TPMS from stock steel wheels to 18" Method Con 6 wheels
Discussion in 'Wheels & Tires' started by KTM1090r, Dec 15, 2019.
  1. Dec 15, 2019 at 7:39 AM
    KTM1090r
    KTM1090r [OP] New Member
    Dean
    2019 Tundra Crewmax
    Anyone know if they will transfer over? Thanks in advance, Dean
  2. Dec 15, 2019 at 7:52 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I thought that the steel wheels' TPMS sensors had a different stem angle than the sensors that fit to alloy wheels, 45* for steel and 20* for alloys. Or is this not entirely consistent?
    TheBeast and Pinay like this.
  3. Dec 15, 2019 at 7:56 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    My bad. I saw stock but not the steel part.
    Wynnded likes this.
  4. Dec 15, 2019 at 7:59 AM
    TheBeast
    TheBeast The Beach
    need new ones I believe.
    Wynnded likes this.
  5. Dec 15, 2019 at 8:00 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    I don't know the degree angles but you are correct.
    Tundra steelie sensors don't fit alloys.
    Is there an alloy wheel out there that the steel wheel sensors will fit? Maybe. But I don't know of any specifically.
    I would be prepared to buy a set of sensors.
  6. Dec 15, 2019 at 8:02 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    No worries, I've never had steelies on my truck and was going on what I'd read here. I've also disabled my sensors so I don't have to deal with them when changing them (I have three sets of wheels/tires).
    Pinay[QUOTED] likes this.
  7. Dec 17, 2019 at 2:52 PM
    KTM1090r
    Dean
    2019 Tundra Crewmax
    They moved over perfectly from the stock 18" steel wheels to the Method Con 6 18" wheels!
    Wynnded likes this.
  8. Dec 20, 2019 at 7:50 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    Interesting.
  9. Dec 20, 2019 at 10:22 PM
    619tundra16
    619tundra16 New Member
    Glad they worked out for you. It was my understanding to get them to work on aftermarket wheels the installer would need to flip the sensors upside down or something to that extent.
    Perhaps that's what they did.
  10. Dec 21, 2019 at 5:01 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    It can get pretty dicey doing that. It can cause the sensor to stick out too far and the tire can knock it out when the lower bead slips over.
