Any issues with +25 offset wheels and 275/70/18 tires?
Discussion in 'Wheels & Tires' started by ProtoJ, Oct 15, 2019.
  1. Oct 15, 2019 at 4:17 PM
    ProtoJ
    ProtoJ [OP] New Member
    2018 Crewmax TRD Off-Road
    Im close to pulling the trigger on SCS SR8 Wheels. They are +25 offset. I have a bone stock suspension set up. I'm running 275/70/18 KO2's currently on factory off road wheels. I'm worried to death that they will rub and annoy me but I'll get over that. My real question is since the tires will stick out a little less than 2" with these wheels, does the truck handle different good or bad? Also, since these wheels are 3lbs ish lighter, does that help out with MPG, power etc. I'm going to analyze this to death and I need someone to tell me I'm over thinking this and they are just wheels!!
  2. Oct 16, 2019 at 8:29 AM
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    :popcorn:
  3. Oct 16, 2019 at 8:34 AM
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    You're overthinking this. They're just wheels. :thumbsup:
  4. Oct 16, 2019 at 9:11 AM
    ToyotaTundraMike
    ToyotaTundraMike Not A New Member
    2015 Tundra
    I have the same setup. SCS Ray 10’s on 275/70/18. You will lose a little mpg going with the bigger tires but not too bad. Ride change isn’t significant. You will feel a little difference because of the tires. Shouldn’t rub much at all, especially if you remove front mud flap. There’s a fender liner mod you can do as well which completely eliminates the rub.
  5. Oct 17, 2019 at 6:22 AM
    ProtoJ
    Thanks for the insight. I’ve been running the bigger tires on my stock rims so I’m used to that. I was more curious about if it handles different with 2” of offset. Is it harder to park or make tight turns that sort of thing.
  6. Oct 17, 2019 at 6:39 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Ive run a similar combo. You should be fine. The turning radius does decrease a little
  7. Oct 17, 2019 at 6:44 AM
    Jrharvey02
    Jrharvey02 New Member
    I doubt you’re wheels are gonna stick out 2”, with a +25 offset, unless you’re meaning 1” on each side and you’re adding that up to 2”. I’ve been looking into 0 offset and that’s close to 2” each side. You won’t notice the slightest difference with a +25 other than appearance.
  8. Oct 17, 2019 at 8:41 AM
    ProtoJ
    I found a calculator online and I thought it was just under 2”....each side.
  9. Oct 17, 2019 at 8:46 AM
    Jrharvey02
    Could be...I’m toying with +0 and spoke with someone in here running the same wheel and his measurement was 2”...I could be wrong...
  10. Oct 17, 2019 at 9:26 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Makes sense. 25 mm is 1 inch and the wheel is an inch wider on the outside of the hub. And has less backspacing overall
  11. Oct 17, 2019 at 9:55 AM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    Bet it will handle corners better. Or not. Hell, I don't know. Wheels are the one topic that everyone likes to expound upon, but you never really know until you install them. I say do the best research you can, make the decision, but be prepared for the fact that something may not go as planned. I mean, they are just wheels. o_O
    Hbjeff likes this.
  12. Oct 17, 2019 at 10:23 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    It absolutely corners better. I went from 18x9 +20 wheels back to stock and instantly felt the corners get worse
  13. Oct 17, 2019 at 10:35 AM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    Changing from stock wheels (+60) to the SR8s (+25) will push each wheel out ~1". The 275/70's are about 1" taller than stock. If there is rubbing it should be minimal and can be corrected by removing the front mudflap, pushing the front liner forward (if needed), and worst case scenario would be modifying or removing the mudflap behind the tire.
  14. Dec 21, 2019 at 10:02 AM
    ssmith110
    ssmith110 New Member
    Is there a mud flap mod? I just removed mine, but would really like them on. I'm getting a rub on the driver's side. Running 285/65/18 Nitto Ridge Grapplers.
  15. Dec 21, 2019 at 10:07 AM
    MARanger
    MARanger Lost in the woods
    Andy
    Home of Friendly's Ice Cream
    2017 Super White SR5 DC 4X4
    Same size tire on a wheel with+18 offset, you should be fine9D569997-C20F-42BA-B216-D19CF81BECF9.jpg
    2chains and Black Wolf like this.
  16. Dec 22, 2019 at 6:45 AM
    Kanobi13
    Kanobi13 New Member
    Did you have any rubbing up front?
  17. Dec 22, 2019 at 7:46 AM
    MARanger
    Andy
    Slight rubbing at full lock, bent the factory skid plate back a little with a rubber mallet and pushed in the plastic fender well with a heat gun and it eliminated it
  18. Dec 22, 2019 at 11:30 AM
    Kanobi13
    Kanobi13 New Member
    Easy fix did you have tires on before or after the wheels? Reason I ask is I have tires on already no rub and plenty of room waiting on wheels to arrive.
  19. Dec 22, 2019 at 6:25 PM
    MARanger
    Andy
    Put them on at the same time, went from the stock 255 and 18” steel wheels to the 275/custom wheels
  20. Dec 22, 2019 at 7:11 PM
    HighonFirewood
    HighonFirewood Everything can be fixed with a hammer.
    Stage Left. Colorado
    2019 Tundra
    I have Ray10s, +25. 275/70/18. Remove front mud. Cut the bulge on back mudflap (front wheel wells). Zero rub.
    gabewhite likes this.
