tundra maintenance schedule
Discussion in '2.5 Gen Tundras (2014-2021)' started by 9am53, Dec 13, 2019.
  1. Dec 13, 2019 at 5:30 AM
    9am53
    9am53 [OP] New Member
    adam
    2015 Black RCLB 4x4
    2020 PRO headlights and grill
    I've asked this elsehwere and I cant seem to get an answer, where is the maintenance schedule located for our truck? In my wife's yaris its in the owners manual, but I read mine cover to cover (i'm one of those people) and couldnt find anything. I feel stupid for asking this as it should be obvious, but I really cant find it.
  2. Dec 13, 2019 at 5:40 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Black Wolf likes this.
  3. Dec 13, 2019 at 5:45 AM
    9am53
    adam
    2015 Black RCLB 4x4
    Thanks you!!
  4. Dec 13, 2019 at 8:27 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    Dang just the other day I was looking for the blank pages in the back of my manual to write down all of my maintenance so far. Looks like I’ll have to see if I have that maintenance and warranty guide. Thanks Jason.
  5. Dec 13, 2019 at 8:43 AM
    Bergmen
    Bergmen New Member
    Ukiah, California
    Interesting that this maintenance guide says nothing about changing transmission fluid or brake fluid (in standard operating conditions). I used to replace brake fluid every 24 months but there is no mention of ever replacing brake fluid. Is it considered lifetime?
  6. Dec 13, 2019 at 9:18 AM
    9am53
    adam
    2015 Black RCLB 4x4
    I just read through it and you're correct I didnt see anything about changing brake fluid, however it did mention changing tranny fluid. The reason I wanted to look is because my wifes yaris has a maintenance free tranny. there is no mention of tranny fluid change in the manual, so I called toyota and was told that its good for the life of the vehicle. we have 220k km on it and its clean and full still, heres hoping it does last :)
  7. Dec 13, 2019 at 9:51 AM
    Bergmen
    Bergmen New Member
    Ukiah, California
    Transmission fluid change at 60,000 miles due to: "Driving while towing, using a car-top carrier, or heavy vehicle loading". I can see the need for that but I rarely tow and almost always have no load so I should be good for life.
  8. Dec 13, 2019 at 10:23 AM
    thetaxguy
    thetaxguy New Member
    2019 White SR5 CM TRD OR
    The trans service is a "do it when something is wrong" type of service. Toyota takes the stance that if upon inspection there are no observed issues, a service is not required. We'll have to see how that holds up with the dedicated trans cooler absent on my 2019.
    Can't hurt to do the break flush yearly, and its super easy to do on your own. The last thing you want is for the break fluid to absorb too much moisture from the atmosphere which will lead to corrosion in your system.
  9. Dec 13, 2019 at 10:30 AM
    9am53
    adam
    2015 Black RCLB 4x4
    peronally I used to changed every 100k km (~60k Miles) just because it made me feel good, then I switched to changing when it needed it. Ive never had to rebuild or replace a transmission, fwiw.
    I'll probably continue this program on this truck, however I will change the other fluids regularly (diff, transfercase, coolant, oil brakes)
    Does your 2019 have the 4.10 gears? I didnt know there actually were non-tow package tundys out there in the wild!
  10. Dec 19, 2019 at 3:39 AM
    ddact
    ddact New Member
    2019 5.7L 4WD SR5 DC FFV - Black
    My wifes corolla is the same way. No transmission service recommended. I had the fluid changed at 125k anyway, because we're planning to keep it a long time. Getting the toyota dealer to do it was like pulling teeth though.
  11. Dec 19, 2019 at 4:09 AM
    triharder
    triharder Sorry, Not Sorry
    Jake
    Southern, Maine
    2010 RWB Black
    Billstein 6112/5160's, coachbuilder spacer on driver side/ 20" rockstar wheels/ 33" nitto ridge grappers/SS Brake lines (or as most people write Break), Painted Calipers/Powercoated Tow hooks/pocket flairs/heated seats,bed leds/line-x liner/xtang trifold/tow mirrors/Stereo Work/Compustar Remote Starter/ retrofit Morimoto Minin H1 and switch back LEDs/ plenty I'm forgetting
    I called toyota and asked what they consider "Lifetime" of the vehicle.
