Skid plate missing bolts
Discussion in '1st Gen Tundras (2000-2006)' started by Vegas_2002_Tundra, Nov 12, 2019.
  1. Nov 12, 2019 at 8:49 PM
    Vegas_2002_Tundra
    Vegas_2002_Tundra [OP] New Member
    Hello and great forum you have created here!
    I am looking for answers for my Brother who owns the 2002 4x4 Tundra but can't seem to find what he is looking for (even at the dealer)
    So here is my dilemma.....
    There is a Splash/guard pan under the front differential (What is that called and is there a link to a diagram anywhere for that area of the truck?)
    for some reason, he is missing screws from the pan and now it is rattling.
    Any help would be greatly appreciated!
    My name is Brett by the way!
    Thank you in advance!
  2. Nov 14, 2019 at 5:12 PM
    Vegas_2002_Tundra
    Thank you so much!
  3. Nov 14, 2019 at 5:18 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    Take one.of the bolts out.and take it to your local hardware store. It's it's a legit mom n pop shop they'll likely match the bolts for you
    Migraine and BubbaW like this.
  4. Nov 14, 2019 at 5:25 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Local hardware store? Whats that? I kid because big box put them under around here sadly.
    Big Box should have them located in the pull out drawers in fasteners section which I just visited for metrics to fit the running boards.
    bmf4069, 15whtrd and Migraine like this.
  5. Nov 14, 2019 at 5:45 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    Luckily we still have 2 local stores. Ace hardware and Stanton's Grocery, Meat, Feed and Hardware. Stanton's is the original general store from when my town was formed in the 1800s. So we try to keep em in business since they more or less started the town
  6. Nov 14, 2019 at 6:07 PM
    @Roman
  7. Nov 15, 2019 at 7:08 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    One of the bolts for the skid plate? There's a couple of different ones to choose, but they have the part numbers next to them in the image.
    JohnLakeman and speedtre like this.
  8. Nov 15, 2019 at 2:31 PM
    Fred
    Hand Protectors
    I used self tappers from big box. They are the all weather metal roofing type with both a rubber and metal washer. Make sure you know where your fluid lines are located before zipping them. Use the 3/4” long ones and zip about 4 on the sides and 3 on the top. Cheap and stronger in my opinion.
  9. Nov 15, 2019 at 2:33 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I zip tie mine. Just replace them every oil change. Solves the rattle
  10. Nov 15, 2019 at 2:35 PM
    Fred
    Hand Protectors
    That works too! Did it on a few other cars. The 1st Gens don’t need to drop the skid plate to change fluids fortunately. Only if doing other major work or if you have T-Rex arms.
  11. Dec 15, 2019 at 1:08 PM
    16 blue crewmax
    16 blue crewmax New Member
    Doug
    Richmond Virginia
    2016 Blazing blue pearl crewmax trd
    I see this has been covered but I am missing the insert that the front bumper plastic bolts to the skid plate and also the front skid plate bolt any help appreciated
  12. Dec 15, 2019 at 1:11 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    They break often. Cheap tho, order a bag of them from @Roman
    Roman likes this.
  13. Dec 15, 2019 at 1:15 PM
    16 blue crewmax
    Doug
    Richmond Virginia
  14. Dec 15, 2019 at 1:15 PM
    16 blue crewmax
    Doug
    Richmond Virginia
  15. Dec 15, 2019 at 1:35 PM
    16 blue crewmax
    Doug
    Richmond Virginia
    One of the skid plate holes is cross threaded go figure
