  1. Dec 16, 2019 at 7:51 PM
    ScoutTrooper12
    ScoutTrooper12 New Member
    2019 Tundra 1794
    Had 3/1 Ready Lift installed out new shoes on her.. Nitto Ridge Grapplers.
    cjmay13, rebmo, sseaman and 18 others like this.
  2. Dec 16, 2019 at 8:04 PM
    sbxx312
    sbxx312 New Member
    2018 Tundra, 2012 s/c Tacoma
    Easy install? Mine showed up yesterday.
  3. Dec 16, 2019 at 8:10 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    I got my winch control box mounted and the wires ran down to the bumper.
    Next step is getting the winch and light bar into the bumper.
  4. Dec 16, 2019 at 8:26 PM
    Yzed608
    Yzed608 New Member
    Wisconsin
    So this was just me being dumb. When I tightened the straps around the axle housing it shifted the whole skid assembly causing the front wrap-around piece to touch the drive shaft. Loosened the front portion up, re-positioned it and tightened it back down, all good now. Just looks like it scratched the shaft, the skid took more damage. With how loud it was (I had to drive it about 60 miles like this) I'm surprised there wasn't more damage...
    This is after adjusting it. The upper portion where the bolt is is where it was touching the drive shaft. Took it out for a rip to test it afterward, tow/haul in sequential shift is still so fun in this truck.
    ntg and NewImprovedRon like this.
  5. Dec 16, 2019 at 8:41 PM
    AZTundra
    Paul
    Phoenix, AZ
    You forgot a part on top of your engine cover. :facepalm:
  6. Dec 16, 2019 at 8:57 PM
    Leetomnsx
    Leetomnsx New Member
    2016 Toyota Tundra Platinum
    Air lift, black out emblems, wheels, tonneau cover, tires, led lighting, hidden step rail, remote start.
    I was lazy but I did install my remote inside a color matched AJT case.
  7. Dec 16, 2019 at 9:52 PM
    Squatting Pigeon
    Holden
    North Texas
    Did I though? :monocle:
    2018Tundra and AZTundra[QUOTED] like this.
  8. Dec 17, 2019 at 12:06 AM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    Did you torque the studs to 100 lbs?
  9. Dec 17, 2019 at 12:18 AM
    easleycrawler
    Travis
    Easley, South Carolina
    19 TRD SPORT CM MGM 4WD
    I torqued mine to 110 lbs. Checked them after 500 miles, still torqued at 110, never loosened. Make sure you use some blue loc Tite.
    PeakIT likes this.
  10. Dec 17, 2019 at 2:29 AM
    r8rs4lf
    r8rs4lf New Member
    Al
    Tree Juan Hoe
    2015 MGM SR5
    How does that mount?
  11. Dec 17, 2019 at 3:44 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    It uses 2 of the bumper mount bolts, where the bumper bracket mounts to the chassis.
  12. Dec 17, 2019 at 7:31 AM
    Keithbickford
    Keithbickford New Member
    Keith
    Seattle
    2020 Cavalry Blue Tundra
    King 2.5” suspension, Method Race 313 wheels, Nitto Ridge Grapplers 35x12.5x17, TRD exhaust, RCI Skid Plates, Alpine ILX-F309 stereo, Alu-Cab roof top tent on Yakima Overhaul HD, Line-X spray in bed liner, VLED LED reverse light bulbs and VLED LED license plate reverse light. VLED brake/tail light bulbs. VLED third brake light and cargo lights.
    Yes. Very easy. Just some bolts. I put my truck on some ramps to make it easier although they’re not necessary. Then I used a floor jack to lift the skid into place. If you can tighten a bolt, you can install this. Instructions are clear although the rear nuts were not nylon locking nuts as indicated on instructions. Instead they were normal nuts with lock washers. I’m not necessarily a fan of the spacers they use for those with a diff drop. But I’m sure they are fine.
    sbxx312[QUOTED] likes this.
  13. Dec 17, 2019 at 10:27 AM
    solidsnake
    solidsnake New Member
    Colorado Springs
    2017 Lexus RX 350
    Added a universal seat heater for the drivers seat.
  14. Dec 17, 2019 at 10:45 AM
    Keithbickford
    Keith
    Seattle
    Oh damn. So when you have a pretty lady in the passenger seat and you tell her, “I’m really warm over here with my heated seat.” She’s gonna jump out and climb in a RAM truck with bubba.
    aperezsh and Toyota_loyal like this.
  15. Dec 17, 2019 at 12:25 PM
    ryanryan34
    ryanryan34 "Its almost done"
    Olympia WA
    2016 Supercharged Overland Build
    Supercharger, Carven Cat-Back, Rough Country Heavy Duty Front and Rear Bumpers with grill insert, , BDS 3" Suspension Lift, 18x9 XD 820s, Kenda Klever 33x12.5, AJT Designs interior items, De-badged, Tuffskins custom door sills, RCI Skid plates. Victory 4x4 Bed rack and Stiffeners. Roofnest Condor XL RTT
    Added Carven Cat-Back exhaust today. Quite happy
    cjmay13, sseaman, GAknight and 7 others like this.
