Fuel filler neck seal question.
Discussion in 'General Tundra Discussion' started by cornwall325, Nov 15, 2018.
  1. Nov 15, 2018 at 8:54 AM
    cornwall325
    cornwall325 [OP] Work in Progress
    2018 Tundra TRD Offroad Limited Crewmax
    There is a visible gap around the fuel filler neck area. Please see the attached picture. Is this common on the 2018 year?
  2. Nov 15, 2018 at 9:05 AM
    Mines towards bottom like that, believe some members say it's normal
  3. Nov 17, 2018 at 11:32 AM
    Jeremylee
    Jeremylee New Member
    Jeremy
    Tundra limited TRD
    Mine has the same gap at the top.
  4. Nov 17, 2018 at 1:00 PM
    wigsplitter
    wigsplitter New Member
    DFW Texas
    2018 SR5 TSS Crew Max
    my 2018 is the same as well
  5. Nov 18, 2018 at 1:55 AM
    rsgt
    rsgt New Member
    2019 crew cab TRD sport 4x4
    all stock
    2019 has it as well. I just put some gas in it ,the neck moves when the nozzle is in. Feels kind of cheap.
  6. Nov 18, 2018 at 5:45 AM
    Tundra6465
    Tundra6465 New Member
    2015 CM TUNDRA ~ BLUE RIBBON
    Trd dual exhaust, trd shifter, underbody spray, tinted windows
    Is there supposed to be a flap inside the neck where you stick the fuel pump nozzle
    Never seen one that is wide open
  7. Nov 18, 2018 at 10:01 AM
    Tundra6465
    Ugh..wonder if it is in the tank? Might have to upgrade to the 38gal?:sawzall:
    Y0TA PR0 likes this.
  8. May 21, 2019 at 6:50 PM
    shulsy
    shulsy New Member
    Jamey
    Maryland
    2023 Tundra Platinum Hybrid
    I just noticed mine today. Doesn’t seem right though, pretty big gap. I have 38 gallon tank, 2019 Platinum
  9. Dec 23, 2019 at 6:08 PM
    mech_engineer09
    mech_engineer09 Tundra Enthusiast
    Ohio/Pennsylvania
    2020 MGM Platinum
    Ceramic Pro, XPEL Ultimate Plus, Woolwax Undercoating, Diamondback HD, TRD Air Intake, TRD Skid Plate, TRD Front & Rear Sway Bar
    Did you ever find out if this is normal? I just noticed i have almost the exact same gap as you in my 2020 platinum and thought something was wrong so I came on here to look for answers. But this is the only thread that I can find that says anything about this.
  10. Dec 24, 2019 at 1:34 AM
    CementGen3
    CementGen3 Gas station Attendant
    Will
    Western WA
    2018 Cement SR5 CM 4x4
    TRD Dual Exhaust TRD rear sway bar Method Wheels Vex 311
    Looks similar to mine. I have a 38 gal tank also.
    mech_engineer09 likes this.
