signal has been blinking faster than normal,the right one is normal.I have a 2007 sr5 4.7,with 135,000 miles on it.Thanks
  2. Dec 25, 2019 at 3:38 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    It may be hyper flashing because one of the left blinkers has died.
    G10dra and JimboSlice413 like this.
  3. Dec 25, 2019 at 3:49 PM
    liddown
    liddown New Member
    ^^^^^ Yes ^^^^^ Either the front or rear blinker bulb is burned out....
    fuzzamungus likes this.
  4. Dec 25, 2019 at 4:03 PM
    Vince
    Vince New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    :amen::spending: that is it my friend.
  5. Dec 25, 2019 at 4:28 PM
    Yodder J
    Yodder J New Member
    Northwest Arkansas
    2011 Silver Tundra SR5 4WD DC
    DAP Tune, Truxedo ProX15 bed cover, WildPeak AT3s
    it's a bulb
    FrogmanTundra and tenntundra like this.
  6. Dec 25, 2019 at 5:31 PM
    Tiamat
    Tiamat New Member
    2015 tundra crewmax xp
  7. Dec 25, 2019 at 5:47 PM
    Iowa12tundra
    Iowa12tundra New Member
    2012 tundra crew
  8. Dec 25, 2019 at 5:48 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I'm not sure why no one has suggested this, but I'd say check out the bulbs.
  9. Dec 25, 2019 at 6:24 PM
    Theyfzman
    Theyfzman New Member
    Pa
    08 TRD
    Prob just a bulb
  10. Dec 25, 2019 at 6:33 PM
    19TundraPlatinum
    19TundraPlatinum New Member
    Maryland
    2019 Tundra Platinum Magnetic Gray Metallic
    5% Window tint Ceramic coating Weather tech mats Color matched mirror caps and door handles Oem black exhaust tip Blacked out 4x4 badge and added black tundra tailgate insert
  11. Dec 25, 2019 at 6:35 PM
    Zero One Actual
    Bulbous glass being burnt out from your attitude. Fix it.
  12. Dec 25, 2019 at 6:37 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    What's the question? :confused:
  13. Dec 25, 2019 at 6:44 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    As it hasn't been overstated, it's a bulb
  14. Dec 25, 2019 at 6:56 PM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    It's not a bulb. Just need a new Tundra.
    Zero One Actual and Pinay like this.
  15. Dec 26, 2019 at 5:09 PM
    Theyfzman
    Pa
    08 TRD
    The bulb it self is probably still good just put a new heavy duty filament in it and you will be blinking sloooow !
  16. Dec 26, 2019 at 5:11 PM
    Mwray8909
    Mwray8909 New Member
    Chino Valley
    18 TRD offroad cement CM
    :hattip:No check your blinker fluid before you check the bulb.:anonymous:
