SOLD : Plug-n-play Alpine AMP for 2018 Tundra non-JBL
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by hitech, Dec 20, 2019.
Thread Status:
Not open for further replies.
  1. Dec 20, 2019 at 2:55 AM
    hitech
    hitech [OP] New Member
    Blair
    SOMD
    2018 CM TRD OR Limited
    This is SOLD!!! I have an Alpine KTP-445U amp that I installed in my 2018 Tundra Off Road Limited non-JBL with Nav. The harness that attaches to the amp has all of the necessary wiring already done. All you need to do is remove the old amp under the passenger seat, unclip the old amp harnesses and clip in this one. It replaces the factory amp with something that actually sounds decent. You lose nothing, you gain a lot of volume with better highs/lows, everything of course works as it should. There's also a power wire for turning on an additional amp for a subwoofer. All connections are soldered and shrink tube protected. I can also include the line to RCA converter, but you'll need to splice that yourself. The amp is the easiest part to upgrade and I've already done all of the work. I replaced this amp with an entire new head unit with built in amp and a powered sub. This is a 4 channel amp. Read all of the reviews on this amp, it's a great universal amp. I don't know if this will work with systems that don't have Nav, but I think as long as you have the amp under the passengers seat and you have a 2014+, then it should be fine. $115 shipped CONUS. Thanks. Blair
    PM me for any questions. If interested I take PP or MO.
Thread Status:
