Creaking sound
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by georgiey22, Dec 21, 2019.
  1. Dec 21, 2019 at 7:01 PM
    georgiey22
    georgiey22 [OP] SW Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    Odd situation. In the year since I drove the truck off the lot it has a small creaking sound. It’s not a big deal but would like to find it. It sounds like it is coming from the base of the windshield. Therefore I would assume it is the windshield cowl but nothing is obvious.
    So far I’ve eliminated the loose bolt behind the glove box theory. Also, lubed the bolt/bushing behind the grill that others have said is squeaky.
    Any other ideas or solutions out there?
  2. Dec 22, 2019 at 4:52 PM
    No Limit
    No Limit New Member
    Alberta
    2020 Tundra TRD PRO 4” Readylift
    My 1 month old 2020 PRO has a little creaking sound coming from the passenger side on rougher roads. The colder it is outside the more noticeable it is.
    Dealer traced it to the passenger side A pillar trim. First try they shaved some plastic off on the inside that they thought was rubbing down at the base of the windshield but that didn’t cure it so now they ordered a new trim piece.
    Hope that helps
    georgiey22[OP] likes this.
  3. Dec 22, 2019 at 7:22 PM
    georgiey22
    Thanks for chiming I’m. I spent another hour poking around in the engine bay last night and I solved the mystery. Feels good to repair stuff on your own sometimes!
    1: The windshield washer fluid hose that runs along the interior of the inner engine bay fender on the passenger side is moving and tapping the fender. Adhered a small white rectangle adapter to the inner fender and zip tied the hose so there is no longer a tap and the hose can’t move. See the first photo?
    2: The ‘louder’ creak was coming from the area that I thought was the passenger side windshield cowl and what looks to be the A/C lines or break lines, along the firewall. They each sit in a plastic bracket that is designed to keep them from moving, bending or touching each other. When I applied a little pressure to them, they all replicated the creaking sound. I generously hit each of the fixed mounts with Blaster spray dry lubricant ($5 @ Lowe’s) and the creak is gone. See photo 2? Drove around all day today with a big grin on my face.
    Hopefully this can help someone else.
  4. Dec 22, 2019 at 7:25 PM
    georgiey22
    Thanks for sharing the idea No Limit. Best of luck with your creak.
  5. Dec 22, 2019 at 9:33 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    That is extremely helpful and a nice easy fix. Thank you!
  6. Dec 24, 2019 at 8:24 AM
    georgiey22
    @Atomic City Tundra
