Do I need another battery?
Discussion in 'General Tundra Discussion' started by Rica25, Dec 18, 2019.
  1. Dec 18, 2019 at 6:04 AM
    Rica25
    Rica25 [OP] Got Bam? IG ......@TNDRA08
    Ricardo
    Tulare
    So I'm will be running here shortly as soon as the bumper gets delivered this week a 32 inch light bar with Baja design sport amber wide and ditch light from Baja designs sport combo ......will I need another battery or will I be fine running the lights to one battery.....also do I need a accessory control or can I just install the switches on the empty slots on the dash?
  2. Dec 18, 2019 at 6:05 AM
    You should be fine. You can use empty slots for light control, if you wanted.
    Black Wolf, Rica25[OP] and OR18TRD like this.
  3. Dec 18, 2019 at 6:19 AM
    Rica25
    Ricardo
    Tulare
    It's the stock size but it's a Die Hard
    OR18TRD[QUOTED] likes this.
  4. Dec 18, 2019 at 6:19 AM
    Rica25
    Ricardo
    Tulare
    Do you know where I can get stock size do you guys have part numbers?
  5. Dec 18, 2019 at 6:35 AM
    Rockanock
    Rockanock 21 Chevy 2500
    Super helpful with your write up thank you.
    Rica25[OP] and NewImprovedRon like this.
  6. Dec 18, 2019 at 6:54 AM
    Rica25
    Ricardo
    Tulare
    Thanks will look into it
  7. Dec 18, 2019 at 6:56 AM
    Stig
    Stig New Member
    I wouldn't run those lights off the battery, just keep the engine running the alternator. Stock battery is fine.
    Trooper2 and Rica25[QUOTED][OP] like this.
