Verifying Towing #'s
Discussion in 'Towing & Hauling' started by Getsome13, Dec 12, 2019.
  1. Dec 12, 2019 at 8:27 AM
    Getsome13
    Getsome13 [OP] New Member
    Lee
    Tundra
    Hello All,
    My wife and I love Toyota's. I have personally had almost every brand of truck and worked for several over the years.
    We are trying to get a New (to us) truck, capper, and Travel Trailer. Our current vehicle is a Sprinter 2500 we've lived in full time for almost 5 years. We will be full timing in the new rig, moving once every 3-4 months.
    Here's the #'s
    TRUCK: 2016 Tundra SR5 5.7 6.6” bed 4x2 (4x4)
    Curb Weight: 5,185 (4x4: 5,480)
    GVWR: 6,900 (4x4: 7,100)
    GAWR F/R: 3,900 / 4,100 (4x4: 4,000 / 4,150)
    GCVWR: 16,000
    Payload: 1715 (4x4: 1,620)
    Towing Capacity: 10,300 (4x4: 10,000)
    Estimated Payload:
    Passengers: 350
    Cargo: 150
    Topper: Contractor high roof, barn doors: 200-225
    Total (Minus hitch weight): 725
    Hitched
    Available Payload: 195 (4x4: 100)
    New GVW: 5,910 (4X4: 6,205)
    New GCVW: 14,905 (4X4: 15,200)
    Towing Capacity: 10,300 (4X4: 10,000)
    TRAILER: Grand Designs Imagine 2970RL (33'-34')
    UVW: 7324 (propane / batteries?)
    GVWR: 8995
    Hitch Weight: 795
    This is a big trailer for this truck but "IF" I've crunched all the numbers right we should be ok. I also haven't deducted the weight of removing the tailgate so would pick up a few more pounds in payload to offset propane if it's not figured in.
    Of course I would do exact #'s on exact truck and trailer if we get to that point but wanted to make sure I was on the right track before moving on.
    Thanks,
    Lee
  2. Dec 12, 2019 at 9:05 AM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    That payload of 1715 (4x2) has to be a reg cab 4x2 if it is a '16. My '14 2wd dc had payload of 1520 (iirc) and my '18 2wd has 1420 (iirc) due to the 38 gal tank.
  3. Dec 12, 2019 at 9:30 AM
    Getsome13
    Lee
    Tundra
    so 1520 would put it right at the payload max, then a few under for removing tailgate. Gotta love the internet, it's full of accurate information.
    Still looking for any feedback from anyone on the above #'s and lets say I'm at payload or 50-100 lbs under. I can move the bikes from truck to camper to free up some weight while traveling
  4. Dec 14, 2019 at 9:03 AM
    snowmansimon
    snowmansimon New Member
    Simon
    New Brunswick, Canada.
    2019 Tundra SX Barcelona Red
    Firestone Air Bags, 255/70R18 BFG All Terrains.
    Check your payload on the yellow door sticker if you haven't already. My 2019 SR5 is 1320lb. My 2011 V6 Tacoma was 1208lb and my 2002 4cyl Tacoma was 1480lb. Incredible that these trucks are rated so low. I carry a slide in truck camper and don't even notice the camper on the truck.
  5. Dec 16, 2019 at 8:52 AM
    Getsome13
    Lee
    Tundra
    I don't have a truck yet, I'm looking to buy a new truck and trying to verify everything.
  6. Dec 16, 2019 at 11:15 AM
    djvpinky
    djvpinky New Member
    South-west Ontario, Canada
    2019 trd crewmax
    I would be wary of the listed tongue weight on that trailer. 795 is the unloaded weight. With a GVWR of 8995 the tongue weight would be at least 10-15% or 850-900 lbs. We all say we are going to load light but somehow all that "stuff" adds up. I tow a Jayco 26P with a GVWR of 6,750 at 29 feet and my tongue weight is around 800 lbs. I used to tow it with a 2007 crew max, now a 2019 crew max with no cover, nothing in the box and only the wife and I, We are right at a payload of 1200lbs of the 1320 available. Tows very well but I know it's there. I have been trailering for some time and it is my belief most people underestimate their trailer tongue weight. I manage operations at a large landfill and as I tell a lot of our customers, the scales don't lie. Good luck and happy camping.