  16. Dec 17, 2019 at 2:17 PM
    Redrider29
    Redrider29 HARDTRD
    Mitch
    2019 SR5 Crewmax TRD Offroad 4x4 Cement
    Paint matched mirror caps, grill surround, hood bulge, and Bumper Shellz Wireless phone charger in center consule TRD rear sway bar Black painted TRD off road wheels with TRD center caps Black emblems TRD air filter Tyger roll up tonneau cover Extra USB plugs in cab TRD Pro grill Paint matched Bumper Shellz 1.25" Spider Trax spacers Lamin-x fog light covers yellow-removed Diode Dynamics SS3 amber fogs Bilstein 5160 rear shocks DIY bed rail system AJT TSS relocation bracket AJT interior chrome delete bits and pieces Caliraised LED 32" light bar bracket GG Lighting 32" light bar
    Just got these "used" on Amazon...lol. They are brand new and I saved $45 each. They were only $107!! Has anyone installed the reservoir on the frame instead of piggyback? Pics? Bracket? Can it even be done?
    Thanks
    cjmay13, ntg, georgiey22 and 11 others like this.
  17. Dec 17, 2019 at 5:36 PM
    HidetownRed
    HidetownRed Buffalo Hunter
    Top O Texas
    2020 Sky Silver Limited 4x4
    3/1 285/60/20 RG tint and red toes
    Not if she is sitting in your lap:)
  18. Dec 17, 2019 at 6:25 PM
    solidsnake
    Colorado Springs
    2017 Lexus RX 350
    I guess I’m lucky my wife and I don’t know anyone named Bubba or that has a RAM.
  19. Dec 17, 2019 at 6:33 PM
    Flyinryank
    Flyinryank New Member
    Las Vegas, NV
    White 2015 CM 4x4
    Nice deal! My buddy just got them for his Tacoma and they come with frame mounts now. Not sure about tundra though. I’d call bilstein and see or use their black billet clamps. Would be cleaner!
  20. Dec 18, 2019 at 2:12 AM
    Tolebooth
    Tolebooth New Member
    Fernie British Columbia
    2016 Black Tundra TRD Off Road
    Added a double wide sled deck and Firestone Ride-Rite airbags.
    sseaman, Major, Tankstew and 23 others like this.
  21. Dec 18, 2019 at 7:30 AM
    Toyota_loyal
    Toyota_loyal Platinum Pro build in progress
    deb
    Denver, CO
    2020 Platinum CM
    The husband and I debated for over a year Platinum vs 1794. I would've agreed to a 1794 that looks like this! Love it!!
    Cfincke[QUOTED] likes this.
  22. Dec 18, 2019 at 11:01 AM
    BROGAN
    BROGAN FNG
    Logan
    East TX
    2015 TRD Pro CM Inferno Fast
    Just ceck out build thread in sig
    RK Sporthood. Two tone. More pics to come later. Literally just picked it up on lunch break.
  23. Dec 18, 2019 at 12:47 PM
    DCB500
    DCB500 New Member
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    Finally got the leather in and installed today!
    73046095-46E7-420D-A51C-2C75C20C57A9.jpg 78CA98FE-0A08-490F-9035-E3A33C8D35B2.jpg A134CCE7-1A3F-4BE3-8AA8-AF2698C26A82.jpg 1C5102EF-83D4-4AD7-ABB1-B440BCB9F6F0.jpg
    TundraMash, ntg, Newbie_19 and 37 others like this.
  24. Dec 18, 2019 at 2:14 PM
    ARMYGREEN
    ARMYGREEN New Member
    2014 CrewMax MGM
    Picture heavy
    Before
    Parts thanks to @Roman and @iHacker
    After
    Delete Chrome Bulge add MGM Bulge!
    cjmay13, ntg, Newbie_19 and 29 others like this.
  25. Dec 18, 2019 at 4:42 PM
    gears_call
    gears_call New Member
    Orange County, CA
    2014 SR5
    King 2.5's l Method double standards l 35" BFG KO2 l SS Built front bumper/skid/valence l more to come....
    New shoes. 4 very expensive shoes. I’m dumb shoulda done it on Black Friday.
  26. Dec 18, 2019 at 4:42 PM
    DCB500
    DCB500 New Member
    Oklahoma City
    What headlights are those?
  27. Dec 18, 2019 at 5:14 PM
    57customlp
    57customlp New Member
    Vic
    2019 tundra sr5
    Wheels, dual exhaust,
    3/2 level kit. Stock 255/70/18 tires for now. Doesn’t look as bad as I thought with the small tires. E6E2C668-AA89-4C49-AE52-A1C063A0AABD.jpg
    sseaman, mgm16trdpro, NAFlash and 7 others like this.
  28. Dec 18, 2019 at 5:28 PM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    2019+ OEM Black LED.
  29. Dec 18, 2019 at 7:22 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Any luck finding the issue? I’m in the market for an RCI skid. Wondering if you figured it out.
  30. Dec 18, 2019 at 7:39 PM
    Yzed608
    Yzed608 New Member
    Wisconsin
    Yep I figured it out, nothing to do with the RCI skids as far as I can tell (could have been the ton of dirt/gravel I got out from the skids vibrating, see below). Grinding sound I got after tightening the skids was because I'm dumb and the rear diff skid was rubbing on the drive shaft.
    BlueRibbon4x4[QUOTED] likes this.
