Anyome elses lifted tundra squeak like theres no tomorrow?
Discussion in 'General Tundra Discussion' started by RLHULK, Dec 13, 2019.
  1. Dec 13, 2019 at 2:03 PM
    RLHULK
    RLHULK [OP] Too many gamma rays in all that BBQ smoke.
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    I mean squeak and groans, its almost embarrassing. Pretty sure its coming from the rear, probably the shackles that were installed.
    Just wondering and if so what did you do to solve this?
  2. Dec 13, 2019 at 2:28 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    Mine is quiet in this harsh Louisiana weather.
  3. Dec 13, 2019 at 3:08 PM
    SoCalTundy
    SoCalTundy Tundra Owner since 2017
    Icon Shocks. Total Chaos UCA. Deaver u748 TC shackles. Dirty Deeds standard 10 exhaust. Diode Dynamics fogs. 5.29 Revolution Gears. SSW 17" wheels on BFG 35x12.5.
    I've been dealing with squeaks ever since I lifted my truck, twice! First time I did spacers on my front shocks to level it out. That killed the bottom mount bushings on the stock shocks after 10k miles. Second time I completely swapped out the suspension with Icon stage 2. It's been a year and I'm dealing with an annoying squeak coming from the Icon leaf pack that was added to the rear. I'm super pissed about this. I should not have to grease them up every time they begin to squeak. I have an appointment with the lift shop later this month to have it looked at.
  4. Dec 13, 2019 at 3:17 PM
    RLHULK
    Rich
    2022 Silverado LT.
    ya back in August. It’s done it since day one. I figured it needed time to settle in. thinking I might change the shackles to coach builder see if that helps
  5. Dec 13, 2019 at 4:22 PM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    Which shackles are you using? My TT set at the 1" setting rubbed the bed bolts and made the rear end squeak. (After I bought mine TT updated their site to state that 1" setting may rub the bed bolts).
  6. Dec 15, 2019 at 4:37 PM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    [​IMG] this is your friend
    Tundyfundy and Black Wolf like this.
  7. Dec 15, 2019 at 5:03 PM
    RLHULK
    Rich
    2022 Silverado LT.
    toytec at 1 inch
  8. Dec 15, 2019 at 5:07 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Hahaha, humidity lubes your lift:D
  9. Dec 15, 2019 at 5:18 PM
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    My icon leafs squeak when they get full of dirt. Clean them off and all is well again.
    14burrito likes this.
  10. Dec 15, 2019 at 6:03 PM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    I bet the squeak is the shackles rubbing the bedbolt. These are my TT shackles that I just took off. They were on for about about 10k miles - you can see where the bedbolt rubbed.
    landphil and 14burrito like this.
  11. Dec 15, 2019 at 6:10 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Race truck parts make race truck noises.
  12. Dec 15, 2019 at 6:22 PM
    Rubberdown
    Rubberdown Spilling my guts here.
    All day.
  13. Dec 15, 2019 at 6:23 PM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    This too. My truck squeaks a lot more since upgrading everything. :thumbsup:
    RLHULK[OP] and 14burrito[QUOTED] like this.
  14. Dec 15, 2019 at 6:39 PM
    Mine is quite as can be.
  15. Dec 15, 2019 at 7:10 PM
    Jimes
    Jimes New Member
    Bay Area, California
    2015 toyota tundra trd pro
    Mine squeaks all the time. Never can find it and gave up.
    bdpeelgren likes this.
  16. Dec 17, 2019 at 12:39 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Mine squeaked at the rear leafs and shackles until I hit it with some spray lube. Quiet for over 4000 miles.
    RLHULK[OP] likes this.
  17. Dec 17, 2019 at 2:39 AM
    RLHULK
    Rich
    2022 Silverado LT.
    I will check it out. Thanks
