Pics for Comparison
Discussion in '2nd Gen Builds (2007-2013)' started by Albinator, Dec 8, 2019.
  1. Dec 8, 2019 at 6:26 AM
    Albinator
    Albinator [OP] SAINTRIOT
    Utah
    2008 Tundra Crew Cab 5.7 4x4
    RC 3.5” M1 Lift 18X9 5-150.00 12 Offset Vision Turbine
    I’ve been going between if I could just have one mod, would it be to level the truck or put spacers for a more aggressive stance.
    Any thoughts and/or pics of your own trucks with just one or the other (like just having Bilistien 5100s with stock tires and wheels (even a bigger tire but stock wheels))?
  2. Dec 8, 2019 at 6:45 AM
    18" TRD Off Road Wheels
    :rofl::rofl::rofl:Only ONE mod?!:crazy:
    That's going to be a very personal decision, because neither is going to be hugely performance impacting. It's all going to be a matter of preference. The stance improvement can be had without spacers(new wheels if the budget allows), so I would go that route if you decide on stance. Personally, I like the factory rake and I won't run spacers, so that'd be my go to. Prime example are the SCS Ray 10 wheels. CementTurdOffRoad is a member here and he had them on a stock suspension with 275/70/R18 tires, and it was beautiful. https://www.tundras.com/threads/wha...d-gen-tundra-today.713/page-1061#post-1434584 this should get you to the post where I asked him about it.
    Black Wolf and Blue Thunder like this.
  3. Dec 8, 2019 at 7:06 AM
    Albinator
    Utah
  4. Dec 8, 2019 at 7:15 AM
    I was pretty happy when I found those wheels. It's the exact thing I want for my truck.
    @SCSPerformance is the manufacturer of the wheels and they have a presence on the forum. As far as I know they can only be bought direct or at select places that stock them. To get that stance you would just need any wheel with the same specs. I see you are in Utah, so I am not sure how far you are willing to travel or how much you have in the budget, but there is a member in CO that is setting a set. >> https://www.tundras.com/threads/colorado-scs-ray-10s-matte-gunmetal-800.58150/
    Albinator[OP] likes this.
  5. Dec 8, 2019 at 7:18 AM
    Keep in mind, since your truck is a different body style there might be slight differences. I don't know anything about the previous gen trucks, so you might see if any 2 gen guys have these and can give you a heads up on any trimming they had to do or anything.
    Fair warning, the SCS website is a bit wonky too. If I were going to order them I would try to do it by phone.
  6. Dec 8, 2019 at 3:12 PM
    Albinator
    Utah
    How does this wheel fit a 275 70 R18 tire and has it stick out like this for the tundra? I currently have that size tire.
    HighonFirewood likes this.
  7. Dec 8, 2019 at 3:15 PM
    That is because of the offset of the wheel itself.
    Albinator[QUOTED][OP] likes this.
  8. Dec 8, 2019 at 5:31 PM
    TundraDude18
    TundraDude18 Deus vult
    'Merica
    '21 Limited CM
    Silver Bullet Express
    I could choose just one mod for my truck, I would definitely go with hot babe in the passenger seat.:thumbsup:
    Definitely improves my truck driving experience.:D
    I married mine;)
    GODZILLA and Albinator[OP] like this.
  9. Dec 8, 2019 at 5:37 PM
    Albinator
    Utah
    :bowdown: Amen, and same story with me with 3 munchkins in the back
    GODZILLA likes this.
  10. Dec 8, 2019 at 5:41 PM
    TundraDude18
    'Merica
    '21 Limited CM
    You, Sir, are on the right track.:thumbsup::thumbsup:
  11. Dec 8, 2019 at 6:05 PM
    HighonFirewood
    HighonFirewood Everything can be fixed with a hammer.
    Stage Left. Colorado
    2019 Tundra
    I have 275/70/18s...stock suspension. Nitto RG’s. SCS Ray10s. Love em. I have poke photos somewhere on a thread..26FE9EAC-8340-42AA-9ECC-81EF08427777.jpg
  12. Dec 15, 2019 at 4:21 PM
    Albinator
    Utah
    I just wonder if that size would work on a 2nd Gen. since they seem a little wider than the 3rd Gen?
  13. Dec 15, 2019 at 4:26 PM
    HighonFirewood
    2019 Tundra
    I had a second gen, but didn’t have this size tire. Not sure but I think there are pics of second gens with this size.
  14. Dec 15, 2019 at 5:00 PM
    Albinator
    Utah
  15. Dec 15, 2019 at 5:20 PM
    HighonFirewood
    2019 Tundra
    It says on there these tires won’t fit my truck but they do. You may need to bend your skid plate a little, or cut your mud flaps (I did) and they fit fine. Wheel offset is important. My Ray10s are +25.
    This may help
    https://www.tundras.com/threads/can-i-see-your-275-70r18-please.16553/
  16. Dec 15, 2019 at 5:28 PM
    Albinator
    Utah
    Thank you. I’ve been riding on 275x70x18 for 1.5 years and don’t have rubbing either. I just want to keep stock ride with just the tires out of the wheel wells a little for stance. What is wheel offset? I’ve had someone recommend 20+ or 30+
  17. Dec 15, 2019 at 5:48 PM
    HighonFirewood
    2019 Tundra
    Offset is the distance of the wheel mounting surface from the centerline of the wheel measured in millimeters. It’s a little confusing as it depends on wheel width too. My wheels are 18x9. And positive offset pulls the wheel inward, meaning if you want lots of “poke” you may have a negative offset. The amount your tires stick out of your wheel well. With a 9” width I have just a little poke (seen here)
  18. Dec 15, 2019 at 5:54 PM
    HighonFirewood
    2019 Tundra
    The owner of SCS is named Vin. He is on here and Tacoma world...he would be a good guy to reach out to. Highly recommend the wheelset, it’s my favorite purchase on my truck. @SCSPerformance
  19. Dec 15, 2019 at 6:02 PM
    HighonFirewood
    2019 Tundra
    You have a white truck in your avatar..if so, Go bronze..wish I had the balls to put bronze on my MGM..