    100k.
    Guys on this post might consider doing the same. Call toyota and ask.
    And you will never hurt anything by updating the fluid on a consistent schedule.
    You could however if you wait until something is high mileage and change it then.
    (another great video on this https://www.youtube.com/watch?v=o690DovjDAc)
  12. Dec 19, 2019 at 4:31 AM
    9am53
    adam
    2015 Black RCLB 4x4
    I’m assuming there is a drain? I’ve heard some “maintenance free” trannys dont...if not I am getting a pela pimp for my sailboat’s diesel so I’ll be able to pull it out the dip stick hole and maybe I will change it at 250k km
  13. Dec 19, 2019 at 4:34 AM
    triharder
    Jake
    Southern, Maine
    2010 RWB Black
    No, the drain plug just drains the pan, won't drain the whole system. and no dipstick. They made it hard.
    but i'd use caution at 240K. You're at the point it might be harmful.
  14. Dec 19, 2019 at 4:45 AM
    9am53
    adam
    2015 Black RCLB 4x4
    so how does one drain the transmission fluid?
  15. Dec 19, 2019 at 5:00 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Here's one way.
  16. Dec 19, 2019 at 5:13 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    There is a drain plug on the transmission pan. The term “sealed” is arbitrary.
  17. Dec 19, 2019 at 5:20 AM
    triharder
    Jake
    Southern, Maine
    2010 RWB Black
    there's a ton of information this on this forum
    But I'll bite.
    you can drain through the plug the pan's volume worth of fluid (this only 1/4 the system fluid)
    you need to drain/fill the system through the heat exchanger (before 2019/2020). I don't have a good way on the 2019/2020 to get the fluid replaced at once.
    or you could drain that 1/4, refill that quarter (plug in side of transmission and hand pump) and repeat a few times (5 times to get the fluid replaced, but you'd have to drive in between as you'd have to cycle the fluid.
    try a search. much better information out there for this.
  18. Dec 19, 2019 at 5:25 AM
    9am53
    adam
    2015 Black RCLB 4x4
    I'm talking about my yaris, it doesnt have a tranny cooler.
  19. Dec 19, 2019 at 5:33 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    My moms 2015 Yaris had a normal drain pan/ plug, and dip stick.
    Owners manual had all the info.
  20. Dec 19, 2019 at 5:39 AM
    9am53
    adam
    2015 Black RCLB 4x4
    The owners manual has zero info. I had to call Toyota to find out that I’m not supposed to do anything with it. Good to know there is a drain on it though. I guess I could just drain the pan, too it up and drive a bit and do it again. Not particularly efficient of my time and never really gets everything changed over...
  21. Dec 19, 2019 at 5:44 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    I understand.
    It was at 75K so I got a transmission filter with gasket and fluid from oriellys. Since it’s not used hard like our tundras I am okay with longer intervals. That car is nearly totaled anyway. Mom doesn’t know how to keep anything nice. :rolleyes:
    She’s a hoarder and it looks like she lives out of the car.
  22. Dec 19, 2019 at 6:16 AM
    9am53
    adam
    2015 Black RCLB 4x4
    To my wife her car is just a thing to drive to work. She has no connection to it. I got her a detailing gift certificate for the spring to spruce the car up. I take care of maintenance so everything works well, but it’s gross inside lol
    classiccat likes this.
  23. Dec 19, 2019 at 8:22 AM
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    @Dodger46
  24. Dec 19, 2019 at 3:47 PM
    Dodger46
    Dodger46 New Member
    2019 Silver Sky Metallic SR5 Crewmax
    I’m considering draining the pan and refilling it to send some off to be tested. Toyota won’t void my warranty right?
