High Mileage Motor Oil?
Discussion in '1st Gen Tundras (2000-2006)' started by tundrainsc, Dec 18, 2019.
  1. Dec 18, 2019 at 8:24 PM
    tundrainsc
    tundrainsc [OP] Happy Tundra 1st Gen
    06 Limited 4.7 2WD
    I jut bought a 2006 Tundra 4.7 with 160,000 miles. It has been regularly service at the local Toyota dealer. It was due for timing belt replacement and the dealer replaced the timing belt.water pump, and serpentine belt last week. I think i am good to drive it awhile now. There is a slight weeping around the bottom of the valve covers. I am thinking of going with high mileage oil at next oil change and see if that slows the weeping. What would fellow Tundra owners think about this. The dealer gave estimate of $500.00 to replace the valve cover gaskets. I will only drive the Tundra about 4,000 miles yearly. Almost all in city driving.
  2. Dec 18, 2019 at 10:08 PM
    Aerindel
    Aerindel New Member
    Montana
    I wouldn't worry about it.
    If I did worry, I would try tightening down the valve cover bolts before anything else.
    Tierhog, revtune, bmf4069 and 3 others like this.
  3. Dec 18, 2019 at 11:03 PM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    Lift, Rims, Bigger Tires, Nerf Bars, Black Out Emblems
    It may or may not help your oil leak. But I am a believer in "high mileage" engine oils. I was skeptical at first but when I first tried them many years ago I noticed less oil consumption between oil changes and less oil seepage from seals and gaskets. First thing I do when I buy a used vehicle is change the oil to"high mileage". Others may have different opinions, though.
  4. Dec 19, 2019 at 12:13 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    I just put "high mileage" engine oil (full synthetic) in my 263,000 mile 1997 T100 with the 3.4L V6 for the first time. Cleaned off the oil seepage. Will need a few thousand miles to evaluate. It does not consume oil and never has.
  5. Dec 19, 2019 at 1:38 AM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    The valve cover bolts are (apparently) notorious for coming loose, perhaps because of the rubber gasket/washers?
    I had some seeping going on too on one side and had read that they come loose, so I went to tighten them and found they were basically all finger tight.
  6. Dec 19, 2019 at 4:24 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    HM oils won't hurt .. but they may also not help if the gasket is too far gone.
  7. Dec 19, 2019 at 4:51 AM
    Professional Hand Model
    Fred
    Hand Protectors
    $500 is a good price as I think I spent about $180 on all new OEM Toy parts to do the VC’s DIY.
    Also, as others have mentioned, you can snug down your bolts. There are 9-10 10mm bolts per side. Mine became loose and I tightened them down 3 times over a two year period to hold off repair, but eventually they needed replacing. Change that PCV valve, too.
    HM oil has worked on my truck to slow some very slight weeps in other places. Keep in mind, HM oil is very detergent and you’ll want to change your oil quicker a few times after first using as the sludge reduction in your engine takes place.
  8. Dec 19, 2019 at 10:49 AM
    This is good advice. I snugged mine down earlier this year. Just be careful, we had another number snap a head off his bolt. The torque spec on these bolts is inch pounds, not ft lbs.
  9. Dec 19, 2019 at 11:08 AM
    tundrainsc
    06 Limited 4.7 2WD
    Thanks, I just read that the proper torque is 53 inch pounds. I will double check that before i begin.
  10. Dec 19, 2019 at 11:11 AM
    tundrainsc
    06 Limited 4.7 2WD
    Thanks, I'll try the torque and HM oil.
  11. Dec 19, 2019 at 12:12 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    I don’t have any scientific data, but I think high mileage oil is mostly hog wash. Just use 5w30 (insert brand) every 3-5k and you’ll be fine.
  12. Dec 19, 2019 at 3:58 PM
    02goes
    02goes New Member
    2002 Tundra Limited 4X4
    I was thinking the same about high detergent oils. How about filling it up with
    10w-30 Diesel oil! I suspect that will have way more than enough detergents and should be changed out at 500 to 1000 miles.
  13. Dec 19, 2019 at 4:02 PM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
  14. Dec 19, 2019 at 5:15 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    I had a buddy that was all into old school v8s and such and that's the only gasket maker he would use besides maybe yamabond. I seem to remember him saying it was especially good at sealing the intake valley to manifold surface on SBCs. Pretty funny how everything besides Chev or dodge was jap crap to him but he liked Toyotas sealant haha.
  15. Dec 19, 2019 at 5:21 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Haha my buddy wanted me to get a custom plate that reads "JAPCRAP", maybe if I use 4s instead of A's I can get away with it.
  16. Dec 19, 2019 at 5:27 PM
    Fred
    Hand Protectors
    For Professional Use Only.
    WVI, georgiey22 and Darkness like this.
  17. Dec 19, 2019 at 6:28 PM
    KarmaKannon
    Utah
    Some junk
    Personally I take messages like that as a challenge.
  18. Dec 19, 2019 at 8:14 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    I like high mileage anything if/when available. I’m also cheap too so I usually run Napa brand synthetic since it’s what our shop buys in bulk. BG MOA or RF7 is also good stuff.
  19. Dec 19, 2019 at 9:12 PM
    Aerindel
    Aerindel New Member
    Montana
    I pretty much categorically dismiss any 'fix' based on just pouring a bottle of something in somewhere....unless the problem is specifically that you don't have enough fluid in said place.
  20. Dec 20, 2019 at 10:13 AM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    I agree. But I don't look at "high mileage" engine oil as a "fix" like pouring head gasket repair in your coolant. It's more like "aid" to help your engine run better. Like my insulin and heart meds. They don't fix me just keep me running better. Every one has their own opinion on oil and I respect that but for someone considering using it I think it's worth a try. It won't hurt your engine but it might help.
  21. Jan 25, 2020 at 7:21 PM
    tundrainsc
    06 Limited 4.7 2WD
    Thinking of starting with high mileage oil as needed to top off rather than changing oil out all at once. Any thoughts on combining high mileage oil with regular oil? I only drive 2 or 3 k yearly. It likely will need .5 qt before next scheduled change
  22. Jan 26, 2020 at 11:29 AM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    It won't hurt to mix them you just won't get the full benefits of the oil until you do a full change. I also switched to using Chevron Havoline oil. Found that Walmart sells these 6 qt. boxes for $15 one day when searching on the internet.
  23. Jan 26, 2020 at 4:48 PM
    specter208
    specter208 New Member
    2017 Tacoma and 2005 Tundra RGCAB
    I have an 05 RCLB with the 4.0 and the timing cover leak. When I got it, the timing cover leaked real bad with small puddles of oil every morning, would be half-way between the dots in about a week. I put in Mobil 1 High Mileage synthetic and it has helped slow down the leak.
  24. Jan 27, 2020 at 7:54 AM
    smokey0810
    smokey0810 New Member
    '03 Tundra SR5 AC 4WD
    After listening to a Carcast podcast a few years back with one of the main guys behind Joe Gibbs racing and their oil, I thought I'd give some HM oil a try. From what I remember, HM oil has Zinc added to it, which is one of the main things an older engine needs to help "restore" gaskets and help the motor. Don't jump my s#!t if I'm not correct on this.
    Been running Valvoline HM in our Odyssey, and a few oil changes ago I switched to Pennzoil Platinum HM Synthetic for the Tundra. Our Mini has been running Mobil One since it was purchased.
  25. Jan 27, 2020 at 1:53 PM
    Fred
    Hand Protectors
    Zinc is actually good for the cams and other metal to metal contact points. HM Oil has the most Zinc in it compared to non-HM Oil.
    Problem with Zinc is if you use too much it can fowl your catalytic convertor. There is a fine balance which I discovered when mediating this past summer. I discovered Zinc was so good that I’d start using Racing Oil with extremely high amounts of Zinc. Then I discovered its not a good idea due to ruination of the Cats.
    Another idea hit me when I read some people delete their cats for better horsepower and can then run Racing Oil because the Zinc has nothing to ruin. Then I read its illegal to delete Cats. Then I read my state doesn’t check for Cats so I read some people do it anyway and the Zinc is super helpful for their engine they reported.
    The high mileage oils also contain ‘seal enhancers’ to ‘recondition’ old shranked up gaskets to slow/stop weeps.
    specter208 likes this.
  26. Jan 27, 2020 at 4:53 PM
    specter208
    R
    redline oil has very high amounts of ZDDP. It’s one reason why it’s not API certified but they guarantee that it would meet or exceed the specification anyway.
