ReTraxPro XR install today on my 2020 Platinum.
Discussion in 'Tonneau Covers, Caps and Shells' started by tech1208, Dec 23, 2019.
  1. Dec 23, 2019 at 6:33 PM
    tech1208
    tech1208 [OP] Old Salt, New truck
    Orlando, FL
    2023 Tundra Platinum 4X4 Blueprint Blue
    I have to say, the company really took there time and had someone go through the install procedures on this item. Whole install took 45 minutes with just me doing it. Only tools needed were Phillips head screwdriver, 14mm socket ratchet, tape measure, and Allen keys provided in the install kit.
    This is the T80841 Pro XR model with T slots for crossbars or strut posts.
    Here is the unboxing of the unit. Two boxes shipped:
    Here is the totality of all hardware provided:
    An up close of a not so clear direction on the pamphlet, the hole with my left finger must go to the right behind where my other finger is:
    Here is the unit in place. I found it easier to assemble up here in the bed, rather than assemble on the floor and lift a large U in place in the bed:
    The last part that was not so clear in the instructions for me, was to use a packing piece as a shim for measurement. Makes much more sense with a real picture for me than the drawing:
    And finally installed with drain tubes:
  2. Dec 23, 2019 at 6:45 PM
    bensky
    bensky PlatinumPro
    Ben
    Utah
    2018 Red Platinum Tundra
    I had the same problem with the packing shim “guide.” Luckily my son was installing it with me and figured it out. You’ll love that cover. The only mod I had to do was add some d-ring door seal under the rear seal so it wouldn’t leak going though the car wash when the water jets blast it.
    YardBird likes this.
  3. Dec 23, 2019 at 6:47 PM
    tech1208
    Orlando, FL
    Thanks, I already love it.
    Randy
  4. Dec 25, 2019 at 7:31 AM
    prerunnerseth
    prerunnerseth New Member
    Apex, NC
    2015 MGM Limited 4x4
    I have the retrax one cr and love it. Have yakima racks on mine.
  5. Dec 25, 2019 at 7:55 AM
    13igtymer
    13igtymer New Member
    2016 toyota tundra crewmax limited
    How much space do you lose with the canister?
  6. Dec 26, 2019 at 2:15 PM
    tech1208
    Orlando, FL
    About 8 to 9 inches.
    Not enough for me to complain.
  7. Dec 26, 2019 at 3:12 PM
    r8rs4lf
    r8rs4lf New Member
    Al
    Tree Juan Hoe
    2015 MGM SR5
    Looks good! That was my second choice as I didn't want to lose the bed space. I went with the MX4.
  8. Dec 27, 2019 at 2:15 PM
    LuggNutz3000
    LuggNutz3000 MGMAnonymous member
    Jerry
    Grand Junction, CO
    2018 SR5 TSS MGM DC
    Mine was delivered the other day! It’s going on as soon as get off of work... in ND.
    YardBird and tech1208[OP] like this.
  9. Dec 27, 2019 at 3:13 PM
    tech1208
    Orlando, FL
    Shouldn't take you too long to do it. Make sure you have a tape measure as wide as the bed. The other tools are basic.
    YardBird and LuggNutz3000 like this.
  10. Dec 27, 2019 at 3:22 PM
    gjcarving
    gjcarving New Member
    Looks great! Are these pretty watertight? Thinking of getting rid of my shell and getting one of these. Thanks.
  11. Dec 27, 2019 at 3:28 PM
    tech1208
    Orlando, FL
    Ran mine through the car wash today. Barely a few drops down the tailgate from the seam. With pressurized water, I'll take that any day.
    YardBird, gjcarving and LuggNutz3000 like this.
  12. Dec 27, 2019 at 5:23 PM
    gjcarving
    Thanks! Sounds like it definitely passes the test.
  13. Dec 27, 2019 at 5:56 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    I installed a Retrax Mx Pro many years ago, I will never own a truck without one again. I get small drips around the tailgate seam in the carwash but it stays bone dry in the rain. It's also a huge plus to be able to safely secure items in the back of the truck and also be able to retract it quickly to move large stuff.
    Not proud of this but they're sturdy
  14. Dec 27, 2019 at 8:33 PM
    LuggNutz3000
    Jerry
    Grand Junction, CO
    2018 SR5 TSS MGM DC
    How thick are the bed rail cap pieces? All aluminum or steel? I won’t be home for a week or two, but I need to add/modify mine for attach points above the cover. Possibly utilizing the stake pockets... trying to get an idea of what I’m in for on ordering material for the project...
  15. Dec 28, 2019 at 12:10 PM
    tech1208
    Orlando, FL
    My bed doesn't have stake pockets, and they make a version for those, so make sure you order one for what you need.
  16. Dec 28, 2019 at 1:44 PM
    LuggNutz3000
    Jerry
    Grand Junction, CO
    2018 SR5 TSS MGM DC
    I didn’t order with them. But I have a small machine shop in my garage and can do just about what ever is needed. My biggest problem is I’m 1k miles away from the truck at work. So I have to order things to be there when I get home off my 3 week hitch. So I rely heavy on the forum to get ideas and specifications.
  17. Feb 14, 2020 at 8:48 PM
    Hhtundra
    Hhtundra New Member
    Have you had any problems with the rolling mechanism?
  18. Feb 14, 2020 at 9:32 PM
    JimboSlice413
    Bakersfield
    No issues of any kind
  19. Feb 14, 2020 at 10:01 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I had a Retrax on my 2005 DC.
    It rattled like crazy on the highway, I hear they don't rattle anymore.
    If y'all wanna class up those drain tubes, I found these parts in the underground sprinkler section of Lowes.
    I just pieced together what would work for me...
    Make it pretty....:thumbsup:
    C53E03AA-7462-4102-9DC9-BA6292984014_zps_26ed638355a08f67581dd3e2f0cdea9f138f010d.jpg
    1BEB8363-D50A-46B7-BC55-866794D34996_zps_0273a98bdb6025d88bde745e689d7b77e9d4f337.jpg
    5131B7D8-52A8-485B-AAEA-B6F0FE8F5E20_zps_f5ce0c9d48c373e3b08b0001e84ae2712f76d844.jpg
    Rockgate likes this.
  20. Jan 25, 2021 at 9:45 AM
    Mike19
    Mike19 New Member
    Chi town
    2019 SR5 CM 4X4 TRD Sport
    TRD Exhaust, Bilsteins 6112/5100, CB Shims 2/1, CB +3 Shackles, Air Ride, RCI Engine and Trans Skid Plates, Cooper AT3 XLT 275/65/20
    Do you have a measurement of the space from the bottom of the canister to the truck bed?
