High speed braking steering wheel shimmy
Discussion in '2nd Gen Tundras (2007-2013)' started by Dogmatic, Nov 30, 2019.
  1. Nov 30, 2019 at 9:00 AM
    Dogmatic
    Dogmatic [OP] 2013 TRD Rock Warrior 4X4
    My 13 Rock Warrior gets a shimmy when braking, pretty much only higher speed, like 45+, not so much at low speed. Could be brake rotors?
  2. Nov 30, 2019 at 9:09 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    If it only happens when you hit the brakes, look for a rotor or two beginning to warp.
  3. Nov 30, 2019 at 9:18 AM
    UncleJimmy
    UncleJimmy New Member
    I had the same thing. It was just uneven brake wear with really low pads. New brake pads and resurface and I was good to go.
    OR18TRD likes this.
  4. Nov 30, 2019 at 1:33 PM
    Dogmatic
    Cool. Thanks.
    That's kinda what I thought. Hopefully nothing worse.
  5. Nov 30, 2019 at 1:39 PM
    Aerindel
    Aerindel New Member
    Montana
    Warped brake rotors. Common, cheap problem.
  6. Dec 13, 2019 at 3:25 PM
    Dogmatic
    Dont think it's the rotors. No pulsating at the pedal. If cruising at 60+ I feel a slight shaking in the wheel. If I hit the brakes it gets worse, then as speed reduces it goes away.
  7. Dec 18, 2019 at 4:29 PM
    Can still be pads and rotors.
  8. Dec 18, 2019 at 8:01 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    Mmmhm.
    The slight shaking in the wheel at 60 is the tires.
    The wheel shakes gets worse when you hit your brakes because your brakes are bad and the frequency of the shake slows down because the vehicle is slowing down.
  9. Dec 19, 2019 at 6:43 AM
    00TundraZ
    00TundraZ New Member
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    ^^^^This^^^ I believe Scuba is spot on.
    Maybe try a balance and rotate at your local tire shop, might just take that shimmy away. Worth a shot before investing in new tires. If you feel the shimmy before touching the brakes then it likely is not the rotors/pads. It could be, but it's less likely.
    Best of luck!