  7. Dec 19, 2019 at 6:04 AM
    Getsome13
    Lee
    Tundra
    So after calling around to verify all those Toyota Model #'s it appears the Crew Max 4x2 gives the best Payload for a 2970 RL and the Crew max 4x4 gives the next best.
    Do I remove the WDH hitch weight from the payload? I have seen arugements online both ways. and it appeards they weight 100 bs, correct?
    Thanks
  8. Dec 19, 2019 at 6:09 AM
    18" TRD Off Road Wheels
    General rule for towing: if you have to math this hard to make it "work" then you either need a smaller trailer or a bigger truck. Even if you're within the numbers by 500lbs its gonna be a miserable experience.
  9. Dec 19, 2019 at 6:36 AM
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    I would go with a silverado 2500 or an F250. Their gas engines are solid and they are built for exactly what you want to do. Make sure you get the appropriate gear ratio (4.10) and I am sure you will be happy you went with a bigger truck. The last thing you want to do is get in a scenario where you dont feel safe driving.
    Broncobroke, belanger9 and ColoradoTJ like this.
  10. Dec 19, 2019 at 11:09 AM
    Getsome13
    Lee
    Tundra
    The math isn’t hard it’s finding the actual #s to do the math. The Internet is full of wrong information that you have to sift through.
  11. Dec 19, 2019 at 11:12 AM
    Getsome13
    Lee
    Tundra
    I need a reliable truck for a daily vehicle that will tow a trailer once every 3 months or so.
    Lake.Life24[QUOTED] likes this.
  12. Dec 19, 2019 at 11:25 AM
    Broncobroke
    Broncobroke Super White Power
    Charlie
    Piedmont, NC
    2017 White Tundra 1794
    I have 3 in our fleet with over 100,000 miles and no issues. They are very reliable trucks.
  13. Dec 19, 2019 at 1:37 PM
    Lake.Life24
    Shawn
    Upstate, NY
    That's why I think a Silverado 2500HD with the 6.0 gasser and 4.10 gears would be perfect. You will get the same gas mileage as the tundra. But more stability when towing. Throw a topper on that 6.5' bed and cruise. Don't get me wrong I love my tundra and think its one of the best trucks on the market. That's why I bought one. But when it comes to pulling 80%+ of max trailer or tongue weight I personally think its time to move up to a heavy duty.
    I am not saying a tundra couldn't do what you are asking it to do.
    belanger9 likes this.
  14. Dec 19, 2019 at 3:22 PM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    If you get a lower trim gas HD they are quite reliable. Most powertrain, chassis, and suspension are made for the heavier and more powerful diesel options so they're overbuilt for the gasser application and if you go lower trim you stay away from most electric gizmos that are more likely to fail. A Tundra won't be head and shoulders better reliability wise than a HD gasser if you're ok with going to a lower trim. I've seen dozens of gas work trucks that are beat to crap and not maintained at all just keep on chugging on work sites.
  15. Dec 19, 2019 at 4:17 PM
  16. Dec 19, 2019 at 4:56 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    Toyota is conservative with the numbers. The truck is more than capable and safe at the "limits".
    If you are towing 4 times a year and your numbers are close, YOU WILL HAVE NO PROBLEM with a Tundra. AND, you will enjoy it the other 300 days a year without issue. You are obviously responsible when it come to towing, so use your head, buy a Tundra, and have no regrets!!!
  17. Dec 22, 2019 at 3:45 PM
    usaf.2012
    usaf.2012 New Member
    AK
    2010 Black CM Tundra RW
    10" BAMuffler // Bilstein 5100s all around & front on Mid setting // Toytec shackles // BHLM
    I would double check the bold. The crew max numbers will be the worse. My CM 4x4 payload is like ~1300.
    The WDH will count towards payload. If it is weight on the truck or trailer it will affect payload. I don't know the exact weight but I wouldn't be surprised if my wdh plus trunion bars are close to 100#s.
